Stuttering issue in video applications with "stable system"
I can't speak for the other games, but certainly in PUBG you're never, and I seriously mean never! gonna get it to not stutter on that hardware. You have a slow cpu regardless of how hard you OC it, ddr3 ram (again, slow). The GPU is also on the low end for pubg, should be okay for 1080p. The SSD might help, a hdd would definitely add a intermittent bottleneck.
Pubg runs smoothly on my system for the most part, but still get the occasional stutter. If you want to continue with your current system I think you'll need to limit yourself to games that play well or just come to terms with the fact that not all games will play nice on old hardware (and sometimes even new hardware, as others have said, pubg is horrendously unoptimized). Sorry to be blunt but I think it's best to say it, because atm I think you have some
Yeah I agree. If the above didnt work then im at a loss to explain why you have stuttering, keep playing around with it though.
My build is worse than yours in every way.
Tuthfully PUBG runs at 50-60fps on my i7 anyways, the game is poorly optimized.
PUBG holds 30-40fps on my fx build, doesnt stutter though.
Performance is smooth regardless of low fps.
I thInk simple bad luck is your issue.
That said VRM temps would be the only issue I would bother troubleshooting even though your board has a good VRM.
I ran my CPU at 4GHZ at first but had BSODs and input lag.
Doubt will help in your case as my VRM is a 4 phase with no heatsiink.
the system is fast like a bullet compared to the HDDs speed. boots up quickly, load games quickly an in games installed in it, the stutter is smaller but it is still possible to notice something wrong.
I ve tested to system in the Doom 2016 game - a game that I have finished in 2016 and didn't had any problems at all - and now it stutters aswell. every time it happens the cpu metrics go red. and it can be easily reproduced when printing the screen with Steam's F12 key. so... again... using hdd = stutter.
Does any software or your driver auto save screen shots Or stream without you knowing.
That’s a real good one, since that behavior does cause a momentary hitch!
