Hello all,
First post on here but looking for some help after watching near 1 billion YT videos and have them all more or less skip over the PSU/general cable connections part.
I was in the process of upgrading an SSD on my 10-year old rig when I decided to just finally build my own full rig. Almost all of the parts arrived yesterday so I managed to get everything bar the GPU (coming Wednesday) installed but when it came to the cabling I almost had an aneurysm. I am a complete novice when it comes to the hardware side of PC's.
My new rig:
CPU: Ryzen 5 3600X (Wraith Spire cooler included)
Motherboard: MSI B450 Tomahawk Max
GPU: GTX 1650S ROG Strix
SSD: Samsung 860 EVO 1TB
HDD: Seagate BarraCuda 4TB
Memory: Corsair Vengeance LPX 16GB (2x8GB)
Power: Corsair RM750
Fans: 2x Corsair ML120 RGB inc. Lighting Node PRO
Case: NZXT H500i
Can anyone give me a really simple answer as to what cabling I need and where it goes? Or a decent YT tutorial I may have missed? I've got a ridiculous amount of cables in all the boxes now. I think I maybe bit off more than I can chew getting a case with a smart device & RGB fans as the lighting node baffles me.
So far I know the obvious:
- 24-pin cable from PSU directly into MOBO for power
- 8-pin cable from PSU directly into MOBO for CPU
- I think because I don't have an Intel MOBO I have to connect the case F_connect cable (LED) from the smart device to the short f_connect "connector" then into the MOBO?
- I can have one cable from PSU with some SATA connectors on it to connecto to my SSD (mounted on back of MOBO) and HDD in driver rack
After that I am lost... quite overwhelmed by all the cables and connections.
This is the smart device:
- I presume the LED cable is what I need to connect into the MOBO with the f_connect "connector"?
- USB I'm assuming goes directly into the MOBO (will I have enough USB slots on the MOBO for all the connections?)
- Fan 1 and 2 are connected to the 2 exhaust case fans, but wondering if I need to remove the FAN 3 cable to somehow link up the lightning node pro or this cable connects to the lightning node pro?
Much appreciated if anyone can help at all.
My new rig:
Case: NZXT H500i
