Shadow of the Tomb Raider PC System Requirements Released
VSG
Editor, Reviews & News
3,725 (0.94/day)
Square Enix's upcoming game title, Shadow of the Tomb Raider, is due for public release on September 14, less than 11 days from the time of this news post, and has grabbed attention already thanks to that being the first game to be out that also promises support for NVIDIA's RTX real-time ray tracing. Based on preliminary tests, this appears to have even the upcoming GeForce RTX 2080 Ti struggle to maintain a solid 60 FPS even at 1080p so time will tell how the rest of the game fares on hardware both old and new.
In the meantime, we look forward to seeing the third of the rebooted Lara Croft series that has been received positively in general- including for a good PC port, as tested by TechPowerUp before. Shadow of the Tomb Raider is slated to run on a system with a dual core CPU, a GeForce GTX 1050/Radeon HD 7770 equivalent and takes up 40 GB of system storage. As for recommended settings, Square Enix via developer Eidos-Montreal suggests a quad core CPU (Intel Haswell and newer, or AMD Ryzen R5 1600 and newer) paired with an NVIDIA GTX 1060 or AMD Radeon RX 480. Interesting also to note here is the use of the 6 GB version of the GTX 1060, so it may be a case of the game needing a minimum of 4 GB VRAM at 1080p under their recommended settings. Let us know in the comments if you plan on picking up the game early, and also what system you are going to be running this with.
3,244 (1.16/day)
System Name Grunt
Processor Ryzen 5800x
Motherboard Gigabyte x570 Gaming X
Cooling Noctua NH-U12A
Memory Corsair LPX 3600 4x8GB
Video Card(s) Gigabyte 6800 XT (reference)
Storage Samsung 980 Pro 2TB
Display(s) Samsung CFG70, Samsung NU8000 TV
Case Corsair C70
Power Supply Corsair HX750
I suspect it'll kick my system's ass, like Mankind Divided (the other TR's run very well though).
79 (0.03/day)
System Name RED
Processor Intel Core i5 2500
Motherboard Gigabyte GA-B75M-HD3
Cooling Cooler Master Hyper 212 Evo
Memory 2x8GB 1600MHz DDR3 @1333 [Avexir]
Video Card(s) Gigabyte GeForce GTX 1060 3GB Windforce 2X OC
Storage 1*Samsung 840 Series SSD 250GB, 2*Seagate Barracuda 1TB HDDs
Display(s) LG W1934S
Case Aerocool X-Warrior Red Devil Edition
Audio Device(s) Realtek ALC887
Power Supply Seasonic M12II Evo 520W (80+ Bronze)
Mouse Cooler Master Devastator II Mouse
Keyboard Cooler Master Devastator II Keyboard
Once again, the specs that devs give are completely nonsensical. How can you suggest a GTX 660 "or" a GTX 1050 when the latter is almost as fast as a GTX 680.. And it's even worse if you mention the HD7770 as the 1050 trades blows with the HD7950.
4,378 (0.92/day)
St. Paul, MN
System Name Bay2- Lowerbay/ HP 3770/T3500-2+T3500-3+T3500-4/ Opti-Con/Orange/White/Grey
Processor i3 2120's/ i7 3770/ x5670's/ i5 2400/Ryzen 2700/Ryzen 2700/R7 3700x
Motherboard HP UltraSlim's/ HP mid size/ Dell T3500 workstation's/ Dell 390/B450 AorusM/B450 AorusM/B550 AorusM
Cooling All stock coolers/Grey has an H-60
Memory 2GB/ 4GB/ 12 GB 3 chan/ 4GB sammy/T-Force 16GB 3200/XPG 16GB 3000/Ballistic 3600 16GB
Video Card(s) HD2000's/ HD 2000/ 1 MSI GT710,2x MSI R7 240's/ HD4000/ Red Dragon 580/Sapphire 580/Sapphire 580
Storage ?HDD's/ 500 GB-er's/ 500 GB/2.5 Samsung 500GB HDD+WD Black 1TB/ WD Black 500GB M.2/Corsair MP600 M.2
Display(s) 1920x1080/ ViewSonic VX24568 between the rest/1080p TV-Grey
Case HP 8200 UltraSlim's/ HP 8200 mid tower/Dell T3500's/ Dell 390/SilverStone Kublai KL06/NZXT H510 W x2
Audio Device(s) Sonic Master/ onboard's/ Beeper's!
Power Supply 19.5 volt bricks/ Dell PSU/ 525W sumptin/ same/Seasonic 750 80+Gold/EVGA 500 80+/Antec 650 80+Gold
Mouse cheap GigaWire930, CMStorm Havoc + Logitech M510 wireless/iGear usb x2/MX 900 wireless kit 4 Grey
Keyboard Dynex, 2 no name, SYX and a Logitech. All full sized and USB. MX900 kit for Grey
Software Mint 18 Sylvia/ Opti-Con Mint KDE/ T3500's on Kubuntu/HP 3770 is Win 10/Win 10 Pro/Win 10 Pro/Win10
Benchmark Scores World Community Grid is my benchmark!!
What was your point? Pointing out deficiencies in the System Requirements?
"it's even worse if you mention..." Really?
You seem pretty knowledgeable, use it for good.
;) :toast:
2,002 (0.55/day)
Seattle, WA
;):toast:
Because the GPUs they have specified for the minimum requirement are practically on opposite ends of the performance spectrum. The Radeon HD 7770 and the GTX 1050 are so far apart in performance it's not even funny, so why would a game with a minimum requirement of a GTX 1050 also run on a HD 7770? That makes very little sense.
11,880 (2.15/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
Because a game made for consoles isn't going to run bad on low end amd GPUs is it? but the 1050 is what's required in Nvidias older(now older not older then the 7770) now less optimised tech.
It does seam an extreme difference maybe async computes involved.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
They usually list cards based on what was tested by their QA department.
4,378 (0.92/day)
St. Paul, MN
So, again. @ExV6k @Fouquin The point? As @FordGT90Concept and what @theoneandonlymrk , was trying to say, is this:
The game developers, producers and probably paid people, run the games and that is how they get their recommendations.
So, what seems senseless to you, is not. So, your point is to point out your opinion of what they do for a living is senseless.
My point is, use your knowledge for good. Use it to help, not denigrate people for NO reason.
That, is the very definition of senseless.
Thank You and Goodnight.
:mike-drop:
2,002 (0.55/day)
Seattle, WA
This is a very anticipated title that has two very well known developers attached to it. Their QA department(s) should have access to hardware that is not over half a decade old for their qualification testing, as evidenced by the inclusion of the GTX 1050, GTX 1060, and RX 480 in their requirements lists. The Radeon HD 7770 appears to be a carry-over from the previous title's minimum requirement despite the minimum nVidia suggestion being upgraded substantially.
I thought I was fairly clear on my point.
The GTX 1050 is roughly twice as fast as a Radeon HD 7770. This is pretty well known. If the absolute bare minimum system requirements to run this game calls for a GTX 1050, than why would the suggested equivalent from AMD be half as fast and 4 years older? The senselessness of the recommendation lies in the extreme performance difference between the two GPUs suggested. Even if we exclude the GTX 1050 and refer back to the GTX 660, that card too is 1.7x faster than a 7770. Why would they not instead suggest a more modern, and much more equivalent, RX 560?
I'm curious as to how questioning a discrepancy in the minimum requirements list of a video game in any way constitutes a direct attack on the people in employment of Square Enix, Crystal Dynamics, or Eidos Montreal. ExV6K in particular did question the devs because it was stated in the article that Eidos Montreal were the ones who supplied the system requirements for publication. They did not directly attack anyone employed there, nor their choice of employment. I don't know what things you see when you're reading between the lines, but I assure you with great sincerity that they are NOT being said, indirectly or otherwise.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
:confused: They still list the 660 yeah? They just added the 1050 to their minimum testing because it's a common card. They maybe should have added a newer AMD card too for fairness but...top 3 cards are GTX 1060, GTX 1050 Ti, and GTX 1050. Minimum testing the GTX 1050 covers a lot of bases. HD 7770, being GCN based and GCN not changing a whole lot since then, they likely didn't feel they needed to test anything newer.
11,880 (2.15/day)
Manchester uk
VR HMD Oculus rift
Fine wine:)
266 (0.10/day)
Processor Intel core i5 4590s
Motherboard Asus Z97 Pro Gamer
Cooling Evercool EC115A 915SP Cpu cooler,Coolermaster [200mm (front and top)+140mm rear]
Memory Corsair 16GB(4x4) ddr3 CMZ16GX3M4X1600C9(Ver8.16)(XMP)
Video Card(s) MSI GTX 970 GAMING 4G
Storage Western Digital WDC WD2001FAS 2TB Black, Toshiba DT01ACA100 1TB
Display(s) LG Flatron L177WSB
Case Coolermaster CM Storm Enforcer
Audio Device(s) Creative A550 Speakers 5.1 channel
Power Supply SuperFlower Leadex 2 Gold 650W SF-650F14EG
Mouse PLNK M-740 Optical Mouse
Keyboard ibuypower GKB100 Gaming Keyboard
Software Windows 7 Sp1 64 bit
No I will not be getting it, the wounds of the lack of actual tomb raiding, the redundancy of abilities in skill options, the eternal colectathon, unchanged gameplay, unexplained erratic graphic performance and aggressive desexualisation of lara are still too fresh . Also still don't have a 10 series card so no max details on my 970 (will there be a performance review on tpu?) so there is that as well.
/rant over
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
For Rise of the Tomb Raider a GTX 650 2GB is what they suggested, that was upgraded to a GTX 660 for this title.
HD 7700 is more powerful than GTX 650 and they probably found out GTX 650 was unbearable with the new game; hence, jumping up to GTX 660.
3,244 (1.16/day)
System Name Grunt
Case Corsair C70
/rant over
I can't deny the issues, but I still somehow enjoy them. Barring it being seriously bugged, I'll probably buy it :D
4,378 (0.92/day)
St. Paul, MN
How about what I see, reading THE LINES.
2,002 (0.55/day)
Seattle, WA
You are interpreting malice against other human beings from words that express no such thing. None of the words said are personal attacks, and any interpretation suggesting they are is a fit of mental gymnastics, nothing more.
Senseless - lacking common sense, wildly foolish
The usage of the word is in context of the article's subject. In a report of computer system requirements, where involved parties would have prior knowledge of computer hardware and their capabilities, it would seem senseless to offer two options as equivalents when they are, in fact, not so.
If you have any further issue with my use of the word in relation to the report of system requirements and not the people, employees or otherwise, please feel free to PM me. This has dragged on long enough for one thread.
23,843 (6.15/day)
Its simple: market share. They list GPUs many people have so many people think they can run the game OK, and thus many people will buy it. Or people will see they have something faster than that from either an old or new gen and know they're safe too.
The point is to sell as many games to as many people as they can by not having specs that are a barrier to most potential buyers. That is also what games are optimized around - and even what GPU generations are aimed at. The common denominator. The 95%. It happens everywhere, even in clothing. 'One size fits all'.
