Sound of pc heard by others in vocal
DeliiK
14 (0.02/day)
Hello, i have a steelseries arctis 3 and when i'm in a vocal (discord, in game, etc..) people hear the sound of my pc even if my mic is muted. I tried to plug it front and back of the pc but nothing changed.
251 (0.17/day)
Scotland
System Name Scan 3XS System
Processor Intel Core i7 11700K
Motherboard ASUS TUF GAMING Z590-PLUS WIFI
Cooling Corsair Hydro H150i ELITE CAPELLIX RGB
Memory 64GB Kingston FURY Beast DDR4 3200Mhz
Video Card(s) 10GB EVGA GeForce RTX 3080 XC3 ULTRA GAMING
Storage 256GB EN605 M.2 SSD, 240GB Kingston SSD, 1TB Lexar NQ790 SSD, 1TB Samsung 970 SSD, 2TB Seagate HDD.
Display(s) Samsung C32JG5x Curved, 1080p, 1920 x 1080
Case Corsair iCUE 4000X RGB
Power Supply Corsair RM750x 80PLUS GOLD
Mouse Razer Mouse
Keyboard ROCCAT Horde
Software Microsoft Windows 11 Pro 64-Bit 24H2
If you're all wearing headphones how can anyone possibly hear your pc...? Can you hear their pc's, if not then they're talking pish ?!
DeliiK
14 (0.02/day)
Wearing headphones or not does not change the fact that they hear the SOUND of the pc not the pc (i mean like videos or else, everything that does sound). No i don't and they're not in push to talk. You didn't understood my problem i guess.
FreedomEclipse
~Technological Technocrat~
24,778 (3.77/day)
(currently) Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Hello,
its it possible to get one of your friends to record what they hear on their end then email it to you so you can drop it here?? It could be EMI (electromagnetic Interference) that they are hearing
DeliiK
14 (0.02/day)
Hello,
I will take an example, if i listen to a youtube vid they will hear exactly what i'm hearing so the sound of the video like if it was them that was listening.
18,584 (2.64/day)
System Name AlderLake
Replace those Delta's with Be Quiet....
166 (0.14/day)
Processor Intel i5 9400f
Motherboard MSI Z390 Gaming Plus
Cooling SilentiumPC Fera 3
Memory 2x 8GB Corsair Vengeance LPX 3200 16-18-18-36
Video Card(s) MSI GTX 1660 Super Ventus XS OC
Storage 500 GB Kingston A2000; 1 TB Kingston A2000; 1 TB HGST Travelstar
Display(s) AOC 24G2U
Case SilentiumPC Signum SG1
Audio Device(s) Creative Pebble Plus; Logitech G533
Power Supply beQuiet Systempower 9 500W
Mouse Logitech G403 Hero
Keyboard HyperX Alloy Origins (Red)
Check under sounds > recording devices that 'Stereo Mix' is disabled. If it is, a screenshot of the recordig devices window might shed some light on it.
DeliiK
14 (0.02/day)
166 (0.14/day)
Would have been nice if it was that easy ... next I would try to establish if it's the headphones or a software issue.
Either try playing a video and look at that gauge next to the microphone in the recording devices list or in the windows settings under system > sound > input; if there is anything on these gauges the headsets may be faulty and sending audio output back into input.
Alternatively you can try going on a voice call with your friends, play some sound and completely unplug your headset. If they still hear your audio after unplugging the headset it's a software issue/misconfiguration.
DeliiK
14 (0.02/day)
Yeah... I don't use the software from steelseries (i tried to use it to see if it was fixing something but no). I did that and the gauge of the mic was moving like the gauge of the headset while i was muted. I did unplug only the mic (pink jack) while i'd let the green one and the gaug was not moving anymore. I join a screenshot though, my headset is recognized as a speaker when i plug it to the back.
166 (0.14/day)
Have you tried unplugging just the green one to see if the gauge stops moving if the headset doesn't get audio output anymore? If that is the case I would recommend contacting steelseries support to get it repaired/replaced, because at that point I suspect a fault in the headset (maybe miswired or something).
DeliiK
14 (0.02/day)
I did it a few sec ago and gauges are not moving :( My headset is too old so i will need to buy a new one, thx for the help !
166 (0.14/day)
One last thing I just noticed is that the Arctis 3 seems to have a detachable cable. Maybe try unplugging it on the headset side and leaving both plugs in the PC and see if it still duplicates the sound. If it does only the cable might be broken.
DeliiK
14 (0.02/day)
I did it and i saw the gauge of sound move but not the mic one
dgianstefani
TPU Proofreader
5,442 (2.04/day)
Swansea, Wales
Benchmark Scores Legendary
Some pcs have integrated microphones. Go to device manager and check.
2,523 (2.68/day)
Braziguay
Processor AMD Ryzen 7 5700X3D
Case Lian Li Lancool 216
Mouse Razer Viper Ultimate
Does the same behavior happen if you use the front jacks on your case?
166 (0.14/day)
Then it's unfortunately the headset itself that causes the feedback. You could try the headset on a different device/PC if you have access to one, just to be sure, but I don't have high hopes for it anymore.
2,523 (2.68/day)
Braziguay
Y, i told it on the post ^^
Sorry, I did read it a little bit fast while commuting so I didn't notice.
Then, as @DarkDreams said here
I'd check if reseatting the plug on the cans help. I wouldn't put my Astros above such an issue if the cable weren't to be correctly plugged.
DeliiK
14 (0.02/day)
True, i can check to be sure. Thx for your help !
I checked and it seems to be correctly plug in
2,523 (2.68/day)
Braziguay
But does the Sound Panel bars behaviour change while moving the plug?
A kludge way of checking this would be starting some music and monitor the bars while you move the plug around. If at any point the mic stops reacting to the music (but still reacts to your voice), there may be a mismatch between the plug and the jack contacts.
ixi
1,482 (0.38/day)
So, you have somewhere plugged incorrectly cables or mixed up settings with recording device or discord output device.
DeliiK
14 (0.02/day)
Every cables seem ok and i used default periph (so windows settings) and i only have 1 possibility for headset and mic so can't be this one
I tried and it was moving everytime
18,584 (2.64/day)
Try this:
Discord Settings>voice&video>turn off automatically determine voice sensitivity and adjust the slider if necessary lower mic volume.
https://www.reddit.com/r/steelseries/comments/l4m5yn
