Trouble hooking up Bluray 5.1 surround sound system to Desktop PC.
Bartok
6 (0.00/day)
I recently received an LG 5.1 Bluray surround sound system for free from my father and am trying to get it working with my desktop pc but have run into some weird issues. I'll link the system I have down below in hopes that it might help. So I have the system connected to my pc using an HDMI cable from my GPU (GTX 770) to the HDMI IN port on my bluray player / receiver. The issue is I am getting a noticeable hissing noise that goes away as soon as I unplug the hdmi cable. I've made sure that the receiver is also connected to the same powerbar as my pc. So it doesn't appear to be any issue with signal to noise ratio or ground loop feedback. There also appears to be a noticeable delay in the audio I am getting while playing games that support 5.1 surround sound. The other weird thing that is going on is that windows seems to be registering the bluray player as a second display. So when I turn it on and off my monitor goes blank for a moment while it sorts out the newly added "display" before returning to normal. Except that my mouse on the right of my screen will disappear which I can only assume is in the area where is thinks my new monitor is. So yeah some weird stuff going on while connecting this though HDMI. I don't know if anyone else has had these issues so I'd appreciate any feedback. My first step is probably going to go and pick up a toslink cable tomorrow. I know it doesn't fully support uncompressed 5.1 but at least then I can see if the issue persists while connecting a different input. Any feedback or tips for troubleshooting would be greatly appreciated. Thank you!
The system I have: https://www.lg.com/ca_en/home-theater-systems/lg-HB905PA
A link to the manual: https://www.lg.com/ca_en/support/manuals?csSalesCode=HB905PA.BCANLL
My motherboard just in case: https://www.msi.com/Motherboard/Z87-G45-GAMING/Specification
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Oh god, you're entering into a rabbit hole of hell, digital audio is a pain in the ass on PC.
HDMI does NOT do audio seperately - it is a display and audio combined. You need to run Video card -> receiver -> monitor
It will only work with "normal" TV resolutions and refresh rates, so 1440p or high refresh rate monitors work work
If the sound source changes between PCM, DD or DTS standards you can get a bit of delay as it changes (you can disable those in device manager by unticking some boxes for your HDMI audio)
optical is stero only for 99% of PC use, the hissing should not exist but might be because you have no display connected to the receivers HDMI output?
Bartok
6 (0.00/day)
Unfortunately I have an ultrawide display and it only has a dual link dvi connection. So I can’t hookup my monitor to the DVD player unfortunately.
Mussels
58,412 (7.78/day)
Oystralia
then you're doomed to always having an invisible second monitor, unless you actually connect a 1080p monitor or TV to it
You may find optical with less issues if you want stereo audio, but getting 5.1 audio out of optical on PC is another entire bucket of fun with only a very few, hard to find sound cards support real time encoding (which allows *all* audio to be 5.1, and not just DVD's and blu rays)
818 (0.34/day)
System Name Dell Inspiron 7375
Processor AMD Ryzen™ 7 2700U Mobile Processor with Radeon™ RX Vega 10 Graphics
Memory 16GB (total) 2400MHz DDR4 SODIMM
Video Card(s) Radeon™ RX Vega 10 Graphics
Storage SanDisk X600 SATA SSD 512GB
Display(s) BOE NV13FHM
Audio Device(s) Realtek ALC3253 (Dell Labelling) ALC255 (Real name)
Mussels
58,412 (7.78/day)
Oystralia
161 (0.07/day)
wild guess
did you try a dvi splitter
dvi also send sound
Bartok
6 (0.00/day)
wild guess
dvi also send sound
The only DVI cable I have on my pc is going straight from my GPU to my monitor so I don't think it would be an issue with that cable.
486 (0.15/day)
Processor Intel i7 4770k
Motherboard ASUS Sabertooth Z87
Cooling BeQuiet! Shadow Rock 3
Memory Patriot Viper 3 RedD 16 GB @ 1866 MHz
Video Card(s) XFX RX 480 GTR 8GB
Storage 1x SSD Samsung EVO 250 GB 1x HDD Seagate Barracuda 3 TB 1x HDD Seagate Barracuda 4 TB
Display(s) AOC Q27G2U QHD, Dell S2415H FHD
Case Cooler Master HAF XM
Audio Device(s) Magnat LZR 980, Razer BlackShark V2, Altec Lansing 251
Power Supply Corsair AX860
Mouse Razer DeathAdder V2
Keyboard Razer Huntsman Tournament Edition
Toslink is your best bet, as it's for audio only. There's also RCA cable option but you'll be limited to 2.1 only.
161 (0.07/day)
yeah but you can buy a dvi spliter and connect to receiver via hdmi dvi cable
just a thought i dont know if it will work but....
just a cheap solution
Bartok
6 (0.00/day)
As far as I know there are no dual link dvi to HDMI adapters that are actually dual link. They are all single link adapters even if they are advertised as dual link and they don't support the resolution of my monitor of 2560x1080 @ 60Hz. However, I did seem to fix the secondary display issue just not by going into display setting and clicking show only on monitor 2. So now I don't get the annoying mouse moving off the screen but I need to test the surround sound now. Currently rewiring a few speakers to see if that fixes the hissing problem I was having.
2,373 (0.55/day)
Audio Device(s) A LOT
Have you tried modified drivers?
Mussels
58,412 (7.78/day)
Oystralia
those are complicated, messy, work for only specific sound cards, and if they break they break your OS. not something i would recommend anyone do.
Bartok
6 (0.00/day)
I’ll give this a shot. Thanks for the suggestion.
Can you elaborate on why these may break your os system?
Mussels
58,412 (7.78/day)
Oystralia
they often need driver signature disabled (which messes with a few games anti cheat systems) and replacing files manually - if things screw up and you dont have the original files to replace them with, an OS reinstall may be the only way out
these mods are made by people who dont have the hardware to test them on, so they're always a gamble - i personally dont think its worth the effort and suggest one of those creative cards for real time encoding and going the optical route
3,156 (1.97/day)
United Kingdom
Mussels is correct enough. Always make sure its signed, and where possible you can see the files (not hidden behind an installer).
ALWAYS make a restore point or other type of backup.
