CAPSLOCKSTUCK
Spaced Out Lunar Tick
- Feb 26, 2013
- 8,578 (1.90/day)
- llaregguB...WALES
System Name | Party On |
Processor | Xeon w 3520 |
Motherboard | DFI Lanparty |
Cooling | Big tower thing |
Memory | 6 gb Ballistix Tracer |
Video Card(s) | HD 7970 |
Case | a plank of wood |
Audio Device(s) | seperate amp and 6 big speakers |
Power Supply | Corsair |
Mouse | cheap |
Keyboard | under going restoration |
The innovative material has been made by engineers at the King Abdulla University of Science and Technology (KAUST), in Saudi Arabia.
https://www.kaust.edu.sa/en
It consists of a polymer layer that rapidly expands when heated above 80°C (176°F), causing the device to burst open from the inside.
The mechanism could be adapted to be triggered in a range of ways, including remotely through an app.
Once triggered, the device's battery channels power to electrodes that rapidly heat, causing the polymer to expand to seven times its original size.
This crushes the inner components of the device.
Speaking to IEEE Spectrum, Muhammad Hussain, an engineer who worked on the polymer, said: 'The expandable polymer expands much more and causes sufficient tension in the thin silicon — which is sitting on top of the polymer — so it simply crumples and then breaks.'
The invention could be used as a cost-effective way to destroy devices if they are compromised. The polymer is very cheap to make, and could be fitted into devices for just £12 ($15).
