Hi, i'm a very unfortunate owner of an HP-15f series; with a I7-1255U 12thgen CPU.
I use it for work so a lot of multitasking and videocalls
I've been going through a lot of problems with performance, that after changing thermalpaste, removing battery, changing chargers, and praying to the old gods; I arrived at the following conclusion (which might be wrong but it really looks like it)
Power boost is enabled => Temp runs high (over 60,65) => Throttling is enabled
and when throttling comes around, pc almost dies. calls are inaudible, the pc lags.
I've been tinkering with XTU and managed to avoid this at great length, but it kinda "loses" settings. I've found this app but I'm not an expert by any means; so I need advice on:
Which settings can i set, that avoids powerboosting, or thermal throttling at all costs?
I beleive i can work with the cpu "standard" specs, or I would rather have it running all time at 80% its capacity than going through 5 seconds at 120% and then 2 minutes at 30%
sorry if too long or repeated.
