Shouldn't CS2 generate more fps than CS:GO?
299 (0.33/day)
CS:GO is an old game, DX9, it uses only 1 CPU core, it is not optimized to use advanced instructions of modern CPUs and GPUs...
CS2 is a recent game, DX11; theoretically, the developers had the chance to make it optimized to use various CPU cores and new instructions from the new CPUs and GPUs, but it is much heavier than CS:GO and generates practically half the fps that CS:GO generates with the same hardware.
I expected that even an Intel APU to do ~500 fps in CS2...
And why didn't they make CS2 on the Vulkan API to be even more optimized (to take better advantage of the processing power of the new CPUs and GPUs)?
3x0
1,016 (1.08/day)
Processor AMD Ryzen 7 5800X3D
Motherboard MSI MPG B550I Gaming Edge Wi-Fi ITX
Cooling Scythe Fuma 2 rev. B Noctua NF-A12x25 Edition
Memory 2x16GiB G.Skill TridentZ DDR4 3200Mb/s CL14 F4-3200C14D-32GTZKW
Video Card(s) PowerColor Radeon RX7800 XT Hellhound 16GiB Noctua NF-A12x25 Edition
Storage Western Digital Black SN850 WDS100T1X0E-00AFY0 1TiB, Western Digital Blue 3D WDS200T2B0A 2TiB
Display(s) Dell G2724D 27" IPS 1440P 165Hz, ASUS VG259QM 25” IPS 1080P 240Hz
Case Cooler Master NR200P ITX
Audio Device(s) Altec Lansing 220, HyperX Cloud II
Power Supply Corsair SF750 Platinum 750W SFX
Mouse Endgame Gear OP1 8K
Keyboard HyperX Alloy Origins Aqua
Does CS2 look the same as CS:GO? No
3,107 (2.01/day)
Germany
Processor AMD Ryzen 9 9950X3D
Motherboard ASRock B850M PRO-A
Cooling Corsair Nautilus 360 RS
Memory 2x32GB Kingston Fury Beast 6000 CL30
Video Card(s) PowerColor Hellhound RX 9070 XT
Storage 1TB Samsung 990 Pro, 2TB Samsung 990 Pro, 4TB Samsung 990 Pro
Display(s) LG 27GS95QE-B, MSI G272QPF E2
Case Lian Li DAN Case A3 Black Wood Edition
Power Supply Corsair RM1000X ATX 3.1
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Morgoth
Fueled by Sapphire
4,253 (0.66/day)
Netherlands
Motherboard aorus x570 pro
Cooling air (GPU Liquid graphene) rad outside case mounted 120mm 68mm thick
Storage 300gb hdd OS backup. Crucial 500gb ssd OS. 6tb raid 1 hdd. 1.8tb pci-e nytro warp drive LSI
Display(s) AOC display 1080p
Case SilverStone SST-CS380 V2
Mouse corsair gaming mouse
Keyboard Microsoft brand
if im correct since release of might and magic on the source engine the officaly started to support 2 threads
NQD44
1 (0.00/day)
csgo uses more threads i think, my fps increased a lot after I changed my e3-1241v3(4c8t) to e5-1650v3(6c12t)
1,832 (1.09/day)
Processor 5800X3D -30 CO
Motherboard MSI B550 Tomahawk
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
CS:GO is completely CPU bound and doesn't scale beyond four threads. It is still limited by a single thread, so CPUs with better ST performance will produce higher fps.
341 (0.54/day)
Source 2 engine can use DX11 or Vulkan (as seen in Dota 2). That being said, CSGO had multi-core optimizations (as you can see in the option menu in the game), it runs on multiple threads, at least 4. Source 2 or CS2 mainly has higher graphical fidelity and so needs way more performance for the same settings.
Regeneration
NGOHQ.COM
3,151 (0.44/day)
No. There is update of textures and the frame rate is likely to be chopped by half.
ir_cow
5,022 (0.83/day)
USA
CS2 is Source 2 engine. That comes with whatever optimizations HL Alex has.
