Hi every one, I have already lapped all my water blocks, when I going to lap my CPU I realized I have no longer have that plastic holder came from the CPU
, so what do I use to hold the CPU while lapping it? Any info will be appreciated. Thank you.
System Name | EVA-01 |
Processor | Intel i7 13700K |
Motherboard | Asus ROG Maximus Z690 HERO EVA Edition |
Cooling | ASUS ROG Ryujin III 360 with Noctua Industrial Fans |
Memory | PAtriot Viper Elite RGB 96GB @ 6000MHz. |
Video Card(s) | Asus ROG Strix GeForce RTX 3090 24GB OC EVA Edition |
Storage | Addlink S95 M.2 PCIe GEN 4x4 2TB |
Display(s) | Asus ROG SWIFT OLED PG42UQ |
Case | Thermaltake Core P3 TG |
Audio Device(s) | Realtek on board > Sony Receiver > Cerwin Vegas |
Power Supply | be quiet DARK POWER PRO 12 1500W |
Mouse | ROG STRIX Impact Electro Punk |
Keyboard | ROG STRIX Scope TKL Electro Punk |
Software | Windows 11 |
System Name | AMD | Intel | Chumpy |
Processor | PHII 955BE Stock | i7 920 D0 4.01 GHz | i7 920 D0 4.01 GHz |
Motherboard | MSI 790FX-GD70 | EX58 - UD5 | E760 4 Way SLI |
Cooling | Zalman 9700 CNPS | Water Loop | Water Loop |
Memory | 4 GB XMS3 1600 MHz | 6 GB Dominators 1600 MHz | 6 GB Dominators 1866 MHz |
Video Card(s) | 3 x 9600GSO, GTX260 216 | 2 x GTX 260 216 | GTX 260 216, 9600 GSO |
Storage | WD 640GB | Couple o' 5400RPMs | WD 1TB |
Case | Cosmos S | Lancool K62 Dragonlord | Lian Li PC-P80 Armor |
Power Supply | TX850 | HX 1000 | HX 1000 |
Software | Win 7 Home Premium | Win 7 Ultimate | Vista Home Premium |
System Name | УльтраФиолет |
Processor | Intel Kentsfield Q9650 @ 3.8GHz (4.2GHz highest achieved) |
Motherboard | ASUS P5E3 Deluxe/WiFi; X38 NSB, ICH9R SSB |
Cooling | Delta V3 block, XPSC res, 120x3 rad, ST 1/2" pump - 10 fans, SYSTRIN HDD cooler, Antec HDD cooler |
Memory | Dual channel 8GB OCZ Platinum DDR3 @ 1800MHz @ 7-7-7-20 1T |
Video Card(s) | Quadfire: (2) Sapphire HD5970 |
Storage | (2) WD VelociRaptor 300GB SATA-300; WD 320GB SATA-300; WD 200GB UATA + WD 160GB UATA |
Display(s) | Samsung Syncmaster T240 24" (16:10) |
Case | Cooler Master Stacker 830 |
Audio Device(s) | Creative X-Fi Titanium Fatal1ty Pro PCI-E x1 |
Power Supply | Kingwin Mach1 1200W modular |
Software | Windows XP Home SP3; Vista Ultimate x64 SP2 |
Benchmark Scores | 3m06: 20270 here: http://hwbot.org/user.do?userId=12313 |
meh its really overkill. BTW you can drop the CPU in the toilet for all I care, just dry it well it will reboot. The water isnt going to hurt a thing trust me I have lapped a few procs myself.
http://img.techpowerup.org/090905/DSC00679.jpg
All done with sandpaper taped to a chunk or granite I got. add water and start lapping. Watch a few vids on youtube.
I would use that little black pad that comes in the processor blister pod thing, just to stop any water getting on it accidently.
Although you don't need to worry about much, even a little water on the grid surface of the CPU isn't bad (IIRC, the grid surfaces is sealed pretty well) - just make sure to dry it off, then clean it a bit with some rubbing alcohol (to remove any potential metal grit that might have transferred) . . . if you're still not 100% of the condition after cleaning it, let it sit for a day or two to dry . . .
TBH, if you're more worried about getting finger prints or such on the grid surface - wear a pair of latex gloves (or nitrile if you're allergic to latex). They can typically be had from a local drug store, and can usually be bought in a package of 1 pair (two gloves). They'll also offer a little better "grip" on the CPU.
