[Scratch Build] Project Zero
Another Update =)
I disassembled my pc and placed it into the new case for measurements.
y3mpNq_yP5u-thtFVFzNy5dH8TutRd22srq5lr7WPPgiz1VlsKKh1OOkI-cvuZLGGkfOzv1r6KdNghCLJXL4EMKAVKZsQ9QRJbVrBx-5gd-51rIREfyvTmHOuyWO4xcMFsx7NtpA1e69J5J8DWrUcHQp1Ae86urmmTQJj-lsXxANqg
Then i nipped on an energy drink and drilled more holes ;D
y3mRS1x7E2ch7krkIcra52O6AvcY-tJPUo5RoZvk31oFzTRNd1HkpJNIRli8Qup9Jut_aksP3S86azipsTQc8JZEf6ZeKTr4W8Mb8PD1nCYfEQDpQO0JmBjZzhTVS6lau3ZQzDxKOHmewVVIbUss1fpaT05bJafNMAUwTTJ1JnYzqo
y3mZVIJ5esZo0D7-w-eUYkSNBzEAdRyGo7RM1lrOJbD2cIC_r0wmchsqBWeQLagPMY-XrEg--8fEULd4sLJCSnDrnYRtbPJ2DkGrAOLicNzMjeWvgNl4KSwxOADYSEjaSd3R9nDl-V93DMT-nrVxHD_MCuQkue3k_4lnsWF7xppfOI
There on the right side you can see i failed. =(
y3mujO87GZMWyWH4gq4uw0K4eR2Lz7akxQVgQrqx0ImEnGOpRwcrh9Z-7K2CQMD_wwl1UdKd8la8xBw8z4XoWFphF8geumArEyw3CDci1Wpf9hzCpO3r1Ny6I5Dk-x7-diHtR3cXSiTDjlh3HoKLm83gODe894oqIXtJ4FzEIJuHZg
Here i took a wider distance, so i wont fail again.
y3mJBudtDqAM4rvhCADz5SYH3oee1kv5I9CTZdNSRuGOEXvrndTAfVDUbQGCRIV54lc1ge8Sq1yPKWwSLyDTM8vMP-1mSmRY-zaG17TiYXX-KUDC_SUkTwLK5n2tcSLM2UFwSy6p1G-bpOQ0W51IJUVDX0At5Ky24OrhP1ju7Qfk60
the next step to file all holes. and fix the fail at least a little bit.
y3mM_JS1o16218Mkx-z6JlC1GyK09AJMRCc1yCw25J_YKD0PGf4snNvUe6i6L6fq_NYVLqWhpB12chqyc7UoUpQCbgZF0kVfy-dTCx9qBsaMQcnZtahMrGsXVcFLpIc_xqtn9diyX7js7yzx0srcwHA3pbGtvafKxSARcE-w_qIH18
y3mLy0ZKjSZ0Q3YNBUcdO_r-A66bh_Earu9ygo6Eke9d9hZ3TXSpL0PUuyWbBccQNXMIfk_2ATajUZBenL8QBYpTtASsEr7RxbPWRju33SBNIJWS3lYpNZDuKoB0vdeuaQE3hxW7nVzhh-OwfEGfuJ4gp2B73tcC1Iqr5N0Jlab7CM
y3mKNlNgJgQH5DdhkTUo-YO8R9AgwIp__D95gAy6Aastr22iXUHOOybAF2CT_fw4dpxUM2GGQs0u_iuo7cKfQneqDfO3AU-QzGzRkH5G5YhMgipPH7-7vV8uk4Kl0esiDWZQt-p0yjPFjGqmrpcePG9hfWzD41UCx6pbKjUYb7Ukq8
I hope that once the cables are in you cant barely see it.
greez benny
hey guys,
i made a new bottom piece. out of LED-Plexi.
This looks way better i think
y3mBMQI7yhss0MOtzM18AFds7hyUrOK1N_vuJZEa-hZTyatAmn4jltg82UeIhr7fppbfSZXXdh8lRBkDHbbWVWzt75Dq6Q4ffNaJEcw0m7Cu3t3rvLEbmIXX-s_v_ndaV51xIcqlXy1WAhIzzjdZczGDVDt_npYD0oMyro2c0Rwdy8
y3mh9tC6glZxHwwLtecLuYVbtzh8v6w0qeTXJ3HYTxL9dHzSJ7D0PjxP-h1bS5pu1N3aWm6tWnXt7p8IY8TUl55etUkps7uJMDv0LPztui9k9PJ33aHPU5-SeOTnRFAgL22FT4aeQolOBmUHsi0UoeFTKk2aU9inR8viV7Z92WiTqY
y3mKxC3onj4WaJ8TsmwE9_17m6bT_eaHqkpkRNlsRKB8ZYqtdwYG8SPiPU_AioTQmYI9rp9sQNzRdwqO70tFGgmF3uhnIC0SBHCNG8uggs9-EF3B3W-9JcT5JKZd2w-vZ-NjvMIJMKROh2fmtl2zCslPfUk8POO3CunDCTq9j6IoVI
And then i made a little light test:
y3mrpUSE1_qaQxSnUrP8QYbqUGthTKlEHM98Ia2NR63M0E0z9NApqHobQ39J-twN_tRXbZKL1xSv1FJh-o9AJxshoG101bT1zkVj3vQR5ILNGv8rFC1cr9FDTlcpNlFCr5zXaZX4XgV-uBItiGBxA7ZLAPI_Au3UZ0d5Km0-20Uu_A
Paired the Alphacool Aurora LED rings with their Eisbecher, this looks so awesome even without water in it.
(i just noticed i should have cleaned them up first ;D...)
y3mafHU0SHpP7VluGadydg-Xwb85z8bZbRmeCx9f7j2X65WpPe8QHQWFodTUVDL54-MlZR0UCqTNGxC0Lu4qWb13JentzZ6Ico09nSVAX-4ZxV3FLs-K8Wg4wsnDAucxzRK3OFSgUiS8mn-xN_CBS79zdWH58gRZJ0tYAfbocpE7KE
y3mK4VmoixptoMNaCAjyWFWTx79UvQgn2-IawyMur4XiXnhEmG-_IKERCHRx1kFYQNyieJ6rZM_jJAF7AFxSa96r81eVDcGj000IBqCTx4IxCHuuZXQscpLKXdNf8Gw7jD_grwTnyOm_b3aqwfN20jN1rCN4tYv9W6_DeW6i2SlXV8
y3mm8AMde19Th6ocVPAZPqD7jTzH23cZVe7-gQBx1zjYSg721WqqxGqluUpuV_Akgcxv_oeJTMn-BTL_GyD2Pji-WKBK7QLiwkw4gw7NlfR_STrECXWDXg0PjSkWh0f5X6Fmkv_EU1TsHVOGO_bLaSuiPkBlah_ITsdO89BhGSio1g
y3mSIeGmnj_rAty9YnS8BVaRilH4VCefsT53mDSBipwdrZvFEAJ0uXYfI4uYJyBh-emjvsjJ0aklya6NETXu8TMV0qTqUs2GuugoydBtgahUMAbzZn8kNCTArvDd14OnrP94_bSGr1m8bvzpoPBU7_cyU9xaCKUACZXQfz3WlRGLWQ
greez Benny
great advance, have you thought of using led fittings? the would go great with those led reservoirs
Thanks.
Yep i thought of using led fittings.
But the reservoirs are lud up, the pumps, the ram, and the cpu block and then led fans. i think than it will be too much.
And even for the parts i listed i will test if it will be too much.
So another update.
I installed the alphacool D-Ram module.
y3mZH_euNkX2K8gPu3iKpYzGAscKbGK-8mjOjfq41nhFpn7hSuX48vzS-KjBSkF3fJi6W2-KQ-CuWVT1Mp2S8u4QYI9Gvca2WcN8c2-0Fu1KZurcegplZMZJsb-gKBH2XpSSgs8eOg3toFkDDnSlTQiHu7fzbLdrde6aVDvYVXG4Q4
y3mXXEaP0gEsWWlIdjT7OATEJtRAHV95KsHAUCaL6sDFGiqLXpdkCu1Agl6Z-UCD1h5hHbaiNQocVKZyntris9wlZmoLwnVEwl0x6LXjmV18vZc4VgakyfkkCItdS0Y3uSpMj0rIocrXeVAHXUyuioq8qGAxNox9TDCdNFe8Fm5fqc
y3mFK1cchMjACL03czWYM3arP6AZLYDQdayRX1y4C7lFawNrTe83C0s3Ih08Nz2MhaXa1SQ4nK1qJ2-Bi-WEEafrtfuBm8007FcNyF7l-t4CLaDlGPTWv8XSISoCbMsJh5i-R9oA8U0VV_eITq9RuSOCjgD6KxE0ygdpXGaHn_TJyc
And i had to drill even more holes.
I forgot to drill them for the GPU powercables ;D
y3mKEkWJoz1RwFANU3m6qeXEuEhROPUg9nHaQZolDcw_3nhdtnihRab_UXMBwDNofU3hAP2YGUG2i9YwsgtF5XSOngO3rqUkTyXCWprsUnXCZMjU2fQGjdQllx9WtYQtWQXwyNZP1HmGEjvZDZOI3gI_QDI7RlV1ITAD1MjcL2fzGI
and two more for the waterloop
y3m8zjxodChREOsXHBc4dSISEMGg61upO_AuD9h5J_oPESAa--D3zEYEeZTtoC2221CJrEp5pAkUjdh9WVG3rf8EeXLU6OwwQ9JXta1vqp6jjyEh4h-husb61ZcCPYL-9zJgedPb9qLuxeUNZrO78MoLl1bNvtEDYHj7GhCIXL91y4
y3mSwvbaKgziog0AfV-YZvcMSBX_w9Zw2uECJGvMN4Spc4O4hjsHuUZmcP0VM_jFeWQKmdfbRZTp5NkUnRve229F1tviLwsPJesozk1XZEKVaSyRM6QcSHkySHQk2mRYl9lnfhGRSyxAZ4VAmvJux4v0Jomkz-w1QoHDDYN8gGVDQk
a bigger one for the PSU cables to the back.
y3mjyKhEGmdBpSZmGd5iqYSyQXnk7pv8PftYybjHh69EX_mvePzReTwDjySjelb2TXR4cL_okzR3hWTiIMQxPdQnH3XHHRQOjGXZW1G-z-l4qNwUuCiIUCAbM93AWjtQYd6tZnwVRhTydQTIoiigNROOWTkJ63MnWOot3IyQZL3x6Y
and i clued the cellular rubber behind the red plexi, cause the pumps will be mounted on it.
y3mk9ACChtb58yJUwc_oIVcGRoJOTk3PyX6XBWX7BEa6-2YNwiHKh1J8IeE0BoqnWMe-EIDxG4iFeXeoGQN8hLNa-Ky0ouRnMNdqs4Q7QfI1dwx7_oWhAqIcrqfKULmxLOgex2uLnhLl1WJ2gp822m6ohbvFgv6iSMHVc3HyHdtgUc
Now i have to wait till Gosumodz will have their sleeving tools back in stock, to make me my own cables.
greez benny
Hello guys,
i ordered me some more plexi for the back.
y3mjYNQMxxKN8pwutCyXpOHX5yuQF4sfYMiHRTOla_IjHew708MeGdIZoossrwRckbKesPlXd5Mst_mlirZWrJEWRsV8HWA-WeXIY5HDST02a52EcZ8hOlI79tJ9VU6uWx_xEWKB4HeNyk_z_c3_s4KoJA7mwOxIJtvaH0G5F5PHGQ
and made a hole for the cables.
y3mVFxJDon4Y6r_xATG8ZdDV36dXmBhn7l_ZJW-bL46h6XKWdXUzFCeuY1fXf_iE5B2Aq4OSaDlYpt5ty6vKmOVCeTxCz-Lg1mT3GMMiBqW7JPluX_1qcsjCk7X-K61r-6SrnbGPImVwyf9QkOyCsGliemC4UqH1jrH96bnFE4HW_I
y3mreDDMY48OC7shKowBARniVuZs6RRoC4U7OVc_jVkk_BUGU5seIWQ0LXXLFsiQdT5_Jqzr9SFi3vMLPxpwXgJ67eSw1MykYP-0alA8BEDXvP4QlC0nTe2njWcGoYWPt6IeAef_JRVFuhF9zMCtpji40N7wZ46bnuCZo7Hcp0_wZY
And holes where the warm air can leak through
y3mETtYeh9rN0KYUXsEjN7sl3ngjMEdPWYvx2VRj4RgzL_fXWTcQVAWs0i7vCLG-eu2HQx7MWCK8vmL9DxNueWG7a8SG3fn0HQbjgxf0Nsh2OyQfCFnFSavDazpUp82TQWskALrXCg_b5oXNpABxTXVSFEjEEyUlvrm-oJGV9nHTsY
Let the fun begin... ;D
y3mbYVyb38yFmaZgkpuvBGvCSwIPsEeTPRvsItpsp4Hedn34_JnN7lw5fIUC-bJMpog-lUG-Muiq4fIy5_l54zXYxdleiXBsuLNX6BP4GUZ5N1xufrmk00xsPSbRYyRn0B7f0OHCRULalJbUkk16hIYEC_Eqt37v_66-kFekWqTlf0
This wasnt fun at all
y3mBWcyILENO0rvWDRMBxNkay7k-jWQjKu-YPhOOZFfZYv5POH3uxZRQWl-nyKJdFx0dzyrFfvtG_Cta_FNoHcwa6o1CLiG-RuLuIRs96f2b1IJ7UWhOItFhoG3O8J-p5r7G5WZjUp0OHH1OGEQdzOajGRq9x7c7XgPRLqCb4HBOWw
so i decided to go on with something different.
y3meJYM92nf0-zVY8saDiWo84oKneTQZKHmuBSxKA6IcZs-MdrGB5D5rKuVC2omY0iZSJ_1KG2Uz1S5G5qEj20xpJmYvy7LlYgZCjN2x_fVviXs4lbyQUhcbWXyNbL-koGoo3H4SlPZk6FxrUpFHvumydkarqclK7i-RoHv3zcXOJc
y3mGOXKFniyEQSZFlzzcqmODvH9e-EwY0fcRjz-dz8woN0glG5qt1pOjruknPrs-LlxYBjF71PioSsydx8tlih-pxh4pWlA-Z1xZZOdXB9tSkqTnT2-bzkjQ_IN2cyD2SRwYJivI_UL3PEliGarpuxj7RB_9a04L4A-A6DlttrPNh0
y3mTZG3thjrrnHjsPlcqLNpwt91KeGwcIrcCrZ_SDmdaRbRp4e1v5BdFki0baXe_FCGIwvXFb05oJpq8Dox5Z5qclFchOnTwv3KAKVtPIj4eLWE0NqH99c85pxVAjcU0yIZppYtaOdMyr3ejke5SP9d37rHJwjiciRThLNm7qCgWL4
y3mXF9VKP4JVs9b29lcThWslauNnni2Ih2ufi0m-eq__SdEoL7n-9QJPc9tPyrSZCAyLQiotnl4sDM59QEnA4PEerFjE-HaPkob-mVIxVRjTMv6i0aqtQWcTm-L5E7WoWqpFfLltuDgBw0t51osEnfqAVvIKRKqZiMTASvjDdlqDDE
y3mDSz9NbZk2OdGnvhNyzaGcbzsBwoo7MBmjqBPFAYfcKWwCLJDsDGTt5tqIPZbYW0axTuEkUT2_zTMaNimyza2ZE9-U8dUdX7tFjm1vvESxXa0KuFFoDUQ4lL8AryRaB20gTtGZ5_eT3D-ECbeFP83d1uxEbRI_L9mRmwMq5DrURM
y3mGRf5RCmXVHJBd-qrmgk8qsakTdJP8RYG3owN3Kz2RGdQIpLijfRirwFbRezYWnEG9or7t9ExAIJzIPTp1u_zukXPJPDYc4-YjV2aB-aIT2FU73WJERhpM_1ZhlugOtFJ3I9Pq1cCTYepDxbL8l7ThLTCWBkmabSgMSIUYT0ZhN0
y3mzoKJenH7HCBrXj04damT_Cn9btz8yo0SBn68abobgBddizbhO5LRugfSkJMavwUTDFQEGeBzwQVlIL-we0YZ4eKs04xlOq30HdxJeJqbSxe6xDQoT3xtEnCuL91f-Ksdbj5BX7L1_NVaWD51s3hcoJtkOsz4LQQ-W5AahrU98N8
it is a little embarassing for me that i made a mistake again.
It cracked because i was to carefully at drilling the big holes and used the drilling machine to slowly so it canted and the plexi got a little crack.
but i want to show you all.
y3mUGvGBtpotCQbtyGpcf0WZv6huDEbfgVIuBHPhBV6NPu5OKM8GVFr-F9-oL1J7jYWfZP2lBgcUShN94rq6yv7r-e0RMMwd994hAnyQdIDF-c6l40hRppLnn9_ZvAY0rOzvqmaG7QUOf5z9zl5BUoFYrpTtNLUZH5GNr_6ctwcmcI
y3mtGGbW7DSvA_Tn29FKYBZ7G-NFNjq3JB2kH9dDGLKtD2SnbOwzuvNoKDCdR03a-StQ_gt4QlxjxUrmCjhCFXxqEOHl-kGK6-4GAcWiwMoOhE6M0m214RpxpYwpkVRSoDLKGEzyTJ9prh1eK6OCWuFrHLG9nQNdYhhIvfUv75EMxQ
hope you like it nonetheless
Benny
Everything looks pretty cool good work but I don't like the panel you just cracked. The air vents (if that is what they are) look out of place on this tower.
I get the octagonal vents but the horizontal lines doesn't make much sense to me.
Thank you both for your honest opinion.
yep this should be the air vents, no contact to the fans at all just a way where the warm air can escape.
I made these horizontal lines because drilling so much holes wasnt fun at all.
I get that. but they don't look like they'd be very effective vents. perhaps if you redo it to fix the crack you might consider using a router instead of a jigsaw it would be more functional and look better. or went with a mesh like the bottom with a plexi border. or just did some easy pattern with only big holes. the thin lines don't make much sense to me.
just my thoughts/2cents.
keep up the good work.
So finally i can go on with my build.
Gosumodz got the tools back in stock and i could order them.
y3mfQhAfIGURDkJE4113wLn6AAzlZaC-jjMS0XZQgstO1WBJYYLnKAhkZaM7GbRXoM6cBE84_iLX-cm0s3MmfiayjNYH0OYG7KmP1uzBFVUPyPDYYs7cUkyLFrH_uPuagFvAV6-ZOgaOPaHEa2VaavDFABFRiZXHhJNl7fpCeRXfg4
my first time sleeving btw, but i'll give my best =)
Progress =)
i mounted the pumps and decided not to sleeve these cables, cause you cant see them at all.
And i made light test.
Also i installed the top fans.
y3mck_b3DBnkjV6U8jSHar9S9abtaX3b_QrOJH6lb1k6eZri1zl_wIwyc4SvT6SGrHJCnvgtGCayt2fJoZGiU-dFaEYokRKDIGzLXIuFuvIWKtetSC8bujgkZzzizpe8qvxAbYieFtqkdzxstVB8uo4iEb3Gj7zLCzUiDtzcyHGl3w
y3mLN8gXXjilkOJ9eNnD69kf2kWPo2U6yElsoNuUO2si-aMQ0F0JegFNFFGFS0dqoPbgPACQurBiO-44Ay67bkmdoKsTF8mzG_82YMIZFugkx91fb7nN1Wvkx14c_PGN4YxstgFv6y78oTQRfF-nsrSjPhkGbQwkA3nW3XmbA4axMo
y3mnSMkUZG5ZPdxOmW5ZWw2gKSpfpVYXLqQtJMMFrSmzTMB-6OTlTCu373wMFRmqyVUdQayoNi3S3MeT_jh6qgrOaO2BUog4kQ4R7KddNILo9lzilHoU2JbpeamIVyIyjmwaIKoZKPFYTwf6MQtfBVRj4HeBN3h4HUir_b56_5XVhI
y3mSIxH3k4D1b6Q2U-6LCrdI-6rRxgh_3DNrL_Sjd4O44CKSb8Ldf1_dj4mFe3C4rYvwXOB21JxnpF6WWbtHUYgPU7m4FGzYHH7V7Nm2f02DFMJI235bjXPYsor5JWOTJ9_q-cDmTjcVUPEWQs4kp6E3o3mhmAVfNA1Vcgc49jd9Ww
Then i began with the sleeving.
for now it makes fun =)
y3mVNnc1ysl-Le4xt0ola2y_wmK9dNtusevUlzkWgvAMXpPX_M6DRvKKnfx9huRWzQ03YwIeMyZR5qF9zqfYMnfMaKRGpvF-WXx-NIuc-eaWzxmOfPLTircQ3ZY4QJrNRwvaXi0nyRONrBHoYUCMrMgvE8H0WafnKdleLEPbSOTRQQ
y3mv_aJy5QiJ37Re9AsQcSeIv_5_M8jUEA-yV0LzDQK0DhTBiaYYyeX4JjrXB1tXmG3y6zeLLYD7OztLmaYX1NRHNUNSC9mzMgmj8IwGKqdpfCgxCv9t76UYfX50LpMR8NGL7Om8cHRTa7H0FI36kg_QteEB9Vs3aZ6MTpReLJI0rw
y3mR15qpb-Rqyo9M16GV_8xcoq75RYeF2qioX5SpGeKqmKmGE1ILEjqGXvBo5kTEGOm92NebpAXdQBR6S4vYt6vvZPtjuNtmus3uhwwyL_AgSU7dp1uWk9wP33_fcZKIOsnbVE6OXEj8bSrazxhA9-lU28NrbYBDMU7sVJbe9y4Hug
y3mXBl1kgjSjRjLSxp5tq9xvoAU0AGhkCYeV9ntlbD69hroBEpRjmF6mFivdH4RiHWV7s_Dy4lYEiuDLUIi1RhTwcaIWPfeWNn13hLrwwOfJhpPnVDnyK_sHxjte-N3pDut7dILf4sBbEhSutsr7zEKGmWEEZgW_vl25zwK5VT5h8M
y3mMu1rk9NUWnNBsiYrMyJmMjRcWX7EqAh4Fwi3UwUXyiTOfriccakF0wm8YobKM7f_Sk8gATB4lzE52jFSkNXROP2fQg1P9ZRw41-5CNjM4f4vx-CjSu9IApOw7R_hG2SwMwdrgKZADcQF2uqrHI_WPqymyQ7eExY50x9avGX2RsA
y3mrbBWOElMeFPrv_NWrpMEZa3FJsBMKuQFx69TvRjhKH6wbTJfSWJmE2QL7Q7N6LxSBhLnp0qAm7YZM78CUHs6G1KGWI2W9XSBAQzdr5KGS1MN28DFJRIoG0dg8xtdxcXRtKJwP7aJ-bmi_ms5rBj03OK_THVFHb8Uj4Nj_d9dTAA
y3mmb_Tprtt4mACD4rde4U2jjMxI58UG-hWUAIi_4-Fp_auA1eMvHG4d8-sWXstxSh2DBlv2T90I0ZeyEROFPrHg-d8NSohIqFE9cA8kOpeqVquoVEFNpdu4M7qodAQ8O94cHSxH0EhrbnksKqyUQDoB9sUZ80pBRo3zI-hSdaIRGI
y3mTQg5fpmqtP94pVhV14ejmMfmMv8VZ2s96LpWltm0T65ljwRIscNgytuhodj0GamzWSBPU0Tqs_2F-DjB6du3eweKG9y_HNWDzBfHcxvud-T2SneueqbaMJ5nnT_fjg-5PNwB4-wu0Bv_VDcSFXGqKgaZnwU-LPDNZXdxC5WF-Ow
And my two SSDs arrived which i bought on cyber monday =)
y3m7YqQ2vQL2POinRLNjX6j0FlvJ2fL9yuSX58KuyRWDhqG-jv5I_KayjhlytfNX4M9GqT2NJ0uZoQ05LXoSiepaWdMuj7blBbJxLIUS1w3_nc182vSFstuJfDcPnr0qS7Z6jS8QYgPZ39dsvsDtoH9-sQD5FioAs05r-iWUoqYsW0
stay tuned =)
Staying tuned...
Looks great!
Finished the sleeving.
y3mRR27hmccAL60TllkkmrVKyPG_E-wM6LYC0bGhcwUCY6C5nCdFJC6pU6IAUAVDr_1dgbpim-O1yKU30K4YwShRqHBD22TSf4xJgA7bAxMmizXxaMUwP69FRAJS2OQr-5mozuRiHspEZmrvdXkg73S6sOqScfrVtsn7-vxouosUmI
y3mc0nO3fsDB4dZ1BPdWOe8rIZEqA6Ctfzu0z6h1MUwhjCqw4F4bPLS-BL3f4ZzJzDqTfREdF8aFrSyxGJAPGSrf-WE9wxmbLirV0eCLJQUeAxDeeH-hBWaTRpmn7LVyZ59SQU07qkx7DJ4MxkXb7mzkh2Ay5RPpayV1qdQ1ZT3LYw
y3m1LAGlYX7hfpsUX9eCD8n8A9rkGbvs0OsidD9pHMGaZ7a_2ybcFHRbMz5M-rbaiXWLfy5qXlI1X0PIeVu1s6jZaiv8E4bSmx_RhR7a_5C0spKrqmnlZomkAYL4xnm_tdQOTDCWVjXUHexsqIhTJHyYdzPG9891pfWrxg4pHkM8Ms
y3mRXt4NzHTA8b6EUmeiKq1UOZcNevsrLY8cua80b-JxAt8Ggh2U1pQYGvTxggqWT26LmA8VsYepk4X-WXMQk6vm5HpMPH3T2sD3u0V2O-zsi0YfbD7-H19Df5cXLmWf4J6HL9na8e8jtAtR1vl73mwXjZZxV3R3DRoidUJopvf36A
y3m4k__x1FYmp6HlPZT26Ed3Y5Pnx1t0DPNSKhLV6L8fml3RGzYdhg43KhvQKVprvOXktTKROKhKt7rN4SklMWwS_v0WZvpAOOJtEmRk3WQuEGz4kqBfiMSohBGaZUUGrpXEyAGaVqvmJop3fC1Mpyjmfu247JZk1n_zG3X901dsf8
y3m4QIWUz4mwPbtyiBVBfav3P8pPi5CzRAth00jyOrK-ARmk4ASIS9Box1L0xlAiUO5KiGmjJLfbuBF0V40DlXMxCfLs7bfB6_joi1QI3_5EzZFfrq1vesmoAkM-aZ6j8t9Q8rfGw0PMON5p-b4E1f94-dgRzAnEiKnealulMyW374
y3mzwJBm3yd2zzkq-I2L2fDd8Yf7Vsgrv7na03pmcVzdk2r1zWZyzn1coKndyAE_iRYzCghT-QNnE_cqkJb77IXyWBqOTpMOSWjFds-llJRndrWd8nPjTb1zm_qd8Ie0eEELbvgGoFkLaNu56NErEYdwn6Be90ZC93kAZvyD_XV428
i have to wait for some cable combs =(
in the shop i wanted to buy them they are sold out for weeks now.
So i went to another and ordered them last Wednesday. But they havent arrived yet.
Next things to to before mounting the waterblocks and make the tubing:
work on my new enermax fans
flush the radiators
and think over the routing.
The colors are crossed.
Left side Res is Red and the pump is white
Right side Res is white and the pump is red.
I took my new Enermax fans and disassembled them.
sanded the Halo-Frame and painted the plastic parts.
The assembling is like lego ;D
y3mxJ9fzNdyXYIuT5TYqQ9Tx5oHYNWCEljrPIMlQyRSCTSWH1FlqozPgYoSnNi6trjK0ysv_84Sf00pZXzS8hKnRbpV1Ao4tZ-lbfZLbImnhdfrruOPQ8nTmqCw8cbHPd46VyXq-ZIa8IU5KX4CRdE9PjIf56qKKT46q8CuaeU_Yjw
y3mrm2kgV2KfMJYnAA1WhkBUDOoKpo7gzvzLENEgmgDVMLP4SG4kSMDNWYolw2iqMCTqIA3qewYIVcaYVZTRoPa2C7idw1PWKglXYBaIHA4-gOkziN3uKaEc_xwd0gEfn4qESg0HYqdKDPV7r5TIvmL6D-ILGnh_UaOdXBu-ns2DgU
y3m3a8C8JIPDowrgFsfjs6FZjE7v9-rWFXCLNAQT4fChbAgonYb2Kr8tFBEE8QblePpWSnbcx-vo76J4B2yHE81e9RwzpIl7CvrTXCdE0dINg_5oovY7PFER-7Pz1HDv8XyuhGbnq3kQ2-LX3NRdVKy6o4jjHwldxhxESQQZo9gkEc
y3mwVTYjpuWr0OREcfJ8QCMNFsAoXXfrZKEA3P-TzgYGfmqZGajBENw39aGhIQwiWtdxKG-YmL1imla4mftT1erhF1bk35o3zJflfiUCHZe9QbjkEWsXm2gByxroQh93Wg6ZJiJxXgUSmMxa-n_zr0OZGfFQ6QRyC6vQ6DfIRYbLA8
y3mae0GFee9CwdlYfnfSK0liVScZGJ2DEoR9XgMDGu7-t-9_IZmBAWU0r-W3p2SPXJQABLygSHS31GpzOyCg4rJ3ltFZe2VV7Ehweimo3_gcO-KhbJd0r-uVznPjw1LtWnWRSoXzYG_4og1jXZmy_7s3UKcmD64eUpFRzSm76uTmmU
y3m9lo0imgBkr-ePzkK2Sxn2HSVo1e_cOQLaAvn0sZ4ovzIwakJHfaPOHUUzTaCmNTAHTh4QC5MaWmjt_yjW_xj0szdYU0RrpW_2BAURMOUtt4YQUxW2JOk6Sj0UtWH2Ap4s92akuB2Ykt5lDv9GFR92Bx-YEnKYh0_LvGhibdJ1e0
y3mUGlacXjUBB8FZ9Ev0HEzPYzsqhgweRcGx2BqdX5kYb-KxLfEJ7y5zHUX8sjXSstYqsj0ls1ih_Q-WFqQ77FQ7tk_EnbZJlYuv2oIGop3LInpCDoV9rx_hKSx_mzpXllsVryon8Hf_tR0kT-7DWD1Q7RT-Jdc43i97hmdfv_HbDk
y3m4QYqvq-H1YCzss83STF5CZpHtyE04EUbNa2zWYtuTTc3qvre7zsjOUaZpn4E_zsdFtk5xBOPN9nXfh2uv_MJ8UZdZIDiPBMx4y1wLnKkZ54cxxeI2sW2mtaJrWLj0m_QanYCRHREmQehcztMCvAWvCgHI-wC3Tvld0OBcMBjn7g
greez Benny
Another update =)
I mounted the rads and the waterblocks from alphacool.
y3mIbSPwjNkr_JtqRvXhQvowsGx22LzqugvQ15znsdIilryFqi4gLXCt71AZaK-gxBzrC44_l7nuvH_KJQ6oY7dUHHcqSVYTik6uhCef-gYSR63bpteVzZF02OfOnePOk4XtpU23d4LCYRfrlEMrQg7prrvUugCktefHGbCRJSiD1w
for now it looks messy in the back ;D
y3m8yOG9qE0LiW-Rli-0CKNO_2jYNKZpxFds4uJzNI4EKNrU2rVTJtEyTUivzeu9nlHN-XG0k2eVXnxPGyZK0k16pnw19NRaI2G0M9dvADsV9LOyp0h5gDd9CsUlmTMEr4YKUaygSJ1o3dNEC1b6M8sgavbznA2Z0aFpreXR-oduTU
the SSDs are in place as well.
y3mIVjzCj5wH6vTHQ5hfpPsHpD1oyVfcW1gyhE0R0lxQJddQTZHEQdA0B4Pt4ycpoMckdIxb6ERKhdteEB4wEb382u3FCyyYvVB4OMgRBtp_YEQoD3XpBRAOFrMI4NIUAdMQe9L97ChttdAdGjrsI35lDMwr7ZjLzteTP5BSkv3gCo
The GPX waterblock with all you need.
y3mlRe4ImZOGo2xOhTf3x9CyZ6Os3oMA-mCTxuJ_AqfCli_jpwNlFunsFvw3ZocIHL-TfEU8e33zS6lxxH_0AAQHsVOZ6WHWe6ZA0ZZdG5s0BBGKNqFQmULp19LFBQUENRiW3mkyR70Tsb8tOzysvLapyvfHDrOQCAgB_BP7r5-lTE
my dusty GPU ;D
y3m1ePcXo74ogiZMRmyYc4ZT2rGamwbW3Cd0YDJceNzaOZbWR2kIjwoHVgqbbjxQFcAzTdTB6X1VPnB3KcJtKSeT6wZvnnu-CoQSJ6WIBLmaA8zi41TrXH3v0uvfYLoEjATnJdo9Ywz7ALCj2epQACzj7Fb_Rw0ATc5oL6_hctw_LI
y3mUAQ0AEQ3_rrPMvsoRVp3lzaxxqhxbFCShZ-FZtFQxgh518nhtGmznGQKXIApqvv9tcftLPmZEqaKe7jNzmV1iqoKgY3fyj022TGj6GjZreGFxxLl3e93MdxCZaINwEeMA7n-AC9O6hsYpi29HcnHgGdCn-ahV7LXOJcFrDzSjjY
y3mBT_Y3pqBbJRQPu58eNxbXr_Zyl8grZFlBzk4BYRZ02ceITQbINk1wWJQR7gTjRiwYLwbbemT9bzCN26Gs1Omr-r4m32vd18QCmDGJxR2NfXVVWqz0Sxi8rklVMNWBO7jd4xDC-LVxmm0XJ3ljG0TAMXmTIlhT0c_dV3gRHNL2bg
CPU block with the "Eiszapfen" fittings.
y3m_aUNveNCVtoS1T60DfJZAjQLeT6bcgwrRdhnBmWjMclWwVI_xuvA7TMFElKQM4VkaqH4SJgykl5KWKxKNxVpJBN8aKRgN-Jm40XV6aTfwquwfdE49nDuHXL6HWvRNSmgoc5TvjyDgS3hdLJ_pY6eqWzZdJnoTVe46bnzqmnhGF4
The DRam cooler.
y3m4lVVhb8W9Bm1RHxMi7Q6kSEMBmJRiRxhXUXYw5DSUHisGVCawcogPRsWxbADDbWr3GrWrxfZ3Q9mP9w85AIqubB-vXxToZOFArlvNukFAVaQafO2Qxn92Oy2i904ZTNwv30trNydFWqPXrZktb7lrP9xgoSifWVIqtr-pqQA8GA
y3msnodva2l01ZANUUO5bI1F6bMsO1CvdPnJmlyk8dL8o18UF_J8kcjIabPua6dSgs2YvQsFbRWhqVxqtrzrUcj8lz5ve22z1UuTtSMjCX98qdyOp8TAiI-n1FzYI3kHFrhp-KatItEp_51kFo_3tGg97sYUUKxHs5wFaT1d8eE-2E
the screws to hold the Mainboard.
y3mYrJyVJthMAQLw2JZsILkbq-kikhnSqHcoLDU5LB6t3S5hKk4Wnivgda0MHIh8nOeINEb3RHqU-3b-DaL6GjAsgxfwhAGAHD67y4QTC5bp4ykI1msHkzkCvPB_iSnVzZe5G0CzSeZdQ5dUnCWfOfKXul6clxvWouTkJ5MZ2gDB0A
y3mWqI7gJO_l8mRoyfVzBrP-9M7W-_9oKeilmRnvwlNGmVPmW-10S1-ds0zIN_X9-6UsfEqkf3c-3lwEXg7pTZ0I6sJiNsKOLNpygSZJSaTuoQb5ivrxKzyq_nEpsR664aRLKL9mlJPB7ylVGHDzyFKiYTGAVNts5jbchqeY8eYYNc
y3m_7v4ZqlEiKMFCXVZc14zRR26Rx0b7-w4G6AlF80snWjmSvr36bSbURmDhIyTTcrQd9OumbGXHUKJ4Fo6DjBQnqRNMZJiLKVVXQvxx01QOsUg2T8WAc1rd5luQfFnZmFeIczFkrTm5UnNU-Ve2Mjt6XlCaVl6rmoTKg6SHYRcz9g
y3mf4ZFh-348CoYjh73VRC0f_m9w-c69BoWUqSi7qOeMOlr1Y5LOPMUBtwuja6D69P2C7R44o0S9spyyu7MSll1J3a49OK8RZGT4bggo-eRaXSrWRwePO7ysFPVzMRudF0huTl2S9EXHaMQZsE8wSZH1evg13AotnkPOsAybXa2BTU
y3m3uWglCDSpSOWOncU_v9juL4bPV3ONQaL8H8OkqwU1IRTTRCCDSDv19ZEoUf4bi6QJfbISuSisFb-Zeg-k9fa2xIV8HI8vHUz9DM8CRwu5A_tvqXsXpfU5YA3ILdp6cfrCluO-c80kAmFdjN8GU2qcotTDtToTVxKSAVQ_C6Ikl0
greez benny
I'm back with another update =)
this time the hardlinetubing
All of that stuff goes into my case aswell ;D
y3mswc4bDUv4DNpuvCODuB8bW1F7JDW9R5RyFl89rCXkKN1xD_dd47u_WDXkeIF33NgRHvDVX6SB8E-RyR6RQyeHcS0zKsDaM-egQLJkHeZ9-3HrnTj2HR1bDycgDNvaxhs6n8Z595-IBfSn2h_pztQLhc-JfpjqDzZMZ-zZQ_zbUw
The first connection:
y3mYoBo8xnBg1L00Ev-euaxOmQhuSBXh5iqlIHpGp7w-SkE9LQRF92isB0Le41RQgHRDg4BN-YaeoZHaP0mamEfz2BoIOflIvKJ3kpB79rgraNOjSEigp-5g8RAXn69rNfmNkQUUS7OXzIvhZ5XKveTs73kJrXjJpn43B5A7LpM-Sc
y3mWPjDUEuolGLwxO3EIlYhQN3gF7fX_rJhWOz_Xs2Dck_exbRrfqp0xrQCzDhgsPI1jrqIgx1sEAeGiki84VMBEMDTqAwtmGyqZ0OqdDPVGNj1qjECdXMeA3LZr2N0DEWserQgj9vN0fb0fGiwxc2uQr_IJjrMF5YqWTiDpM2Dzjo
y3mX9ULNDUltyE3wdT4cs48aqRwKmLdzg2zsqFu6nIu8WL86lYpPbguiJrVXBsB-VE9tlsLrJpp_DZ3XZwue5DLxyN7B8NuOwFdhe3uoY_bFZXS-N4T1X6G5hBernjXiS0vDhqkw8wgOEQ9qNDZF_muQBBdIuQ1uX35uwzO7LnDu2g
the first unuseable pieces.
y3mVEAlNtqNzw6kaF1fgxynRdt7NKzgXRMLah8Oc7rDFwAAIyIbijP2uQfoVOMZG5sPu1vRVeGTq4eE7H6q7CcXXEfFKqIxQe1NqjkPzJgWRUZmG_Rk6urLP5yVLTGij1lS9DrJtvSMUukKY9Sirr6erHg3F0iRseXfwFepKBzGN1E
took a threaded rod to hold the GPU in place.
y3m6O3bb-q08u06mA6eW7-uOCvLv-u6QctURdj8v_r9KPMc0Qi_f8koHFd_WDVksvki83YOPEJFrxpaeO5_gy-yyuciDfqJEs_mZZ55R4OuHoCFhys5rEy6PsZm7qRzRGLtfNlRurWdjTXv7bZG4E26sVOGiffbdR7jxjFIMY59WCc
y3mdBAop9UZEuy69W24n6Ctzye1e9Vc59d9inM-Mz6x0vKh6hXb_p2WmFqgyQz2TiPFPC37PqvEVAxV13WmTvSHcmYUgYlTJsBlwYPKpNwnuhzSM5mNf-HHxpPrlHesbpHG3F0dc8Ez7l9eIdz4mzcLVMlHcD46czQh5q8Q6cLNDi0
y3mK6fzyIVLyePkYLjUMIeY6TCzoFDq5XpYX94XdEsOUvvhh0o_fgCJYmLWPjFWjXrP60i17JpEa1sYyka9VWuS082gQBr77OWtQgFnExxjO7S7lgngNEmghwMtIps5cl7kme-_bbduyVIu6JArxHuonGXrfxSEobH6YHi_yiSFrro
y3mPtRm9UtGk-ort1lrmvjLR8YndLMfWJWMZxtW4IcgnFWs4fOq20SEZgI6kNMoBSEZ_epHJgPysl4V7Kb5yfoFTxK32JgTIDQMMCC45wgCvglya7VcKiZQgZiBUnabu6F_7p8H7lP3r92WOsxdMOftuuSZM6-_yAfQdtypQosqh0M
y3mB1q_-dRse_eO--NVMYXIJgVt2XtZ1Jg47b_HWmZ92HIS1gBZU3HOeSrxbsjDgI6v0EkYOBxmgtVfmhnYHQMrJHZoYzsAe0QIxhie4KIiBIv_SGFFTXV7pchGQ_lqrIj-mrnbYMuFAbR5MnU5ALKePBhgbkmMj1CKtai_8teQX0A
y3mtu2pOVUHqA_6ZTVRz6eTCr9DqRchU56yUOeyk3KEjQpP5qb3vy7eD65uBIxgxEfUNIpkF9ZzlSuWALfb57hTE2PVyIk7XIZij4liGV0ro8slKbDscakszLGwc6i8ULyiR_oDtXV3QF_VIYd18Xm_f_Jn6HlyL1SxH9J9sAoEgik
y3mBPW_FVWIEpMxHlpGbPxBjQglZZ1imeIH8i806u7f8IB1BRarJJu5AxOeq_BPoTB58kHeVkSasYdql1C4Jq1T5CJGSynbMFUFRhoq729lZ0Nf_yXQeYJKS6SVHOxddu-zW3QVsVXqlK9hsnOvOym40zXDEMuxkMi-DBzhBL6g21A
This was my first experience with PETG, it was more difficult than i thought.
I watched several videos - there it looks really easy ;D
here are the broken pieces
y3mmXUBLeQhWPkF3xl3NEffEXGkLM5K4fInJ4rWJMKbeSEv3s8qjRsR0NufH4uWhW5sRhiIfk1sFqGKD8JRI7NjPjt2neGmZDqnZljsKGzjupuD5e6VA8V2ClaOlERI0VMTyqUSehikXzvJIoUdBvQ8KItmsuVRZCF2pI-hPXkMX0I
A leak test:
y3mr6_Jk1E7sHBfrZfGuoL_5BweL2dY6YHaMx0fDM3p6gKZpMuZ3oMTU7IYXuORsfK4efn1hB8x8SS63N3r8F5KITFzIA0M8QosoAc3Xp21RslBgChFXdHfbREHtUT8UtIVvwon-GWMXqvZBYRgpCDgcUrd8JtatGD2NJGvPslXTUU
y3m5kpcIdPhUZVmG6agyuSLEm-Jn7XbZHduYAP1JeasrDtut0EKt66Swa5eavUwQZvYDQhNAcuGJXz52z1qrM8cn0EODehSGC9TEC64QDJ33uikQegZgnfxQqO_YXqzcI02km3Es_6VLh1_8W55CSIL9AMjB7cFkNhnlViev5EC7Dg
y3ma1a2vKlwK-Dfq6emYbXu_QJ_476pyYfTMd5Qq57fX2SRTcm7Jl0ubInk_lnQY6NVs3CgvZm7-G_rkmMJKQAPhHD6PxrMob1JMXSKKsClr2X3QUUS1U4ACC0XflYGEzfgXfdGy86rNpCk9xoPNiudlAzKSAPsqRO7gECpm1GjKpE
So i've done around 80% of my Build i think.
Have to make some other things aswell.
So long
greez Benny
Hey folks,
long time no see.
sorry for that.
But here i am back again with the final pics.
I made a mount for my Harddrives.
y3m0nWnJGrvd5EB5mSeUrV0WBUsx_A5XFD2SN82aak7n3iQ9KymPipaFi7R9RkJYP6D3g6QKhJXOkOWHCHrhrYvPj0ETwzHH05RwPA3InUn6DIoSVs7xvdVQVm568xfB8CD26k8HnEcD3s9ywsWQ70Wje4AETddTZwMR4VOcfkn8Ho
y3mFMm2Ob5S1yVYyTIG86BrXWj7NiqFoW-tsylQxcg3If-f9ZhJuQ6rOAi7RmRwuaMU2P-bJ_xlHLj2x7mYRdLXeQqtQqsW_Czd2l4NgGDoykLKUBoTQo5X3ZRwlCGdvOQyqf6hoX99EB_v6zb7nRAA2gGmW4BBITermPKzIqRifpI
y3mKTCipW6fFDFS0b16L-DW-aWY5q_47XonzemnMoned0TA1UZlNfr89v1PIev7CGbh3g80-sm6a0yEEJ8AaW6iyyqj7eEovmN2FsY2u21xO61uHq57ppiHHosz2_6g4Y5UYfyTdEKGPoNL48UG-DMKf9IZ9p962Anh5YzJwBz1HQk
And i cutted the holes in the backcover.
y3mdKVKBVfs9MKuTrZDKz23tzuNsc4oxhJcyW6fxMoDAJV2Wn_IMX84RbImjUV78r4tiqQd2uUah2Pk8ANcjujfUUZJQHD_vnUW1eCxxzo6uNUMyoKa0e7aHlwuL_PEXMRyWxh1ENer84NjWDnKcKF6i77SvBZhjvExahdfGbxpLME
y3mqHQq_PJ6ZxsjB5nEq9dfUskwoZW9DHqL66IvjhyvnrF9TBmiANaDglQKTViZFtB_9fjKXK8Tm5zXUh_m39a787eEn8BNqK78nnsoUqO2flkKUEokZJOpaf-1-VEDYhEArjWRYhiD84L7UDpAOpJIVZt7NHhaOrDE-ReAgh1dC8M
y3meViDJgCVFjePVtboNcle_CfCIIGdmxx5yqugHVZVTUxfEId5k8dCHC27qL96dWyMzPHgEIXEAy2rMUYW51cVGmT1spqIhKwH89Zj5c8xE5cDBTve6crR7sOe4DYFHRrtFsoyBwcoaMQonuBH-fnNR8IepNMACN-s0uqnO2hmbbE
Here it is placed on my table.
y3myW2Vh3RzqPxTee9Ens9NyRX9thKk9bjzshizHNy69Bzp9kz_QOe2UvmKCbJQgV9PZxUiYmT0VNn8MCW0M7ZwZKauhMmpTC34Hg3opa40qfHr84i5cVG9lnSefydMCm0pJiU0_9f8nmuj2mSUhs-QDBhz4TupjWdumhGC2xqk6ck
y3mv9UeueLGXUuvNNAa8LugPD1omGU2uX8lEp96QQvR46o_50zmjiQ5-mLU9D1XjklEPlkw-X5cqf5J-p-I5eETTrT1KLNI97hiu2jINxHg7Im9GfDD4NXgBc6vCfZHNIa7DOQbBcmL7pt-tFkF0YyoCPjTi8JwlMcjnSmyp7PerMo
y3mN-16jNmjd-nJiCKS1TxcbUXdj-mb1mN5beqNjPHLk1SGN-yke-1awaDoIsA4txj5fwm_Z2zZ6oLYshdMLFf7BzzY0fUUpBnB6Nwwn9xYr-aNo72jtTrxGX1L-uf35opjQ0PZfsOuOuQ2XnmtpUFqkC4f4ewB9mffSV7xfhFMEBI
y3mRL5hJ96w4pVl5Shdx5NEA2Q6oga-0yN_4NOgj4ivIXp43DrxiWmpm71x3hvDF2ELvRCeRBcVR7CE5UmZpwdXm7E_3BWHN7TEB_46h6kumQUJXpexmv0dcua-iZNodQWZtYyH-pC7kQQMHjv0yzm2YuCmPQRqTfXSV3LgWqbVLFU
y3m1M8kwi6nlAQTOJH_kbnHgKr7K5eGn1LN2X6Hl-yd3VVZx-CMY14ZnL0oQLPwircLLTv9wIqpYgNfDhk5jt-gIYmAR79ygUu8y6115u4Zk0-UprET5c8XcfJBM-jIO5tEeZTZLEt-BUHipnMvf3_QTxh32UK4zpq-3UthousgzYg
y3mAknSXjt52Rb81F-tUgcY9lLpGKF1m4znebxQ_JbnUtmE37kPz7rGR0-5Oba3oe1d4b6I-We1VN_kvHK5Bam3ToH-hgfhcNWkWxHL9hf9lGw2qXct1qbuao2u-cfVYSjwkY0vQ7GVHxPhD8O9dP5RplYXE1ELcsWf4WVTd66uH7U
y3mDm4dMFt2zWdC8Xjx8FAO8phXfNxb01LGMy-U1BX-gjR8L2sYypmld138_agV8qBAFQWF_KpuAw4EkvWH4PfDjvshgLYEQlIa6hiKSu9HNsQmJdlDksnnKwPI6cvoPr7zd8WE7_HsLuZk_0SA33Q4SWZThEzOFJl4lns4YEiydrQ
y3ms3-TqOw5-0nVW6S12HIqWYZeIJMzvKauY0vrBnfw3iOZTQm7tdkRg7DsdBQP6PgnMaDDo5ntOAYNfW1OnbFKkjXl87HpJb15TEqouMAoZOEif8Q1RqFb99OnknrCijym9YPSYf70wS2NgidEXZ_TkB2Dw5hJQuJ-oHJCWPl7T4w
y3mi-lzxO9z2aLIneOMw6EQtylxzik2SpPueOa17uKFN1ipiQYBGl0f8Q5w9_8uoSLNjmo_oTbBzyAnOHdXkK7C9zCKa3muCo6CBm9DNH2Tqt9O1hE7X0DldPfY9nClGDghswQZw6W7eonu7qmK4y4JXhM0BrvShDyM_n2ZePNSE9o
y3mLRAZbvk2GUIG6L1cKuACcja7-qFi-CnsUN60qaeNHva0uXViJIjs117U3NFDbt9Cw-LKNpqJ6dy11NdMD6QbAL3cStRFbkOflvK-izNXZ6UZPO6ID28lbBvy7177fV5C0QDHrUZGf3amIOyEnCXMiF8SUCFyGZiYNdpY4Gait3s
y3mgu6ZKHi2FJqJK3K5HaD3hzBPf_P01Izz5LLktRSWtn2Fc_vZ4KdovV1FmV0lF-gmnWWSlpauBeMS7sGieXFHJ7ZtJodpFr-EX19jAlhR8ZTprib-qv2UrGcYTnsNLnm-Ysq46e5YUM6EPVO8v2Ojq73B8VP1vzR5VrF8aJQ5iZM
y3m4ELMi-wfnCm7F3h0ZX0kJwuNyHLLrS8F8tHJZJD7V0fvQF7DWSmrqSQC6r0YOMdfExpgCUbOgmu370-y0n4OuNa4RN0kHfEHEO4pIBj7sYq-7oMf-UFrZx41NOeN2WrpJPvd3iCV1auVRSObrQqqIMytbsAmFb6OG4dSW5hk1gA
y3mHHbWFGy2UaM72LeXEfnN66OBs_tb-UiCKsn8J2L0Bw4Qcv3rkwpQv1kGUHYUTzmspTNVTGvDA4pPdVM1r8FdEgIOraSxQKAlOlh3rOenu90FTfXuHbiL9Lc-9fJTI5tMg-G3cMjzGTuItDShEqY-hqnVaukqzMmC2Ogu2mcpGzo
y3mibtpPfZCrp0hICHRi9n5y8g1aC2d0UUzu9JAsAFUWPXMfXscgM-FeY9oAyWr2FaqeXIrM6a6-OBkYM-zCmvuUIkwv-N-8E6tIjDBQIQCwLLL1hRwwclobraaHA5ydGeEjLaX9dSVUStTwn_w_BAWuqVWdl7vz2BzOmcF_-ZLJFA
y3mNN6QhAJS0slyc3CiCbS5Z6GNmFYBD6qKzSFUMiarBEFruj0PqsaIrygOIE2kxsm72azdcPVM0WAhJpS5E6mU4NsoBDHuGuUX4xy5t2hfXgF6GddWpuAS8f_QPrp4KQOQzyGQEfED_wehCwUbzYG728QkQrJTVafL0qxFRe1Msys
y3muTi0fNJ1ByKPHJMhluOTqwFUu3fMDAnarOvTZ8OLLxYNIkr4I22fVkT0oMB4JGaJByZq2aWEYzbBn29Eu4eM7VI3r_1d-UQWkGF2LLtVcUF0TToBHFB1kgCnKexzO7z5SgsD3lJjPJCdpKPriPEJ6vvLpCQnvPOwK1XoX7FtGko
y3mvuFf1tSSIu1dtICE7SyE7dfgb25Tk3dbH1nHqAV0_JQbLeY4Q_x8OnS2ZyRfg9QVyLYGRzPXZYvUh33U2vy3J1GR0smbq-6fCJWMAeeSikVA1OCz7xZNP3pDjo3IID7SRKMUcZej8dhr9ezvRBC0NlCU_GwjFTS2KEGcjkmSLP8
y3mScgSO9Im6MIgKxi4WsmIgRvb1v1zxVLYKbnlNjmvU0ibU-AqmfBmNYD8nQdx74ngDzejRIRfTJyf6XsbV7dYPfTIV8dX9zRV8K8ukQfZM9mALVo6Lnn4CGqxznFJd30EzoSAGspk2KPxYPCpJnUYWCeGNVDXjFZOtJhomqs4Lls
y3m1XHXWg6Ushimmy0SiBuWwciJPCIkzNGo9hf8wtXBdYuJUsOm0c--MZtwdv-RUQnQh3LBy6wuT7nqCPAtOa1CV6ETMydqoRB5hmQ8FURagsWulKRng8uOaGM7H4FJgE-u_K1SU2WjCFs2dylNVRQqbD0xFA6TCucc4olpJlpyoCg
y3m6VOsIVEPn_zB52JcK1fEEXh4--S_02693hde2EHhPpMEJYBwCjvW0Mwq7v6TYQqZ96NXm6AZ05APosHLKm73Y6DoRecq6H2fm23JrXTUdsbfQRC4DYRcRkBTeq2M0xF3tFWeYumTFpQ9XdqmDD5jb2kfhfpthWY_lMVQCO3Pvus
y3m1RG7BxydApM66HNY_4qKs3KPOCE9K6Gn0-SjTMVlAxf15LTbvEp3aTG3kMgvVM4SNeLVNz0IGE9a6GBK5FkhwUABSKUYnBTky7GBL_I_gPDccd3E3qWwXyGH8Dxu38jpGwTp-jSzqYAzZQABdZxtoz0OUtY5bAB-tjG8emaG-yc
y3mLh-3J1nAmwZ-FhClKLxZEFtYEcot9QI6UPbk_jmEb2Uzxtka46KaNHvzKlOIofL3W6wu6JK6Kf-pXUQaNEpTVGFj-vUNXjxuTr-m-mk1p6bdf59t63DK3Y4rqgJrtZgozhPDGS-lcjs38w5Fc5wKu1hj8l6579CP1JIXDxFWhpY
y3mFfMz6yVeLQebM3lS7IVKNXl2N9FFyr6T8n-fsb7HFKJ6kAsRL_n8cVeAF8C5X2mXNed-QVN-BhX8uxoaE4xm6uzSPFPoB_AVblXbmr0En9PXN0OzPer5nO6KQWjWMU-qjcLwOeOOrwexPj9ZuprnB43xj7fsSrPSOOUy157UN_I
y3mXwFslepAB1PYajcUa9LPJvlD57X6mduHMbrfprLeWHAHZYGBCXN84IYr2UPmz3FkOUWFLF7MSugofRUFgfHuZz1yW_-C6VE1qaKBcxy5fEjRNwI1n56AY99nGVofUvzwiLtcb7zxVdZykIiLuyuzCukfBRGtP5gEAB5StydBBc0
y3mst8bQyQzQgpXYjhROcu-9-kse0F0uzvlrwy6S6ENFvgp4zNEV94Yje5Zvd-PLNcdyD5jqEE6miZU3TWQ75dUh0eMccVDXS_EtP4GA-WBEDpGxMvuMP_avOQrNUcJwej-HTXBSuGppcnO6i7GgNcGTYDpQFfcFvc4A0p9R5m-3pE
I hope u like it, and liked it to follow my progress =)
Have a nice evening guys.
Benny
