Throttlestop Weird Issue
m4l0n
5 (0.00/day)
Laptop Model: Huawei Matebook X Pro 2020
Processor: i7-10510U
BIOS: 1.21
I've recently just tried the Overclocking lock bypass by changing the UEFI variable so that I can undervolt again. It was working fine for months until today. As you can see from the image below, The FIVR Control box is empty and the table on the right side has no values. I'm not sure if the undervolting is actually working or not as I can still adjust the offset voltage. I don't know what has caused this. Tried restarting the application and even the laptop. Does anyone have any fix to it?
Edit: A reinstall of Throttlestop 9.4.2 beta didn't work either. I think the undervolt does still seem to work, as I removed ThrottleStop.ini and rebooted my laptop, and the temperature was about 77 - 90 degrees Celcius. I restored the previous ThrottleStop.ini file and the temperature dropped to 60 degrees Celcius.
Edit 2: I've read somewhere that WSL 2 may break Throttlestop, and I realised that this issue did occur after I installed WSL 2 on my machine. I uninstalled it and rebooted, but the issue still persists. Another thing that may have broken Throttlestop may be Virtualisation from what I have read. I do have it enabled, but it has been working fine thus far with Virtualisation enabled on my machine. I do use Virtualbox from time to time. Do I have to disable Virtualisation?
I also have Matebook X Pro 2020 on 1.21 firmware.
Could you help me undevolting it ?
disable all the Windows virtualization options -> Virtual platform + Hypervisor...also in bios*, disable the core isolation option and if present in BIOS enable the voltage mod
* I use Virtualbox whit VT enable in the BIOS and TS works
Thanks for fast reply. I have stock bios.
Do you have guide for unlocking voltage control in bios ?
I read voltage in Fivr window but can't unlock voltage to undervolt
can you post a screenshot?
edit:
it's the latest version of your BIOS which locks the undervolt option
I found on google a lot of info about it...and some way to unlock it
edit:
Could you tell me what guide you used to unlock voltage regulation ?
So Throttlestop and virtualbox worked in windows 11 with virtualization enable?
Just wanted to confirm because I'm planning to upgrade to windows 11 soon.
For me yes.... VT On in Bios and all VT features disable in windows
Asus TUF F17 FX706HCB.310
Windows 11 Home 10.0.22000
Oracle VBox 6.1.34 r150636 QT5.6.2
