- Sep 4, 2022
- 7 (0.01/day)
System Name | Asus VivoBook |
Processor | Intel i5-9300H |
Memory | 24gb DDR4 2400MHz SODIMM |
Video Card(s) | Nvidia GTX1650 Mobile 4GB |
Storage | XPG GAMMIX S11 Pro 1TB |
Mouse | Logitech G603 |
First a quick backstory:
Hi, I started using throttlestop some months ago to undervolt since then there has been many developments and research in my journey with this program. I would say I'm an intermediate with this program.
I recently did a windows reinstall meaning many things changed one of them is that my undervolt is no longer applying for some reason, but I don't care about undervolting anymore since I started undervolting to lower temps and after a repaste the temps are well within reason(max 70°C when heavy gaming on a hot day). And now I wish to increase temps since most of the times the computer is 60-65°C under load and I think that indicates I could get a bit more performance out of it.
My main worry here is bricking my laptop since I don't have any money to buy a new one any time soon.
Now for my questions:
I have a intel i7-8550U cpu, my laptop is a lenovo ideapad 330-15IKB with a Nvidia MX150(undervolted with MSI afterburner) and I want a bit more performance out of it and what I did was removing the 15 watts TDP limit put in by the MSR and MMIO(locking the MMIO and changing Long Power PL1 from 15 to 25W and I can confirm that the change was effective as I checked using TSbench 960M and there were no limits being triggered), then I set the speed shift max to 28(which is a clock that the CPU stays a tiny bit below 25 watts). But why 25W? I searched for my CPU specs on intel's site and it said there that the configurable TDP-up was 25 watt and here is my main doubt: Am I right in assuming that the configurable TDP-up is safe to run on my CPU(that CPU-Z reports it's max TDP as being 15W)? And is this "overclock" safe? I'm also worried about VRMs bc this is not the clock nor the power of this CPU's stock state so: could this "overclock" damage the VRMs(or any other component of my motherboard)? I checked the VID under load and it stays below 1V(but with stock speeds it stays around 0.75V).
Speaking on stock this CPU without throttlestop keeps the 4ghz boost until any medium-heavy load, after that it goes straight to it's base frequency of 1.8ghz. When gaming this means that it fluctuates a lot between those two frequencies and that's no good for frame times.
My main goal with this overclock has been achieved which is more performance and hotter temps but I don't know if it is safe to run without it damaging my CPU or motherboard.
