- Oct 9, 2007
- 46,393 (7.67/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Want to light up your performance-oriented but dull-looking SanAces? SilverStone may have the answer. The company rolled out the FG-122 and FG-142, ring-shaped fan-frames that you mount your fans through. The frames are lined with 24 RGB LEDs, which take input from a 4-pin RGB header. As you may have guessed from their model names, the FG-122 is designed for 120 mm fans, and the FG-142 for 140 mm. If you prefer not to pass bolts through the mount-holes, the frame also has an adhesive strip to latch onto your fan. The company didn't reveal pricing.
