Sapphire rx 580 nitro+ ERROR: 0FL01 Failed to Read ROM
Masum Hasan
17 (0.02/day)
After gaming i shut down my PC on that time Graphics card was working totally Good, When i turn on PC again graphics card fan spinning continusly fixed rpm and Not working, I think its bios issue So, i do some research on internet, I tried Almost every single method like ATI FLASH, CMD, DOS, UEFI SHELL Also i tried lot of code, but it's not work, It's showing everywhere Failed to Read ROM ERROR: 0FL01 I can't flash bios, I think maybe graphics card inside component damaged.
Please check those image:
in device manager showing My RX580 as RX590
Gpu-z screenshot
CMD
DOS MODE
UEFI SHELL
When i installed AMD driver its successful installed like all other time
Wrong bios on the card
Pull the card, get a picture of the white sticker on the side of the card heatsink.
Remove the heatsink get a picture of a ram chip up close and a picture of the metal bracket with the numbers on it surrounding the gpu die.
Gpu-z screenshot
CMD
DOS MODE
View attachment 302714View attachment 302717View attachment 302716View attachment 302718
UEFI SHELL
Use Windows 10 and AMDvbflash 2.93, Find my bios flash guide for 2.93
Thanks for your reply :)
Bios was correct version, i also have previous backup stock bios Sapphire nitro+ 8GB Micron memory,
I used Atiflash 2.93 showed photo above on CMD,
Have AMDvbflash 2.93 Dos mode?
I TRIED BRO, still not work
amdvbflashwin.exe 2.93 not opening, showing error message
There was 2 bios for Micron memory
1. SHAPHIRE NITRO+ RX580 1340 Mhz
2. SHAPHIRE NITRO+ RX580 1411 MHz
Stock bios was1340MHz, but flashed 1411MHz and keep useing this from 4-5 month, Yesterday i got problem suddenly, Just i off my pc and on again after 2-3 hours and this is dead condition now. but driver install sucessfully, and gpu-z showing as rx590. showing all other information unknown
i already showed your youtube videos at first, i do everyhting but not work,
Stop using the win version
Did you tried with secure boot disabled?
:):):):):):), In my country don't have professional experienced graphics card repair shop, they can fix small issue, I don't receive this yet,
maybe it's recover not possible, i will try another shop, see what happened
