Screen water damage
14 (0.01/day)
System Name hog
Motherboard aSus Prime A520m-K
Cooling Stock AMD
Memory 2x8GB DDR4 3200MHz
Video Card(s) Vega 8 (Will upgrade soon)
Storage 500GB SSD
Display(s) Philips 272E1ca
Case MasterBox Q300L
Mouse CoolerMaster MasterKeys Lite Combo
Keyboard CoolerMaster MasterKeys Lite Combo
Laptop that has had water damage got a weird stripe(depends on white or black by the angle you look at it), some condensation underneath the screen, but the screen is working flawlessly except for those 2 problems, any help would be appreciated for how to maybe solve this
1,888 (0.73/day)
Arizona
System Name Space Heater MKIV
Processor AMD Ryzen 7 5800X
Case Phanteks Enthoo Pro M
Mouse Logitech MX Master 3
Keyboard Glorious GMMK 2 96%
Laptop that has had water damage got a weird stripe(depends on white or black by the angle you look at it), some condensation underneath the screen, but the screen is working flawlessly except for those 2 problems, any help would be appreciated for how to maybe solve thisView attachment 324650
What kind of laptop is it?
Sometimes, screen replacements are possible.
14 (0.01/day)
System Name hog
Cooling Stock AMD
Storage 500GB SSD
1,888 (0.73/day)
Arizona
Alright, you can use a tool like AIDA64 to check what display your laptop has. The trial version works.
Shown here is my HP Stream 11. Go to the display dropdown and go to monitor. Note the monitor ID.
Then, go to a site like Panelook.com and search for it.
Panelook will also show similar displays of the same size and interface but do your research before trying a different screen.
Given the fact that your laptop is newer, it most likely has an eDP connector. Verify the connector and specs; then it's as simple as checking eBay or another similar site.
13,942 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Unless it was highly filtered water, it is unlikely you can get rid it because that "stain" is likely caused by dust and other contaminates the water left behind.
The problem is, LCD screens consist of multiple layers bonded together and typically cannot be separated without causing further damage. The way I see it, you have two choices, learn to live with it, or replace the screen.
If you primarily use the computer at the same desk all the time, you could get an external monitor and just use that.
431 (0.11/day)
System Name Blackbelt 2
Processor AMD FX 8350
Motherboard ASUS M5A99FX PRO R 2.0
Cooling Cooler Master Hyper TX3 evo
Memory 8GB Corsair Value Select DDR3
Video Card(s) ASUS R7260X DC2OC 2GB
Storage INTEL 530 series SSD 120 GB, Seagate Barracuda 1 TB 7200 RPM
Display(s) DELL ST 2240L
Case Cooler Master Elite 311
Power Supply CORSAIR VS Series 550W
Software Windows 7 Ultimate 64 Bit
Benchmark Scores 3DMark 11 6532
Have you tried using a hairdryer at low heat setting?.....
I had fixed this with a hairdryer at low heat setting over a period of several days......i blew hot air over the spots for about 30 min over a period of 1 week.....
