[SOLVED] Unstable Internet Connection/Unstable Online Gameplay
Status
Not open for further replies.
539 (0.14/day)
Swanmore, United Kingdom
System Name Joel's Rig
Processor Intel i7-6700K (4 Cores, 4GHz)
Motherboard MSI Z170A GAMING M5
Cooling 3x 140mm Case Fans, Cooler Master Hyper TX3 Evo
Memory Kingston HyperX Fury (DDR4, 2x 8GB, 2133MHz) 16GB
Video Card(s) MSI AMD Radeon R9 290X (8GB VRAM)
Storage Samsung 840 EVO 120GB SSD, Samsung 850 EVO 250GB SSD, WD 3TB HDD
Display(s) Samsung U28E590D (28-Inch, 4K, 60Hz)
Case Corsair Carbide 600C
Audio Device(s) Realtek HD (Integrated)
Power Supply Corsair RM750i (750W)
Mouse Roccat Tyon
Keyboard Razer Blackwidow Chroma
I've got an ongoing problem with my internet connection which is severely frustrating.
My speeds are good (ping of 39, download of 29mbps etc.), but I have a very unstable connection for some reason.
In general when browsing the web, from time-to-time some sites will refuse to load (saying "ERR_NAME_NOT_RESOLVED"), I also can't seem to play online games which is the biggest annoyance! Playing Rocket League, my ping will jump from around 35 anywhere up to 180...and even when I have ping around 50 or lower I'll get ridiculous lagging. On occasion the connection to the server will just time out completely.
The exact same goes for any online game on EA servers; Battlefront I get kicked out at the first sign of lag though.
I know this is my device and not our home network in general as I'm the only person experiencing this. I've checked that there are no IP conflicts on our network, changed to the Google DNS servers, released and renewed my ipconfig, reinstalled my wireless adpater's driver, disabled my firewall and forwarded many ports on the network.
This is so frustrating, I've paid a lot for some online games that I really enjoy and I can't play them!
I'm desperate for help guys :confused::lovetpu:
1,610 (0.34/day)
Northamptonshire, UK
System Name Main / HTPC
Processor Ryzen 7 7800X3D / Ryzen 7 2700
Motherboard Aorus B650M Elite AX/ B450i Aorus Pro Wifi
Cooling Thermalright Phantom Spirit 120 EVO / Wraith Spire
Memory Corsair Vengeance 2x16 6000MHz CL30 / HyperX Predator 2x8GB 3200MHz
Video Card(s) MSI RTX 4080 Super Gaming X Slim / ARC A380
Storage WD Black SN770 1TB / Sabrent Rocket 256GB
Display(s) Aorus FO32U2P / 39" Panasonic HDTV
Case Asus AP201 / Cougar QBX
Audio Device(s) Denon AVR-X2800H / Realtek ALC1220
Power Supply Corsair RM1000e / BeQuiet SFX Power 2 450W
Mouse Logitech G903
Keyboard Drop Sense75 with WQ Studio Morandi's
VR HMD Rift S
Software Win 11 Pro 64Bit
Who's you provider?
Wired or wireless?
Fiber or Landline?
Any VPN's installed?
Are you using the router that your provider gave you?
539 (0.14/day)
Mouse Roccat Tyon
Who's you provider?
Wired or wireless?
Fiber or Landline?
Provider: Plusnet (belonging to BT)
Type: Wireless (no network ports in my room)
Cable: fibre
No VPN's
Yep, using a Plusnet router which was a replacement of one of their older ones recently.
Thanks for the fast response :)
13,952 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Who's you provider?
Wired or wireless?
Note his opening post. His provider is not important since he states others on the network are working fine. And he states he reinstalled his "wireless" adapter's driver.
@marmiteonpizza - Can you move this computer close enough to connect via Ethernet to see if the problem is happening there too?
Did it ever work right?
NIC stands for network interface card - though most are integrated and not cards anymore. Your router's admin menu will let you change channels. I use XIRRUS WiFi Inspector to see what channels are in use and available.
3 replies in the same minute! Missed it by that much! ;)
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
Yea its your wireless. Hard wire it and see if it stops
What router and your PC wireless nic?
brandonwh64
19,542 (3.42/day)
Wireless and gaming don't mix well if there is other people in the house hold using their wireless devices at the same time or overlapping channels with neighbors or electrical devices causing interference. Best bet is to somehow figure out a way to get a hard line from the main router into your room.
539 (0.14/day)
Mouse Roccat Tyon
I can do, I'll move my PC to a room with a network port shortly.
Yep, the wireless connection has worked flawlessly in the past, albeit with numerous hiccups. This seems to be the most disruptive one however.
Sorry, what's a nic? :confused:
Is there any way to join a less populated channel?
By the way, I got the error message in Chrome in my original post wrong, it's actually: "ERR_NAME_NOT_RESOLVED".
12,340 (2.21/day)
Oregon
Network Interface Card
Brandon's right wireless basically sucks for gaming.
Maybe a powerline adapter will help if you can,t hardwire it
dorsetknob
9,106 (1.24/day)
539 (0.14/day)
Mouse Roccat Tyon
Know any one with Powerline adapters ?you could Borrow localy better than wireless connection
Ahhh done a quick Google and these actually look really interesting! Am I right in thinking they adapt a power socket into an ethernet port? But how do they work/communicate to the network cables running to your house?
Do you have Access to the modem Router (permission to Alter setting ect)
Affirmative, I used the admin settings for the router to forward the ports. Guessing if I have another look there'll be a way to change the channel?
I'm guessing mine is integrated? The only network device I used for my PC is the wireless adapter.
dorsetknob
9,106 (1.24/day)
yes
you need min of 2
one connects to your nearest 13a power socket and then by ethernet cable to your router the other you plug into power socket in your room and also connect ethernet cable to your PC
they communicate using same protocals over your domestic power lines
Pity your not closer as i have a spare couple you could have borrowed
12,340 (2.21/day)
Oregon
There are variables with powerline adapters. The houses wiring, separate circuits but they don't have the latency that wireless has. You just plug them in and go
If you get a pair get ones with Gb port
539 (0.14/day)
Mouse Roccat Tyon
yes
you need min of 2
Ahh I see, well I think I'll buy a couple in that case!
However...may be at least a month until I can, so I need to find a fix for this wireless connection before it drives me to madness! I'll try my hand at changing the channel.
This is an error message I received just now, don't know if this will give an insight into what the issue may be.
Good news, tested in a room with an ethernet socket and no lag whatsoever.
Plus, had enough to order a powerline adapter which will come tomorrow!
brandonwh64
19,542 (3.42/day)
wifi analyzer app on android works great for showing you what wireless SSID's are using which channels.
539 (0.14/day)
Mouse Roccat Tyon
So I've looked up the channel usage in my area and I'm already on the best channel available apparently. I'm on channel 11 whilst everyone else is one channel 1.
I better sit tight until after work tomorrow and get those bad boy powerline adapters up and running :D
So let me get this straight...I assumed at first that the powerline adapters would also be using some kind of wireless frequency (not actually cabled) which I was kind of disappointed with. But they actually use the power cables running through the house to transmit the data??
196 (0.03/day)
Mexico
System Name HTPC
Processor AMD Ryzen 7 5800X
Cooling BeQuiet Dark Rock Pro 4
Memory Kingston Fury Renegade RGB 32GB Kit (2x16GB) 3600Mhz DDR4 CL16
Video Card(s) Sapphire NITRO+ RX 5700 XT
Storage Acer Predator GM7000 4TB / WD Blue SN570 1TB / TOSHIBA HDWD130 3TB
Display(s) LG Oled 42C3
Case Lian Li O11 Air Mini
Audio Device(s) Creative Labs Sound BlasterX G6
Power Supply EVGA SuperNOVA 850 P2
Mouse Logitech G900
Keyboard SteelSeries Apex Pro
Software Microsoft Windows 11 Pro
That error means your fiber is dropping packets "dsldevice.lan" is your fiber modem not answering requests.
I had the same problem they changed the modem
dorsetknob
9,106 (1.24/day)
Each powerline plug has a Frequency filter which piggybacks the TC/IP signal through the power line for encoding/decoding its info
539 (0.14/day)
Mouse Roccat Tyon
Hmm interesting...no-one else on the network seems to get any issues and when I moved my PC to somewhere with an ethernet socket, I had no issues browsing and no lagging in my games.
I'm confused as to why powerlines need to transmit data in the first place though if they're just for trasporting electrical power? Excuse my ignorance!
I'm relieved that it'll be a wired connection though.
dorsetknob
9,106 (1.24/day)
Wireless lan transmits Data over wi fi
ethernet transmits Data from PC to Router over cat3/4/5/6 Cable
Powerline transmits Data from pc over cat cable to powerline ( and then thru domestic power grid to second powerline) and then powerline to router via second ethernet cat cable
There is no power transfered by the powerline devices only data
539 (0.14/day)
Mouse Roccat Tyon
Installed my powerline adapters today and tested games on EA servers and through Steam...all is dandy :D
Thank you so much for your support guys! :toast::lovetpu:
Status
