[Case Gallery] Simple System
  • Thread starter Thread starter mrnagato
  • Start date Start date
M
mrnagato
Specs:
AMD Sempron 2800+ 2.0GHz 256KB L2 Cache Socket A processor, EPoX EP-8KRAIPRO Socket A (Socket 462) mobo, 1Gb Corsair Ram, WD 250Gb PATA, Hitachi Deskstar 500Gb, Asus DVD +- R/RW, Generic DVD drive(Fry's Special, ATi X800 256mb w/ ATI Silencer 4 cooler @ stock voltage, unknown case manufacturer, Enermax 450W PSU
Mods:
none, but soon to have Conroe inside and SLi!
Very clean!
Nice system there man that is a well rounded system that I would like to own. Again very clean! Everone says socket A is dead but I highly disagree. You should try to oc that sempy!
This is great, tidy and proud, not the wallet war im so used to seeing, Wish you all the luck with the future of this system,But dont be in a rush to spend...I like your work.
Socket A is dead! Smart thinking with the conroe. ;)
i like it, it looks really neat and well set out/organised inside...
id like to see something done to the front of the case, it looks a tad bland.
Decals/Sprayjob/Fan controller (if your thinking of buying anything more)
also does the grill in front open into the case (if you look from the outside at the grill can you see in?) if so maybe you should put a cold cathode in there? theyr relatively inexpensive.
Very nice m8, clean and simple :)
got the same case :D yours is cleaner looking though
