Secondary SSD on 100% usage when opening any aplication on it
Jerry_X_Gamer
5 (0.00/day)
Hey.
So i've had a problem when my secondary drive (ssd) gets to 100% usage everytime i try to do something on i. (opening a program, copy a file onto it...) When i removed it from my system the same problem transfered to one of my hard drives.
My Configuration:
Ryzen 7 1700x
Gigabyte Aorus B450 elite
16gb hyperx ram 2667mhz
500w BeQuiet system power 9 psu
Msi Rx 570 gpu
DISCS:
Gigabyte 1tb nvme m.2 ssd (primary, with windows on it)
Wd Green HDD 1tb
Wd Green HDD 1tb (problem transfered to this hdd cca 2 weeks after i removed my ssd from the system)
Wd Green SSD 240gb (has a problem)
I've tried many different possible fixes but none of them have worked. I had all of my discs separately checked by local pc repair company and they said they are all working fine. I've tried changing the cables (sata data & sata power),
i've changed my motherboard from asrock x370 pro4 to gigabyte b450 aorus elite (i thought that sata controller on my old mobo was broken), and clean installed windows, but nothing changed. Softwarewise i checked what process is eating up my ssd and found something from windows defender, so i turned it off but it didn't work. I am yet to disable superfetch and prefetch, but when i did it with my old mobo it didn't work either.
Do you have any idea what else could i do to fix this problem?
ixi
1,486 (0.38/day)
Where do you see the 100% usage? If in task manager then don't believe it. When the 100% usage occurs does it lag or you have noticed low speeds on ssd?
Jerry_X_Gamer
5 (0.00/day)
I see this 100% usage in task manager, yes. and it does lag quite a bit. it reports crazy response times like 19000ms and beyond. And while this occurs i'm not able to open any program or access any other file on the disc
ixi
1,486 (0.38/day)
When task manager says it is used 100% what read or write speeds does it show? When it happens again open hd tune and run bechmark test and post picture here.
bug
14,343 (3.95/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
Use resource manager, that'll give you more detailed information about what's using your disk.
Jerry_X_Gamer
5 (0.00/day)
up to now, (in task manager) it showed read and write speeds of 0.0mb/s, i'll check it again with Hd tune tho.
2,673 (1.57/day)
Bulgaria
PCIe number of lanes in b450 MB's is limited to 6+20 from CPU (16 for graphic+4 shared between m.2 and SATA. Your case for graphic card used x16, for m.2 SSD x4, for network x1, for USB also(don't know how) for sound not sure and for 3 SATA devices also used PCIe. Maybe not enough lanes left when trying to use m.2(primary disc with windows I suppose) and 240gb SATA SSD...
Jerry_X_Gamer
5 (0.00/day)
So if I understand correctly my processor is probably lacking chipset pci lanes and can't simultaneously handle 3 sata devices + network cards etc on the mobo? But i'm curious why would the problem reoccur with my hdd once i removed my ssd from the PC and so there were only 2 sata devices left....
2,673 (1.57/day)
Bulgaria
I also wonder, so my comment is rather in a partially questionable form.
ixi
1,486 (0.38/day)
I don't believe that it is the case. I had z170 mobo with 6700k for 5 years. 1080 ti, one m.2, two hdd and never ever I have had this type of problem. I can add in in the loop that I had as well asus xonar essence sxt audio card as well :).
Gladly for me and sadly for you I have not had this kind of issue ever. What speeds could you get from hd tune when windows is showing 100 usage?
1,340 (0.35/day)
Nowy Warsaw
System Name SYBARIS
Processor AMD Ryzen 5 3600
Motherboard MSI Arsenal Gaming B450 Tomahawk
Cooling Cryorig H7 Quad Lumi
Memory Team T-Force Delta RGB 2x8GB 3200CL16
Video Card(s) Colorful GeForce RTX 2060 6GV2
Storage Crucial MX500 500GB | WD Black WD1003FZEX 1TB | Seagate ST1000LM024 1TB | WD My Passport Slim 1TB
Display(s) AOC 24G2 24" 144hz IPS
Case Montech Air ARGB
Audio Device(s) Massdrop + Sennheiser PC37X | Koss KSC75
Power Supply Corsair CX650-F
Mouse Razer Viper Mini | Cooler Master MM711 | Logitech G102 | Logitech G402
Keyboard Drop + The Lord of the Rings Dwarvish
Software Tiny11 Windows 11 Education 24H2 x64
I would've said requiescat in pace but I don’t think death is transferable. So I'll hold my judgement.
As for anecdotal experience, same thing happened to my hard disk when it started to die. Read was fine with crazy amount of latency but couldn’t write anything. I quickly copied all the important files while they were still readable. A week later hard disk became non-detectable.
Jerry_X_Gamer
5 (0.00/day)
yea, that once happened to me but after removing the hard drive and putting it back in after about 2 weeks it was recognisable again, but still with 100% usage
185 (0.11/day)
System Name heat
Processor 2990wx
Motherboard MSI X399 SLI PLUS ATX
Cooling Thermaltake Floe Riing RGB 360 TT Premium Edition 42.34 CFM Liquid CPU Cooler
Memory 128gb
Video Card(s) 2 2080s
Storage 100 tb
Case Asus TUF Gaming GT501 ATX Mid Tower Case
Power Supply 1200 cosair plat
i had over 6 hdd do what you just said before they died....
