Replacing 'Northbridge' thermal paste with AS5: Any Improvement?
HookeyStreet
Eat, sleep, game!
7,122 (0.94/day)
Great Yarmouth, England
I recently had to rotate my Northbridge heatsink 180 degrees so while I had it off the motherboard I decided to remove the standard thermal paste and replace it with some fresh Arctic Silver 5.
Does anyone know if this is a good idea and if it makes a change in the Northbridge temps?
I ask this because usually AS5 :nutkick: any other thermal paste/grease ;)
Also I had some Arctic Cooling MX-1 lying around, so did I make the right choice in using the AS5 :confused:
You might get a little difference, depending on how warm it was running before..
Either way, the thermal paste is far better!
That was a quick reply, thanks m8. I thought I made the right decision :D
yeah AS5 is the best :D
I tried it a while ago. Didn't make any difference that I could see.
But you better be very careful, since the north bridge chip is just like a GPU...
It wont make THAT much of a diff, but its better than nothing ;)
If the old paste was crappy stuff and put on way too thick, then AS5 would definitely :nutkick:
It wont make much difference... if any.
While the northbridge gets "hot"... it doesnt output THAT much heat... unlike a CPU.
On a CPU there is a lot of heat transfered through the thermal paste... from the CPU to the COOLER. Think of the heat "flowing" through the paste. The cooler is big and the fan is spinning and a LOT of heat is being moved off the CPU.
While on the chipset... there is no fan... just passive cooling... and while the chipset gets hot... there is not a lot of heat flowing from the chipset to the cooler. Hence the compound is not so critical.
A bigger effect would be by using a bigger heatsink and or fan. And then the thermal paste is actually doing something... moving MORE HEAT ACROSS THE chipset/cooler boundary.
If you have an old CPU cooler (say 386/486) knocking around... then cut it to size... drill holes... thread the holes... and use it to replace your northbridge cooler. Fan not needed. THAT will make a BIG difference to cooling. It's a fun DIY project too.
(I did this in my silent HTPC system)
Well, as long as the temperature is at least the same or lower than before, then it should be ok. If the temp is higher afterwards, there is a problem there.
Thermal probe on Gateway Gamer showed a drop of 4'F overall. Not much improvement, but when combined w/fan, dropped about 13'F.
When I removed my chipset heatsink the ceramic that was on there was like concrete bonded to it, took me about 5 mins of cleaning it with nail varnish remover pads which worked nicely, then I put a nice dob of as5 and a waterblock on and bob's your uncle it does not get bloody hot no more! :)
I slapped some silver compound I had lying around in addition to lapping the heatsink, I noticed a 6*C drop in temps.
I know Artic Silver Ceramique is best for GPUS, though Im not sure about the north bridge. Also, AS5 is, IMHO, the best stuff out there. Others are great, TT, Zalman, AC MX, etc...but AS is the best, hands down.
Curious whats the difference is reasons to use Ceramic vs regular?
Ceramique is non-conductive and ideal for GPU's and exposed CPU and NB core where there are lots of other resistors, etc on the chip surrounding the core. If you have any AS5 on those resistors you can really screw things up.
Aww ha, I didn't even think about that...
some NB does have circuitry on top.
If you are careful enough the AS5 wount go near any of the transistors. I haven't noticed any difference after installing the AS5.
I agree, if you dont smudge it all over then there isnt anything to worry about with resistors etc...
TK have you checked your pm's recently? ;)
i did the same thing, applied arctic silver to my northbridge chip
the heat sink on it almost gets too hot to touch now, i wonder how hot the chip was getting before i applied the arctic silver!
i also noticed on my friends mobo which is the same he has a fan on his northbridge chip and i have some big gold passive heat sink with a sticker covering the top, im sure the sticker cant be good for removing heat..
For thermal radiation efficiency, anodize your heatsink black (or change it).
Northbridge coolers are often quite noisey for their size. Get a BIG passive block.
Use an old CPU block... cut it down to fit... and thread some screw holes in the right place.
For thermal radiation efficiency, paint your heatsink black.
Don't! Most paints would seal in the heat and not allow it to dissipate. That's why most heatsinks are anodized and not painted.
... some things in life just drive you bonkers. Especially the rubbish you see on forum posts :laugh:
