- Feb 20, 2008
- 4,628 (0.74/day)
- where everyone wants to be
System Name | Everchanging |
Processor | AMD Ryzen 9 5900X |
Motherboard | ASUS ROG Crosshair Dark Hero |
Cooling | Arctic Cooling Liquid Freezer 2 420mm |
Memory | 2x16GB Corsair DDR4 3600 CL16 |
Video Card(s) | eVGA RTX 3090 Ti FTW3 |
Storage | Samsung 980 Pro 256GB, Samsung 980 Pro 2TB |
Display(s) | 2xSamsung 28" 4k HDR 144Hz |
Case | Fractal Meshify 2 XL |
Audio Device(s) | fiio K9 to Hifiman Sundara's via 4.4mm balanced cable |
Power Supply | Seasonic Prime TX 850w |
Mouse | Corsair Harpoon Wireless RGB |
Keyboard | Corsair K70 RGB PRO |
Software | Windows 11 x64 |
So I have an FTP setup on my main rig to transfer files between that and my laptop, and had a couple questions about settings. First of there is a setting for TCP/IP Buffer setting that allows me to allocate xxxxMB to the receive and send buffers, and in program can change the priority from normal, to high, to realtime, to idle. Default buffer size is 4MB, and increases/decreases by 512KB, default priority is normal. How would increasing or decreasing the size of the buffer and possibly changing the priority of the program improve the overall speeds of my transfers, which will be files of all sizes, from MP3's to large video files(8GB+). The largest MP3 I have seen go was about 17MB, and took 4 seconds. Both the laptop and PC are wired to one router with 100MB LAN, (could do a long wire down to my router with GB LAN, but would take away net for a roomie).
I prefer this rather than networking since no matter how hard I tried with 3 Windows 7 based PCs/Laptops on one router, I couldn't get anything to work, and I access my files out side of my house.
Thanks in advance for the help.
