ThrottleStop TPL: Can't unlock Turbo Boost Power Limits
2 (0.00/day)
System Name Lenovo Legion Y540
Processor Intel Core i7-9750H
Video Card(s) nvidia RTX2060
Hi there!
I was playing around with ThrottleStop 9.2, specifically with the TPL options. I went to Turbo Boost Power Limits, checked the "Lock" box and hit apply... Now I can't unlock it.
Already searched but found no tip on unlocking it.
Does any1 know how to unlock these settings?
Thank you!
Exit ThrottleStop. Delete the ThrottleStop.INI configuration file. Shut down your computer. When you restart, the Lock option should be reset.
If it is not reset, hold the Shift key down while selecting the Windows Shut down menu option to do a full shut down. The BIOS should reset your CPU and that should unlock the power limit register. It is rarely necessary to use the Lock option.
