- Jun 5, 2014
- 40 (0.01/day)
- Helsinki
Processor | Ryzen 7 3800x |
Motherboard | MSI MEG X570 UNIFY |
Cooling | Noctua NH-D15 chromax.black |
Memory | G.Skill Ripjaws V 2x16GB DDR4 3200MHz |
Video Card(s) | Asus ROG Strix RTX 2070 Super OC, GPU Boost Clock +70MHz |
Storage | Samsung 970 Evo Plus 1TB system drive, Samsung 960 Evo 500GB |
Display(s) | Asus MG279Q |
Case | Phanteks Eclipse P600S White |
Mouse | Corsair Nightsword RGB |
Keyboard | Corsair K65 Lux RGB |
Software | Windows 10 Pro |
I was wondering if it’s time to upgrade my CPU, motherboard and RAM and whether I get any meaningful benefits out of this. I’d like to be economical and practical about it but at the same time get better performance compared to my current system otherwise there’s no point in spending money and get the same result.
So I was thinking about combination of Asus ROG Strix X570-E Gaming motherboard with Ryzen 7 3700x CPU. There’s one thing I don’t like on this motherboard, which is how M.2 heatsinks are implemented that require removal of chipset shroud. I also consider Gigabyte X570 Aorus Ultra motherboard for it has 3 M.2 slots and better implementation of their heatsinks. But I have no idea about the quality of Gigabyte’s motherboards, UEFI and customer support as I’ve always used Asus motherboards and got accustomed to their products and ecosystem.
I’m not sure if my current RAM will work with these motherboards and CPU and if not, what speeds would you recommend, what capacity and how many modules should I get, two or four. Will 32GB be of any use for me and in the near future and should I get 4x8GB or 2x16GB modules?
Will my current CPU cooler be sufficient for Ryzen 7 3700x? If not, I still have my 3-years old Corsair H110i AIO cooler, which I actually consider selling while it lasts and get something like Noctua NH-D15 Chromax Black or NH-U12A if my current CPU cooler is insufficient.
If this whole idea of upgrading currently not worth it, I was wondering if the next generation of Ryzen CPUs get even better. The way I understand it, this new 7nm manufacturing process brings new challenges and to me it looks like the entire platform has too many ‘rough edges’ like CPUs not being able to hit higher clocks, for instance. I also don’t particularly like active cooling (fan) on chipset. It’s one more source of noise, one more thing to get broken over time. Most of these fans are close or directly under the graphics card expelling hot air. I wonder if already next generation of motherboards will do without active cooling and most importantly, be cheaper than current generation.
And I’m not sure if there’s anything better to expect from the next generation of Intel CPUs in terms of price/performance and platform innovation. Correct me if I’m wrong.
I’ve been able to achieve sustainable under any workload overclock for my CPU at 4,7GHz on all cores leaving all other settings including core voltage on ‘auto’. Temperatures under load (Cinebench R20, Asus RealBench, gaming) rarely get to 75 degrees Celsius max.
I game at 1440p resolution and in such titles as ‘Deus Ex: Mankind Divided’, ‘Shadow of the Tomb Raider’ my FPS hover around 90s with DX12 and around 70s with occasional dips to 60s with DX11 with all the graphics settings at max.
Occasionally I do some light photo editing/retouching after scanning my photo negatives from the past, I digitize my CDs, DVDs and some Blu-Rays, which sometimes require format conversion. Blu-Ray conversion actually takes hours with this CPU but I rarely do this.
So these are my thoughts. Any comments and suggestions are highly welcome!
Thank you in advance!
