[Solved] Speaker volume goes up and down randomly
Status
Not open for further replies.
45 (0.01/day)
Greece
System Name Ryzen
Processor AMD RYZEN 5 3600 Six-Core Processor
Motherboard GIGABYTE B450 Aorus Pro
Cooling CoolerMaster MasterAir MA410P
Memory 2 x 8,00GB G Skill F4-3000C16S
Video Card(s) Sapphire RX 5700 pulse
Storage 512 GB Adata XPG Gammix S11 Pro (NVMe), 240 GB Intenso Sata III (SSD), 931 GB Western Digital (HDD)
Display(s) AOC G2590PX, Samsung Syncmaster 2233 RZ
Case Deepcool Matrexx 70
Power Supply Turbox 735W Power Series Modular
Mouse GENESIS NMG-0500 GX68 PROFESSIONAL LASER 3400DPI GAMING MOUSE
Keyboard Trust GXT 280
Basically, the problem I have is that my speakers volume increases and decreases by itself while the system volume (mixer) is unchanged. I am using Xonar DG Pci 5.1 but I am quite sure its not my sound cards problem because the same problem occured when I was using sound blaster VX 5.1 .Moreover, I have also changed my motherboard, so I believe the problem comes from the speakers. However, I gave my old motherboard and sound card to a friend, who has told me that he has the same problem (He didn't have it before). What could the problem be?
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
What speakers are you using? If it's like a 2.1 or greater system with a dedicated control module, the control module might be defective.
When it goes down, does it go all the way to 0 dB?
qubit
Overclocked quantum bit
17,865 (2.81/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Does this happen when you're watching YouTube videos? There's a bug in Flash/Windows causing this that's still not been fixed. Note that most YT videos are HTML5 now anyway.
45 (0.01/day)
Greece
System Name Ryzen
I have Creative Inspire T 6160.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
I have an idea: you could use a program like Audacity to record the "What U Hear" (or whatever it is called on your card) signal and then use that to determine if the change in volume is coming from the computer or not. You should be able to see it clear as day if it jumps.
Also, what's the context this occurs in? Does it happen, say, mid-song when listening to music?
45 (0.01/day)
Greece
System Name Ryzen
It happens whenever I listen to music or watch videos, be it from youtube or Windows media player. Most of the times it happens mid song/video. The volume change is noticeable, but not extreme.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Have you tried headphones or different speakers plugged into the card? If it is just the speakers doing it, it could be the amp in the speakers failing to produce the continuous power you're demanding from it. 50w is very weak (think integrated TV speakers + 20ish watts for the sub).
45 (0.01/day)
Greece
System Name Ryzen
It doesn't happen when I am using Headphones, so I guess there isn't enough power supply to the speakers. Will try to record using Audacity the problem and will report back.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
If it doesn't do it using headphones, it's not the computer (Audacity would just confirm that). It is definitely the speakers.
45 (0.01/day)
Greece
System Name Ryzen
Basically I tightened the gear and I should be good now. Thanks !
One last question: As said in the topic, my friend has the same problem, but when he pauses and then instantly plays the song, the volume is back to normal. Could it be a system error? I will do the trick with Audacity, but I want to have be ready for everything.
232 (0.06/day)
Dominican Republic
System Name Old but Gold
Processor A10-6800k : 4,700GHz@1.4v
Motherboard Asus F2A85 V-PRO
Cooling CoolerMaster Gemin 2 S524 with a modded crazy fan on it :D
Memory 8GB G.Skill RipJawZ @2400MHz Dual Channel; 10-12-12-31
Video Card(s) Clud3D R9 290 RoyalAce core@1077 mem@1350
Storage Dual 500GB Seagate Barracuda
Display(s) Asus VH198T Res 1440x900@75Hz, Aspect Ratio 16:10, 10000000:1 Contrast Ratio
Case Diablotek Predator
Audio Device(s) Onboard Realtek ALC892 Unlocked DTS and DD :) !!!
Power Supply Corsair CX750M
Keyboard Logitech Generic PS/2 Keyboard !
Software Win 10 Pro 64-Bit
Benchmark Scores 2,810 on Valley 1.0 Custom Preset: Ultra DX11 1080p 4xAA.
Go into your playback devices and right click your primary device and click on properties, check on the "enhancement" tab if you have loudness equalization turned on and turn it off. It might explain the sudden changes in volume in everything and the setting is applied only to an specify output device hence why your headphones are not affected.
Edit: Just read that you may have fixed it but it's worth to check if you have it enabled anyways :p.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
When paused, the capacitors have a chance to fill so it sounds normal on resume but when they deplete, there isn't enough power to drive the woofers.
If the problem doesn't exist when using different speakers, it's the speakers.
Edit: Like you discovered with your speakers, volume issues are usually the control module to blame.
About the only problem with things getting quiet that I know of is that Windows has a setting that can reduce the output volume on telephone activity. You can find it at: Sound -> Communications tab. Doubtful this is to blame.
  • Like
Reactions: xvi
45 (0.01/day)
Greece
System Name Ryzen
I asked my friend when it happens and he told me on Youtube, so I guess its the bug that qubit said above. Thanks again for helping me!
qubit
17,865 (2.81/day)
Quantum Well UK
Keyboard Yes
Yeah, that's the thing I was thinking of. Even when set to off it still tends to do it - and it's still infuriatingly random. I don't think it happens with HTML5 videos though. The sooner Flash disappears the better.
Glad it's sorted. :toast:
Status
