sound driver problems
Vam
37 (0.01/day)
Processor AMD Athlon II x4 640 3.0GHz
Motherboard Asus M3A78-CM
Cooling Pentagram Cooler
Memory 3 Gb DDR 2
Video Card(s) Inno3D GTS 450 1Gb 128Bits
Storage Samsung 7200rpm, 16Byte, SATA II 500Gb
Display(s) LCD Benq EW2200 22
Case stock
Audio Device(s) HD Audio 8-channel CODEC
Power Supply XSILENCE 500 Watts
Software OC Windows Vista Ulitimate SP2
Hi i've got a problem i can't update my sound driver i've got Cmedia 9761A sound card on board i'm running Vindows Vista Ultimate SP1 .Have any suggestion i'm ready to readand listen.Thx a lot :)
who made the card itself? cmedia or another company using a cmedia chip?
EDIT - and welcome to TPU. =)
Another company using Cmedia Chip
Any clue which one? you might have to pull the card out to see, but mine don't say on it, so that's not a guarentee.
EDIT: oh, it's onboard! hmm... one sec.
Looks like you'll have to have Vista fetch the driver via windows update if it's not already installed -Asrock only offers a driver for windows XP and lower, and cmedia does not offer one for it either.
Any ideea what to do :)
do you have any audio output at all?
do windows update, it should have a driver for it
  • Like
Reactions: Vam
Start > right click on 'Computer' then in the pane of system properties click device manager - once that pops up, scroll down to 'sound, video and game controllers' expand it and right click on each and choose 'update software' and let it check windows update - if there are any unkown devices, do this for them as well.
  • Like
Reactions: Vam
Thx a lot i will try this way lot of thx :)
If it works, please hit the 'Thanks' button on the lower right of my 'post' box, and be sure to do the same in the future if someone gives you helpful advice, and they will do the same for you as well if you give them helpful advice. :) I will check back to see if it did any good.
  • Like
Reactions: Vam
  • Like
Reactions: Vam
Thx to all really appreciate :)
