Replace flex ATX PSU fan/ Suggestions welcomed
2,774 (0.57/day)
East Europe
System Name PLAHI
Processor I5-13500
Cooling 120 AIO IWONGOU
Video Card(s) RX 6800XT
Case TT URBAN R31
Mouse Logitech Triathlon
Keyboard REDRAGON MITRA
Software Windows 11 Home x 64
Weekend is here! : ) Weeked warriors assemble!
As I said in previous thread I got an old 3D printer gifted, but the PSU fan is really loud. I opened it up this morning and it is a 60mm x 15mm 2 pin fan. I would like to replace it with something a bit more quiet. Can you shoot some suggestions? Can I go with a dollar ones from Aliexpress or they have to be PSU/server graded? Noctua has 60x25mm, but I don't think it will fit and even if it does how do I change the 3-4pin header to a 2-pin header? What kind of crimping tool do I need? Attaching pic of the PSU. Thank you in advance.
3,950 (4.95/day)
Russian Wild West
Processor i5-12400F
Cooling Laminar RM1
Memory 32 GB DDR4-3200
Storage Yes.
Display(s) MSi G2712
Audio Device(s) Yes.
Software Windows 11 / 10 / 8
Get yourself a resistor. Fan will become slower, thus more quiet.
Beware of overheating tho.
468 (0.10/day)
Lithuania
Processor Intel Core i5 4670K @ 4.8 GHz
Motherboard AsRock Z87 Extreme 4
Cooling Lepa NeoIllusion RGB CPU cooler
Memory 2*4GB Patriot G2 Series RAM
Video Card(s) MSI Radeon R9 380 4GB
Storage Transcend SSD 740 256GB + WD Caviar Blue 1TB
Display(s) Samsung SA 300 24" Full HD
Case NZXT Phantom 530 + Bitfenix Recon fan controller
Audio Device(s) Creative SB0770 X-Fi Xtreme Gamer
Power Supply PC Power and Cooling Silencer MkIII 750W 80+ Gold
Keyboard Steelseries Apex RAW
Benchmark Scores IT WORKS
A. Your fan is loud by design.
In this case is difficult to find a solution to silence your printer. Silent low size fans such as Noctua could be not effective enough to maintain required airflow because low RPM. Usually industrial grade applications require high cooling capacity in low space areas. That is why they decide to use small size - high speed fans.
B. Your fan is worn out
In this case there are more solutions. You can find an original fan in the ebay depending on your printer or fan model name. If you will look for a different fan, you can acheve lower sound however, you should check if it have same operating voltage as well as similar amperage and spinning speed.
_________
Since I cant hear the noise it is difficult to say which issue is in your case.
Fan connection: it is easy to use 3-4 pin fan in 2 pin mode. You just need to connect positive wire with negative wire. You can to cut both fans cables and connect old fan connector to your new fan.
However the simplest fan conversion is this type adapter: https://s.click.aliexpress.com/e/_DnCIUBZ
Before buying new fan please check sticker on your original fan. It will inform you if 5V/ 12V or 24V fan you need.
Also compressed air dust removal + WD 40 could improve your current fan performance
18,584 (2.63/day)
System Name AlderLake
I replaced a PSU fan once and then connected the fan to a fan header of the motherboard, it worked for me. (Enermax PSU)
That was back in the days where I dared more modding and such, won't do it again now these days though, I prefer a stable system without issues. :D
2,178 (0.80/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Storage six M.2 pcie gen 4
Display(s) Sony 50X90J
Case Tt Level 20 HT
Power Supply Corsair RMx 750w
Mouse Logitech G903
Keyboard GSKILL Ripjaws
VR HMD NA
Software win 10 pro x64
@lZKoce
as long as you can find out (and match) airflow, shouldnt be a problem.
i never really cared about (airflow), as long as temps werent worse (matching fan cfm or not)
2 wires are just +-, you dont need rpm readout for that application, so just ignore yellow wire if its 3 pin fan.
test if the new one works, then strip a longer piece from the old, and replace the fan plug on the new one.
noiseblocker and arctic usually do a decent job, and carry silent smaller units, common for ppl to use on non pc stuff like cabinet events or bd players.
pro best airflow (PK2)
black little less, but also sub 19db
or, if enough space, you could use a shroud adapter, and use an 80mm fan
222 (0.26/day)
Could give this a try: Zephyr 60
Has 3 pins, but shouldn't be a problem.
At least, if it's not working, you'd lose around 4 Euros. :rolleyes:
5,488 (3.65/day)
Colorado, U.S.A.
