RX 580 Flash ERROR: 0FL01
Jakiss
8 (0.01/day)
I bought an older SAPPHIRE Radeon RX 580 Pulse, but it's dead.
I plugged in a second GPU. turned on the PC.
The RX580 looks like the RX590 in Device Manager. "! code 43"
disable device / enable device. and is displayed without error.
so I tried AMD / ATI flash. more versions.
I always end up here:
Failed to read ROM
ERROR: 0FL01
I tried the command:
amdvbflash -f -p 1 bios.rom
Failed to read ROM
ERROR: 0FL01
in the latest version:
amdvbflash -p -fp 1 bios.rom
AMDVBFLASH version 3.20 EXTERNAL, Copyright (c) 2021 Advanced Micro Devices, Inc.
Failed to read ROM
ERROR: 0FL01
some ideas?
thank you very much
Failed to read ROM
ERROR: 0FL01
Failed to read ROM
ERROR: 0FL01
Failed to read ROM
ERROR: 0FL01
some ideas?
thank you very much
That doesn't work anymore, syntax has been changed.
Make sure the command prompt is open with administrator privileges then type in amdvbflash -? Or /? To get the list of commands and correct syntax, post the cmd prompt screen after you do the above.
I have a screen here, so how do I use the command? the same error every time.
no new idea? I gave the commands as described in "-?"
Hello
As i helped few days ago a fellow forum member i would like to try to help you either.
I downloaded an older version (2.87) of amdvbflash.
Open cmd with admin privileges.
Use the following command : amdvbflash -fs -fp p 0 bios.rom
Hello
Hi, thanks for the advice.
but it didn't help. I also tried the "super combo" :D :
amdvbflash -fs -fp -fm -fa -f -p 1 580.rom
Failed to read ROM
ERROR: 0FL01
please does anyone else have an idea?
You unlocked the BIOS first ?
Then you use the flashing procedure.
I didn't do that .... like this?
amdvbflash -unlockrom flash.rom
Format: amdvbflash
but nothing has changed.
ok i have it:
amdvbflash -unlockrom 1
but same problem
Pffff , let me dig further.
Again please be so kind and tell us what version of amdvbflash you used ?
If you used 2.87, please be so kind and try also 3.04 plus version.
Thanks
Thanks
I'm currently trying in 2 versions q
2.8.7 and 3.2.0
but I have 2.9.3, 2.7.4, 2.7.1
I can try
Thanks
Exactly the same problem.
only in version 2.7.1 I had a bluescreen with the unlockrom command
