Processor | Ryzen 7 3700x |
Motherboard | AsRock X570M Pro4 |
Cooling | Be Quiet Dark Rock Pro 3 |
Memory | 4 x 16 GB Crucial Ballistix Sport LT red 3000C15 @ 3800C16 Micron rev E |
Video Card(s) | Zotac RTX 2070 mini |
Storage | Corsair MP510 1.92TB |
Display(s) | Samsung U32J592UQU 31.5" UHD + Fujitsu P19-2 19" 1280x1024 |
Case | Jonsbo U3 mATX |
Audio Device(s) | ATH-M50 |
Power Supply | Corsair SF600 600W SFX [currently RMAed] |
Mouse | Logitech G500 |
Keyboard | QPAD MK-50 mechanical |
Software | Win10Edu_64 |
System Name | Brightworks Systems BWS-6 E-IV |
Processor | Intel Core i5-6600 @ 3.9GHz |
Motherboard | Gigabyte GA-Z170-HD3 Rev 1.0 |
Cooling | Quality case, 2 x Fractal Design 140mm fans, stock CPU HSF |
Memory | 16GB (2 x 8GB) DDR4 3000 Corsair Vengeance |
Video Card(s) | EVGA GEForce GTX 1050Ti 4Gb GDDR5 |
Storage | Samsung 850 Pro 256GB SSD, Samsung 860 Evo 500GB SSD |
Display(s) | Samsung S24E650BW LED x 2 |
Case | Fractal Design Define R4 |
Power Supply | EVGA Supernova 550W G2 Gold |
Mouse | Microsoft Wireless 5000 |
Keyboard | Microsoft Wireless Comfort 5050 |
Software | W10 Pro 64-bit |
Define "many". If your motherboard does not already have a header for RGB devices, I would advise against this. You don't want to risk demanding too much current through the motherboard. I recommend you connect directly to the PSU.Can I connect many RGB fans or RGB fan's RGB cables or RGB strips using splitter cable directly from mother board without using any wired controllers or adapters?
System Name | Kursah's Gaming Rig 2018 - Ryzen+ Edition | SpartanCore | SpartanCore2 |
Processor | R7 2700X @ Stock (3.7/4.35) w/PBO+XFR2 | i7 3770 3.4/3.9 Stock | i7 4770 3.4/3.9 Stock |
Motherboard | Asus ROG Strix X370-F Gaming | Intel DQ77MK | SuperMicro X10SLQ |
Cooling | Noctua NH-U14S Push-Pull + NT-H1 | Stock Intel Cooler + AC MX4 | Stock Intel Cooler + AC MX4 |
Memory | 16GB (2x8) G.Skill DDR4-3200 | 16GB (4x4) Samsung DDR3-1600 | 32GB (4x8) Mushkin Stealth DDR3-1600 |
Video Card(s) | MSI GTX980 Ti Gaming 6G LE @ Stock | Onboard Intel HD 4000 | Onboard Intel HD 4600 |
Storage | SSD 250GB + 960GB, 1x2TB | 120GB SSD, RAID10 6x2TB (6TB) | 120GB SSD, RAID10 6x3TB (9TB) |
Display(s) | Samsung 32" TV IPS 1080p, Dell 23" U2312HM IPS 1080p | 19" Dell on KVM..mostly headless operation. |
Case | Corsair 600C - Stock Fans on Low | Lian Li Lancool PC-K7 - Cougar fans | Modified Lenovo TS430 Case |
Audio Device(s) | Aune T1 mk1 > AKG K553 Pro + HiFiMAN HE-350 (Equalizer APO + PeaceUI) | Not in use |
Power Supply | EVGA 750G2 Modular + APC Back-UPS Pro 1500 | EVGA KR500 80+ Bronze (Both) + APC Smart-UPS 1500 |
Mouse | Logitech G502 | Dell USB Laser Mouse (KVM) |
Keyboard | Logitech G15 rv2 | Dell USB Keyboard (KVM) |
Software | Windows 10 Pro x64 | Windows Server 2012 R2 (Hyper-V) | Windows Server 2016 (Hyper-V) |
HI FRIENDS !
Many means three fan's RGB LED cables.my mother board has only 2 RGB LED header and 1 addressable 3 pin RGB header and 1 Corsair 3 pin RGB header.then how can I connect many 4 pin RGB fan's LED cables?and I need to work my components at MSI mystic light.please give me full explanation bro...my motherboard is MSI mpg z390 gaming pro carbon.Define "many". If your motherboard does not already have a header for RGB devices, I would advise against this. You don't want to risk demanding too much current through the motherboard. I recommend you connect directly to the PSU.
How can I extent my RGB header to work MSI mystic light? is cooler master RGB or ARGB controllers compatible to MSI mystic light?I would only connect one fan per header. If you want to add more, I recommend using a fan controller that gets its power through a direct power connection from the PSU.
