- May 14, 2004
- 28,978 (3.75/day)
Processor | Ryzen 7 5700X |
Memory | 48 GB |
Video Card(s) | RTX 4080 |
Storage | 2x HDD RAID 1, 3x M.2 NVMe |
Display(s) | 30" 2560x1600 + 19" 1280x1024 |
Software | Windows 10 64-bit |
Memory | 48 GB |
System Name | Pioneer |
Processor | Ryzen 9 9950X |
Motherboard | MSI MAG X670E Tomahawk Wifi |
Cooling | Noctua NH-D15 + A whole lotta Sunon, Phanteks and Corsair Maglev blower fans... |
Memory | 64GB (2x 32GB) G.Skill Flare X5 @ DDR5-6200(Running 1T no GDM) |
Video Card(s) | PNY RTX 5080 OC |
Storage | Intel 5800X Optane 800GB boot, +2x Crucial P5 Plus 2TB PCIe 4.0 NVMe SSDs, 1x 2TB Seagate Exos 3.5" |
Display(s) | 55" Hisense 55U8N 4K FALD Display |
Case | Thermaltake Core X31 |
Audio Device(s) | TOSLINK->Schiit Modi MB->Asgard 2 DAC Amp->AKG Pro K712 Headphones or HDMI->B9 OLED |
Power Supply | FSP Hydro Ti Pro 850W 80Plus Titanium PSU |
Mouse | Logitech G305 Lightspeed Wireless |
Keyboard | WASD Code v3 with Cherry Green keyswitches + PBT DS keycaps |
Software | Gentoo Linux x64 / Windows 11 Enterprise (yes it's legit) |
System Name | Acer Nitro 5 (AN515-45-R715) |
Processor | AMD Ryzen 9 5900HX |
Motherboard | AMD Promontory / Bixby FCH |
Cooling | Acer Nitro Sense |
Memory | 32 GB |
Video Card(s) | AMD Radeon Graphics (Cezanne) / NVIDIA RTX 3080 Laptop GPU |
Storage | WDC PC SN530 SDBPNPZ |
Display(s) | BOE CQ NE156QHM-NY3 |
Software | Windows 11 beta channel |
Memory | 48 GB |
As expected. Underlying reason is that the EAC method removes some hashes from the .CAT file, which affects GPU-Z's verification methodGPU-Z flags signature as unknown.
thanks!Can confirm that EAC is not triggered. Thanks for your work!
Memory | 32 GB |
Memory | 48 GB |
any idea why they added this limitation? have you tested it on older windows builds?by removing the build check
Memory | 32 GB |
They cannot advertise RTX features under old Windows 10 versions.any idea why they added this limitation? have you tested it on older windows builds?
System Name | NEW AAF OPTIMUS RIG |
Processor | AMD Ryzen 5 5600X (6C/12T) |
Motherboard | ASUS TUF Gaming B550M-Plus |
Cooling | DeepCool Gammax L120T |
Memory | Crucial Pro Gaming 32GB DDR4-3200 (2x16GB) |
Video Card(s) | NVIDIA GeForce RTX 3060 12GB MSI Ventus 2X OC |
Storage | ADATA Legend 710 PCIe Gen3 x4 256GB; ADATA Legend 800 PCIe Gen4 x4 2TB |
Display(s) | AOC Viper 27" 165Hz 1ms (27G2SE) |
Case | Aigo Darkflash DK353-BK |
Audio Device(s) | Realtek S1200A - AAF Family DCH Audio |
Power Supply | RedDragon RGPS 600W 80 Plus Bronze Full Modular |
Mouse | ELG Ceres HyperLight Gamer Mouse |
Keyboard | Motospeed CK-108 Mechanical Keyboard |
Software | Windows 11 Pro x64 23H2 |
Exactly!Another tidbit. For whatever reasons some users prefer antiquated Windows 10 builds or are not even aware of it.
You can force installation of new drivers by removing the build check:
[Manufacturer]
%NVIDIA_A% = NVIDIA_Devices,NTamd64.10.0...17098
[NVIDIA_Devices.NTamd64.10.0...17098]
Memory | 32 GB |
Exactly!
Memory | 48 GB |
First time I hear this, anyone else?But one has to uninstall the Nvidia driver first otherwise it's not being reinstalled
I did, their response "The listed files are embed PE signed binaries. Unfortunately, the OS can't recognize these certificates and this is expected behavior. Engineering has reported the issue to Microsoft."Someone tell Nvidia it's now 2021 not 2019 and that certificates don't last forever.
What's also interesting is that they're getting this timestamped with an expired certificate, and get a MS sig on top of thatexpired certificate signed
Well I don't remember the exact setup menu listing details anymore after installation, if it said driver not installed there or nothing, one of those. The fact that EAC kept on complaining after system restart the same way as it did before the reinstall, my conclusion was that the driver itself was not changed. I also don't remember loosing monitor settings either, I use CRU to clean up the entries and raise refresh.First time I hear this, anyone else?
Try opening your own ticket, maybe you'll have more luck
Memory | 48 GB |
That's pretty much what I've been using for testing dozens of times, just with non-DCHI have been installing 466.47-desktop-win10-64bit-international-dch-whql.exe modified with v1.9.2 over 466.47-desktop-win10-64bit-international-dch-whql.exe (same driver) modified with v1.9.0. In both I disable the telemetry, including any experimental and enable MSI.
I tried to find the Nvidia bug/issue report page again but could not, anyone got a link?
Nice find, I wasn't aware anyone else encountered this problem before. Unfortunately no solution and doesn't look like NVIDIA is planning to fix this. And I agree, this is probably human errorVirtualbox
Memory | 48 GB |
which settings?where the settings are stored?
I was talking about my post above, I meant the HD audio settings. They always get resetted in the normal installation.which settings?
Memory | 48 GB |
Where do you change those settings? I didn't even know there was something to be configuredI was talking about my post above, I meant the HD audio settings. They always get resetted in the normal installation.
In Control Panel->Sound or right-clik on the sound icon in the taskbar.Where do you change those settings? I didn't even know there was something to be configured![]()
Memory | 48 GB |
They got reset with the HD audio, I don't know if I can leave the current one alone.and when you install a new driver version (install over, no ddu), these options get reset?
System Name | Oh wow it's actually good now |
Processor | AMD Ryzen 9 5950X |
Motherboard | MSI Prestige X570 Creation |
Cooling | Scythe Fuma 2 |
Memory | Patriot Viper Steel 64GB @ 3800MHz |
Video Card(s) | EVGA GeForce RTX 2080 Ti Black |
Storage | 2TB Kingsman KP800, 2TB WD Black SN750, 2TB WD Blue SATA SSD |
Display(s) | Viotek GNV27DB, Acer CB271HU, Acer G247HL |
Case | Fractal Design Pop Air |
Audio Device(s) | Integrated ALC1220 (temporarily) |
Power Supply | EVGA SuperNOVA 850 G6 |
Mouse | Logitech G700 |
Keyboard | EVGA Z20 (Linear) |
Software | Windows 8.1 |
