Toshiba Satellite L500d-00x -- Power LED on no display, tried VGA hoop-up
213 (0.04/day)
System Name Shark's Build
Processor AMD Ryzen 7 5700X 3.4 GHz
Motherboard Gigabyte B450 I AORUS PRO
Cooling Noctua NH-C14 heatsink core with swapped Phanteks PH-F140HP PWM
Memory G.SKILL Aegis (2 * 8GB) DDR4-3000
Video Card(s) GeForce RTX 3060Ti 8GB
Display(s) Tri-Monitor setup 1x144hz 2x60hz
Case Corsair Obsidian 250D Mini ITX
Audio Device(s) On-Board
Power Supply EVGA Supernova NEX750B 750W ATX Power Supply 80+ Bronze
Hello gals&guys
I'm looking at a friends laptop and I hear the fan spinning and the power LED on, however I don't get a display on the main monitor, nor if I hook up the VGA. I tried a combination of the FN hotkeys, as well as windows+P for changing the displays.
No luck.
At one point a fan started to speed up extremely rapidly inside, then went back to idle RPM.
Any ideas?
Any help is greatly appreciated :)
46 (0.01/day)
System Name Current
Processor Intel i7 5930k @ 4.6Ghz 1.3v h²o
Motherboard Asus R5E EK Monoblock h²o
Cooling Custom Water 360 + 480 Rad
Memory Corsair Dominator Platinum 32GB DDR4-2666
Video Card(s) Gigabyte Ref GTX 980 SLI h²o EKWB
Storage 500GB 950 Pro M.2 SSD, 2TB WD Black, 3TB WD Green, 4TB Seagate
Display(s) Asus PG278Q ROG Swift 1440p 144hz G-Sync 1ms, Dell U2711 IPS 1440p
Case Corsair Obsidian 900D
Audio Device(s) Creative Sound blaster Zx
Power Supply Corsair AX1200i
Software Windows 10 Home 64 Bit
try re-seating ram.
I work in a PC store. I see alot of laptops like this. Usually its the GPU on the board thats gone. Sometimes a reflow works. If not, then a new motherboard is needed. (worst case scenario)
213 (0.04/day)
try re-seating ram.
appreciate the reply my friend. I'll definitely try that.
2,469 (0.55/day)
Bulgaria
System Name Sandfiller
Processor I5-10400
Cooling Noctua NH-L9i (92x25mm fan)
Video Card(s) MSI RX 5700 XT GAMING X
Storage Intel 670P 512GB
Display(s) 2560x1080 LG 29" + 22" LG
Case SS RV02
Mouse Logitech Triathlon
Keyboard REDRAGON MITRA
Software Windows 11 Home x 64
My wife's laptop had the same symptom. It turn out that the integrated GPU has died. Everything else was working fine. The laptop would start, but have no output. The reason was a huuuge dust ball, which could've been prevetned had I opened it for a clean up earlier.
One thing you could try with it, is take out the battery, uplug the cable, hold the power button for 5 sec. and turn it on with only AC power, no battery. It helped me when flashing the BIOS. It just wouldn't do it with the battery in. Not exactly relevant, but won't hurt a shot.
AsRock
TPU addict
18,876 (3.07/day)
UK\USA
Cooling D15
Audio Device(s) Yamaha RX-V677 \ Yamaha CX-830+Yamaha MX-630 Infinity RS4000\Paradigm P Studio 20, Blue Yeti
Connect a monitor\HDTV in to the HDMI port if available and see if any thing comes on then. If some thing does come on then the panel would look like it had gone and not the video card.
213 (0.04/day)
Hey IZKoce, I tried the second part but haven't checked the inside. That's next on my list, just have to go purchase a tool set.
AsRock, I did try this as well and no luck. The laptop had VGA only :(
I'm guessing the video card circuitry is toast on the laptop's motherboard. I'll be sure to post a reply if I find a solution :) Thanks again everybody :)
213 (0.04/day)
Figured it out guys :p
It was the RAM needing reseating. I ripped them sticks out then chucked them back in. Display showed up almost right as soon as I powered it on. :D
You guys rule, keep this community flowing :)
Cheers
46 (0.01/day)
System Name Current
Cheers
Told ya! lol
213 (0.04/day)
Anyone know why re-seating the RAM can fix the display exactly? Seems like such a weird cross of entities that are dependent on each other :s
