- Oct 9, 2007
- 47,933 (7.37/day)
- Dublin, Ireland
System Name | RBMK-1000 |
Memory | 2x 16GB DDR4-3200 |
Storage | Samsung 990 1TB |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Sapphire recently launched a cost-effective variant of its Radeon RX 5600 XT Pulse graphics card, the RX 5600 XT Pulse BE. The company extended the Pulse BE treatment to the RX 5700 series, in a bid to make them more cost-effective, and ready for price-cuts. The new RX 5700 XT Pulse BE (model: 11293-09-20G), differs in board design from the RX 5600 XT Pulse BE. It's also significantly different from the original RX 5700 XT Pulse. For starters, it features a more cost-effective cooler shroud design that uses ABS plastic. The underlying heatsink is different from the one on the original Pulse, with one less heat pipe.
Interestingly, the card has the same dimensions as the original Pulse, with 25.4 mm length, 13.5 mm height, and 4.65 cm thickness. Sapphire also trimmed down a handful features. The Pulse BE lacks the Quick Connect fans that easily detach from the cooler, letting you clean the heatsink underneath. It also lacks the dual-BIOS feature which the original has. The card sticks to AMD reference clock speeds, with up to 1815 MHz game clocks, up to 1925 MHz boost, and 14 Gbps (GDDR6-effective) memory. Sapphire is pricing the Radeon RX 5700 XT Pulse BE at AMD SEP of USD $399, although you should be able to find it unofficially-discounted.
