Samsung Develops 512 GB DDR5 Memory Modules Running at 7.2 Gbps
AleksandarK
2,981 (1.06/day)
At this year's Hot chips 33 conference, Samsung has presented its works on the upcoming DDR5 memory standard. The company has managed to achieve a lot of new developments, as the newer standard pairs with new technologies to deliver higher speeds and better capacity. The Korean company designed its DDR5 modules as 8-high (8H) stacked TSV (through silicon via) dies. In the previous DDR4 implementations, Samsung used 4-high (4H) stacked TSV dies, which are actually thicker than the latest 8-high implementations. To achieve the new thin design, Samsung has used thin wafer handling techniques, which resulted in a 40% reduction in gab between stacked dies. The new 8H DDR5 modules are only 1.0 mm thick, compared to the 1.2 mm of the older 4H modules.
When it comes to performance, Samsung expects the new DDR5 modules to deliver big. Running at 7.2 Gbps speeds, the Samsung-made RDIMM/LRDIMM modules can reach up to 512 GB in capacity. This is, of course, limited to the server/enterprise market. Regular consumers/PC users can expect to have UDIMMs with up to 64 GB of capacity. The aforementioned 7.2 Gbps speed is achieved at the specified 1.1 Volts of power, meaning that Samsung's implementation is very efficient. According to some estimations made by the company, the DDR5 crossover for the mainstream market is not expected before 2023/2024, meaning that there is still a lot of time for memory makers to refine their DDR5 products.
7,012 (1.41/day)
Case NZXT PHANTOM410-BK
Power Supply Corsair 850W
Mouse Logitech Hero G502 SE
7.2 Gbps is how many MHz speed?
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Goddamn, this may shake up the server world
(and then someone will find a way to mine bitcoins via system ram...)
ARF
4,677 (2.44/day)
:respect: :kookoo:
512 GB is a large capacity, what it can really serve for is RAM Disk, thus making obsolete any PCIe 4 and PCIe 5 SSDs.
1,208 (0.27/day)
Denmark
Processor R9 5950x/i5 6400
Video Card(s) 7900XTX/6900XT
Case Custom builds
Audio Device(s) -
Why not consumer desktop with 2TB memory - 1800MB for ramdisk storage that windows is loaded directly in to un startup and the rest for fun and games :D
7,012 (1.41/day)
Mussels
58,412 (7.78/day)
Oystralia
That's extremely low for DDR5....
clearly these are high capacity sticks, you'd start at the lowest speed for reliability of manufacturing, then release faster modules later
a threadripper with 4TB of ram isn't gunna be there to win benchmarks, it's gunna be doing some high capacity shite, with reliability being key
ARF
4,677 (2.44/day)
The thing is that this Samsung's DDR5-7200 is a very high-end, fast DDR5.
DDR5 for the consumers will be DDR5-4800 running at 2400 MHz double data rate, later upgraded to DDR5-5400, DDR5-6400, etc.
4,105 (2.60/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
It's for servers. The JEDEC specification allows for speeds between 4800 and 6400 MT/s for unbuffered (consumer) modules, and some sources mention up to 8400, which could be for buffered (server) modules. It's extremely unlikely for server hardware to exceed what has been defined by JEDEC.
Beside that, 7200 MT/s isn't extremely low. I have my doubts about Alder Lake's ability to handle that and not turn into a puddle of silicon even in Gear 2, let alone Gear 1.
In case you've been confused by the general MT/s versus MHz confusion: just avoid the MHz.
ARF
4,677 (2.44/day)
It is simple, basic Maths. Just divide by 2, or by 4, or by 8 depending on the memory standard.
4,105 (2.60/day)
Slovenia
Processor i5-6600K
Video Card(s) IGP
Software Oldwin
Yes it's simple, and still sometimes used in a wrong way. Even at TPU.
Um, when would you use 4 or 8? It's always 2 for double data rate transfers, and you too divided by 2 in your examples of DDR4 and DDR5 above.
Ruru
S.T.A.R.S.
13,780 (3.05/day)
Jyväskylä, Finland
Cooling Eisbaer 360 + EK Vector TUF + Acool XT45 240mm + Swiftech res + EK-XTOP SPC-60 / Eisbaer 240 + DCC
Video Card(s) Asus RTX 3080 TUF / Powercolor RX 6700 XT
Display(s) 4K120 IPS + 4K60 IPS / 1080p projector @ 90"
Audio Device(s) Sony WH-CH720N / Hecate G1500
Power Supply EVGA G2 750W / Seasonic FX-750
VR HMD Oculus Rift CV1
The speeds are always low or "low" for the new RAM generation for first few years as seen since DDR2.
6,662 (1.58/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
Go Sammy. bring on DA supppeeeeedddd :D
694 (0.41/day)
Greece
System Name Office / HP Prodesk 490 G3 MT (ex-office)
Processor Intel 13700 (90° limit) / Intel i7-6700
Motherboard Asus TUF Gaming H770 Pro / HP 805F H170
Cooling Noctua NH-U14S / Stock
Memory G. Skill Trident XMP 2x16gb DDR5 6400MHz cl32 / Samsung 2x8gb 2133MHz DDR4
Video Card(s) Asus RTX 3060 Ti Dual OC GDDR6X / Zotac GTX 1650 GDDR6 OC
Storage Samsung 2tb 980 PRO MZ / Samsung SSD 1TB 860 EVO + WD blue HDD 1TB (WD10EZEX)
Display(s) Eizo FlexScan EV2455 - 1920x1200 / Panasonic TX-32LS490E 32'' LED 1920x1080
Case Nanoxia Deep Silence 8 Pro / HP microtower
Audio Device(s) On board
Power Supply Seasonic Prime PX750 / OEM 300W bronze
Mouse MS cheap wired / Logitech cheap wired m90
Keyboard MS cheap wired / HP cheap wired
Software W11 / W7 Pro ->10 Pro
Yeah servers usually follow JEDEC and 7200 is already high (although probably with the standard timings). On the other hand Alder Lake should easily handle those frequencies, the same way a I7-6700K could handle 3200 (with basic DDR4 speed being 2133).
:respect: :kookoo:
Yeah, if we didn't have to pay 4000 usd/eur for 2x512 sticks...
543 (0.34/day)
Not Chicago, Illinois
System Name Desktop-TJ84TBK
Processor Ryzen 5 3600
Motherboard Asus ROG Strix B350-F Gaming
Cooling ARCTIC Liquid Freezer II 120mm, Noctua NF-F12
Memory B-Die 2x8GB 3200 CL14, Vengeance LPX 2x8GB 3200 CL16, OC'd to 3333 MT/s C16-16-16-32 tRC 48
Video Card(s) PNY GTX 690
Storage Crucial MX500 1TB, MX500 500GB, WD Blue 1TB, WD Black 2TB, WD Caviar Green 3TB, Intel Optane 16GB
Display(s) Sceptre M25 1080p200, ASUS 1080p74, Apple Studio Display M7649 17"
Case Rosewill CRUISER Black Gaming
Audio Device(s) SupremeFX S1220A
Power Supply Seasonic FOCUS GM-750
Mouse Kensington K72369
Keyboard Razer BlackWidow Ultimate 2013
Software Windows 10 Home 64-bit, macOS 11.7.8
Benchmark Scores are good
until you lose your power
Windows will still be installed to a storage drive, but on boot will be loaded onto your RAM.
Only the OS though. Programs would be on disk.
2,866 (1.57/day)
Those TB-of-RAM machines are almost certainly there to win database benchmarks. :)
Intel Optane and NVMe ain't got nothing on DDR4 / DDR5 speeds! If you can afford 4TB of RAM to accelerate your 4TB database, you're gonna get 4TB of RAM.
44,274 (6.80/day)
805 (0.14/day)
Madrid, Spain
System Name Rectangulote 2
Processor Ryzen 7 9800X3D
Motherboard Asus TUF Gaming B650-PLUS
Cooling Alphacool Eisbaer Pro Aurora 360 + 240 ST30
Memory 64 GB DDR5 6000mhz Corsair Vengeance
Video Card(s) Asus TUF Gaming RTX 4090 OC
Storage 3 x WD Black SN-850X 1TB
Display(s) 2 x Asus ROG Swift PG278QR / LG C4
Case Corsair 5000D Airflow
Audio Device(s) Evga Nu Audio + Beyerdynamic DT 150 + Trust GTX 258
Power Supply Corsair RMX1000
Mouse Razer Naga Wireless Pro
Keyboard Keychron K4
At long last.
100+ fps on modded minecraft.
Praise the blocky lord.
22,181 (3.43/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
That would just be what cpu mining has been since the dawn of time. Only thing that would be unique is a coin that somehow utilized capacity over ram/cpu speed.
1,457 (0.34/day)
Australia
"..the DDR5 crossover for the mainstream market is not expected before 2023/2024,.."
Good, cause it will be useless for gaming couple yrs yet.
