Normal FIVR values gave me max of 85cSome Power Limit throttling in a laptop is normal. Manufacturers usually set the PL1 power limit to 45W because Intel gave the 10500H a 45W TDP rating.
https://ark.intel.com/content/www/u...0500h-processor-12m-cache-up-to-4-50-ghz.html
Post a screenshot of the TPL window if you need help. You can try increasing the turbo power limits if you want fewer power limit throttling messages in Limit Reasons. You have slowed your CPU down significantly in the FIVR window so I am guessing that your CPU already runs too hot. In that case, leave the power limits alone.
EDP OTHER going yellow under the RING column is very common. This can happen when the CPU is idle so it is not important. Ignore this. You only need to worry about throttling when boxes start turning red in Limit Reasons when you are actively using your computer. Any throttling when idle is meaningless.
Laptops with Intel CPUs can safely run at over 90°C. That is why Intel has set the default thermal throttling temperature to 100°C.I don't know if this too hot or no
Thanks uncle, but what about this oneLaptops with Intel CPUs can safely run at over 90°C. That is why Intel has set the default thermal throttling temperature to 100°C.
Product Specifications
quick reference guide including specifications, features, pricing, compatibility, design documentation, ordering codes, spec codes and more.ark.intel.com
No need to worry about the temperature of your CPU. It will take care of itself.
What about it? Some PL1 or PL2 power limit throttling is common in laptops. Post a log file while you are actually using your laptop. Check the log file option before you start playing a game and when you are finished doing some testing, exit ThrottleStop so it can finalize your log file. It will be in your ThrottleStop / Logs folder. Attach one to your next post so I can see how your laptop runs. Also post a screenshot of your Turbo Power Limits window so I can see how you have ThrottleStop setup.what about this one
this is logs TPLWhat about it? Some PL1 or PL2 power limit throttling is common in laptops. Post a log file while you are actually using your laptop. Check the log file option before you start playing a game and when you are finished doing some testing, exit ThrottleStop so it can finalize your log file. It will be in your ThrottleStop / Logs folder. Attach one to your next post so I can see how your laptop runs. Also post a screenshot of your Turbo Power Limits window so I can see how you have ThrottleStop setup.
The only throttling I see in your log file is the throttling that you are doing to your CPU. You have adjusted all of your turbo ratios to 35 so your CPU is running much slower than its rated speed. Intel rates their CPUs to be able to run reliably up to 100°C. Your temps are mostly around 55°C. Why buy a fast CPU and then slow it down so much?this is logs TPL
Ok, gonna reset it to default, it just keep my fans sound low., So nothing to worry about ?The only throttling I see in your log file is the throttling that you are doing to your CPU. You have adjusted all of your turbo ratios to 35 so your CPU is running much slower than its rated speed. Intel rates their CPUs to be able to run reliably up to 100°C. Your temps are mostly around 55°C. Why buy a fast CPU and then slow it down so much?
Are you running any game boosting type software? Some of these programs will lock your background programs to 1 or 2 specific threads. This prevents ThrottleStop from working correctly.only shows 2 lines of values
Actually yeah, razer cortex software, it doesn't make any difference tbh.Are you running any game boosting type software? Some of these programs will lock your background programs to 1 or 2 specific threads. This prevents ThrottleStop from working correctly.
I am not a big fan of these boosting programs. If they make your games run smoother, great. Some of these programs are like snake oil and might reduce performance.
If your Razer Cortex software provides no benefit, I would get rid of it. Some boosting programs that try to micro manage the CPU by fixing programs to specific cores can end up doing more harm than good.it doesn't make any difference
Thanks uncle, much loveIf your Razer Cortex software provides no benefit, I would get rid of it. Some boosting programs that try to micro manage the CPU by fixing programs to specific cores can end up doing more harm than good.
Your ThrottleStop settings are fine. Some people like slowing their CPU down when gaming. For some games, there will be hardly any difference in FPS but a big difference in reduced temperatures and reduced fan noise. You can use ThrottleStop to run your CPU however you like.
