TeamGroup Xtreem DDR5 heatshield removal the easy way.
231 (0.17/day)
Colorado
Processor AMD Ryzen 9 9950X
Motherboard Asus ROG Crosshair X670E Gene
Cooling Full Custom Water
Memory 48GB DDR5
Video Card(s) AMD Radeon RX 7900 XTX
Storage Crucial T700 2TB Gen5 SSD
Display(s) Asus PG32UQX
Case BC1-V2 Titanium Edition
Audio Device(s) SteelSeries Arctis Pro
Power Supply SeaSonic Prime SSR-1300TR2
Mouse G502 Lightspeed
Keyboard Keychron Q1 Max, Drop + Matt3o MT3 Susuwatari, Gateron Milky Yellow Pro.
Software Windows 11 Pro 24H2
20240515_200219764_iOS.jpg 20240515_200344122_iOS.jpg 20240515_200506793_iOS.jpg
I soaked RAM for one-hour in the Turpentine, and the heatshields basically fell off when I removed them, diden't actually need the tools.
Then I washed, rinsed with 91% Isopropyl Alcohol to remove turpentine, any glue residue. Going to leave them out in the sun for awhile, will wait 24-hours to test.
The Xtreem heatshields inter-lock with tabs, and pins, along with the adhesive,.. very well made, thermo pad on the PMIC.
20240617_185249998_iOS.jpg 20240617_201214835_iOS.jpg 20240617_201234191_iOS.jpg
I guess the first question is Why?
I would have assumed Turpentine would eat the PCB. Guess not. A more destructive way is a hair dyer for 30-50 seconds. Peal and repeat until it comes apart. Some brands are extra hard to get apart like XPG, but Teamgroup is one of the easier ones I think.
The foam side is a pain to get off usually. Sometimes you can get under the glue and it comes off in a strip. Most often its in chunks :/
Nice! I'll have to keep this method in mind if I change my Ripjaws heatspreaders.
I think I didn't apply enough heat when removing them from my first Viper Steel kit so that may have caused their weird behaviour and eventual demise.
I think @Braegnok just likes to run fast, tight, and cool. :cool:
:rockout:
I have a set from this line and they stay cool enough for my use on air, but I'm not running them that hard either.
Running close to 9.000W is about the limit with the OEM heatshields, need better cooling to go higher. :)
I would not trust turpentine. PCBs are coated with resins to keep the layers sealed together and to keep moisture and contaminates out.
