Shader Clock 0MHZ
Chuck79
3 (0.05/day)
Asus Z690-A
i7-12700
4060ti
32GB RAM
2TB SSD
Hey! New here. My 4060ti started running 0MHz on the Shader Clock.
Core and Memory Clocks are normal and games run fine, but look poorly.
I have tried all the standard fixes, including using DDU to clean and reinstall
drivers. My next step I'm thinking is to flash the Video BIOS on the card.
But the version I have installed does not match any version I can find.
Installed Video BIOS version: 95.06.26.00.7A
Version listed here for my card: 95.06.1A.00.4B
I just don't want to brick the card flashing the wrong BIOS
Thanks!
3x0
1,016 (1.09/day)
Processor AMD Ryzen 7 5800X3D
Motherboard MSI MPG B550I Gaming Edge Wi-Fi ITX
Cooling Scythe Fuma 2 rev. B Noctua NF-A12x25 Edition
Memory 2x16GiB G.Skill TridentZ DDR4 3200Mb/s CL14 F4-3200C14D-32GTZKW
Video Card(s) PowerColor Radeon RX7800 XT Hellhound 16GiB Noctua NF-A12x25 Edition
Storage Western Digital Black SN850 WDS100T1X0E-00AFY0 1TiB, Western Digital Blue 3D WDS200T2B0A 2TiB
Display(s) Dell G2724D 27" IPS 1440P 165Hz, ASUS VG259QM 25” IPS 1080P 240Hz
Case Cooler Master NR200P ITX
Audio Device(s) Altec Lansing 220, HyperX Cloud II
Power Supply Corsair SF750 Platinum 750W SFX
Mouse Endgame Gear OP1 8K
Keyboard HyperX Alloy Origins Aqua
Which version of GPUz are you running? Post a screenshot.
This is very confusing, there are no separate Core and Shader clocks for the 4060Ti, only Core/GPU clocks.
Chuck79
3 (0.05/day)
GPUz doesn't show a shader clock...... I was looking at OpenHardwareMonitor. But it sounds like I'm chasing the wrong problem. SO it should be reading 0MHz?
Solaris17
Super Dainty Moderator
27,605 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Video Card(s) MSI SUPRIM Liquid 5090
Audio Device(s) Moondrop S8's on chitt Gunnr
Keyboard Wooting 80 HE White, Gateron Jades
VR HMD Quest 3
Im not aware of anything being able to poll shader clock for nvidia for like decades. I cant even remember the last series that let you. 88xx's? maybe 9xxx's? Shit maybe even earlier 7xxx 6xxx.
Chuck79
3 (0.05/day)
I just went through both nVidia and ASUS support and neither of them bothered to mention this when I told them that my Shader Clock wasn't running lol. nVidia sent me new drivers and ASUS sent me an updated BIOS. What happed is that my graphics suddenly dropped off. I can't find any explanation. Games still run fine, frames are good, no stuttering. They just dont look right. iRacing for example I can not enable antialiasing above MSAA or Foilage. I can tick the boxes but they do nothing. It's just weird and I though I found the cause, but I guess not.
Ok, just so I can move on. The Shader Clock reading 0MHz is normal and I should look for my problem elsewhere?
Solaris17
27,605 (3.84/day)
Alabama
VR HMD Quest 3
yes
EDIT: looked it up btw. It was kepler so GTX 6xx
So they stopped in 2012. I was actually wrong; Shader clocks only existed between 8xxx and GTX 5xx. Prior to 8xxx and after GTX 5xx they were removed.
