Ryzen 7 Build
LostPot
2 (0.00/day)
Hi all,
Any suggestions on the build?
AMD Ryzen 7 3700X AM4 Box
Asus TUF GAMING B550M-PLUS WI-FI
Arctic Cooling Freezer 34 eSports - Red
Corsair DDR 4 64G (32Gx2) 3200 CL16 Vengeance LPX CMK64GX4M2E3200C16
Sapphire RX 5700 XT NITRO+ 8G GDDR6 SE PCI-E
Crucial SSD P5 1TB 3D NAND NVMe PCIe M.2
Seagate HDD 2.0TB 256MB SATA3 Barracuda
CoolerMaster Silencio S600 with 4-5 fans
Corsair RM750 750W PSU 80+ Gold Fully Modular
Thanks in advance.
I think the similarly priced msi b550 boards are better. Also in a couple months you'll be able to get 2080 ti performance for $499
looks good, kinda hard to make suggestions when we don't know what you will be using the machine for though. Are you sure you need 64 gb ram? that's beyond overkill for 99.9% of people
Unless you plan on running it in a cold room, get a case with better air flow.
Hey, yes, the primary goal of this pc is to be able to run simulation software like HFSS and COMSOL (for work) and games (for fun) =D
Can you be more specific?
Phanteks P400A is the best case for airflow according to GN.
but i doubt 5700xt will be of any use for simulation software
Hi all,
Thanks in advance.
I strongly suggest to wait. By Nov5th new CPUs(AMD) and GPUs (AMD/nVidia) will be out. I'm not saying that prices of existing hardware will drop imediately but you might find something apealing from the new ones for the same price. Both for CPU and GPU.
Just Wait!
