EastCoasthandle
- Apr 21, 2005
- 6,885 (0.94/day)
System Name | MY PC |
Processor | E8400 @ 3.80Ghz > Q9650 3.60Ghz |
Motherboard | Maximus Formula |
Cooling | D5, 7/16" ID Tubing, Maze4 with Fuzion CPU WB |
Memory | XMS 8500C5D @ 1066MHz |
Video Card(s) | HD 2900 XT 858/900 to 4870 to 5870 (Keep Vreg area clean) |
Storage | 2 |
Display(s) | 24" |
Case | P180 |
Audio Device(s) | X-fi Plantinum |
Power Supply | Silencer 750 |
Software | XP Pro SP3 to Windows 7 |
Benchmark Scores | This varies from one driver to another. |
I wanted to create a user base tip thread that would provide some tips when you have to format your PC. I will start of with a few that I know:
-Keep a copy of windows 7 on your hard drive (a separate one was used). This should speed up the time it takes to reinstall your OS.
-Don't erase your games. Just install in the same directory. Some of them actually allow them to reinstall what is needed install of a full reinstall. 2 games I noticed doing this is BC2, NFS Shift and Dirt 2
-You can reinstall your OS from within safe mode if for some using the CD as a bootable disc takes to long
-When doing a new OS install using Win7 you don't have to worry about duplicate program file folders, user folders, etc. They are all put into windows.001 folder. That way you can look through them, pick what you want and discard what you don't need.
What are other tips out there?
