@lorry
If at all.
My last custom loop had about 4,5l coolant and the resorator is more than 2ft tall all metal incl heatsinknlike fins, and it took 30 min onnlow load before temps started to rise past starting temp (when pc was turned on).
with ryzen water temps arent the problem, mine never goes past 40*C,
cpu still goes up to 70*C, because of the "small" heatsink they have.
This is the main reason why almost all coolers perform similar,
the only difference is how silent/loud the fans are (no matter cooling type),
and what temps you will get on gpu/case etc.
If you plan on adding the gpu, i would recommend the 360 LT,
280s would allow for lower rpm fans and they make use of a wider rad (vs 240),
and if you really need the gpu added, just get a small 120 rad as add-on that can go to the rear of the case.
But usually using the aio to dump the heat outside the case, is the biggest improvement. Use the fans as push, easer to remove when cleaning fans/rad.
Thought about an airfilter?
20in box fan with a piece of screen filter (cut to size roll of filter for the range hood, if u want odor control).
Have the fan pull the air thru the filter (prevents fan getting dirty),
i recommend make a frame/box that allows for the filter to have some distance to the fan.
Amazon.com: PollenTec Box Fan Air Purifier Filter for Cleaner Air and a Cooling Breeze Washable, Reusable, Compatible with Lasko Models B20200 2301 3733 B20401 Frame size 20.5 x 20.5 Made in USA: Kitchen & Dining
smile.amazon.com
There is already a double mesh setup at the front as it is and surely adding another Very mesh to the front will choke off the air intake entirely?
Being totally realistic Harvey isn't going to be around for that much longer, he was 13 last Oct, he has had diabetes now for 4 years, he has arthritis, he is going blind. 12 is considered a good age for a Labrador so even without all the added medical conditions he is not expected to be around for that much longer, plus making anything these days isn't really too great an idea.
I will go with the standard 360 as that has the greater surface area compared to the 280, 43,200 compared to 39,200 and standard compared to the LT is 5mm thicker.
My biggest problem, no matter what I go with, will be the fitting. I will either somehow need to cut a large hole in the rad cover of the case, so that it can be fitted in one stage in its entirety, or take the fans off and fit those to the underneath of the fan cover and then the rad to the top.
Either way I will need to cut a hole to allow the tubing / pump through
Yeah, mine doesnt have post code display, just 4 debug leds.
The price of that Eisbaer 360 is pretty nice I think... Here too... it’s 120€.
Wasn't so much about the post code, more about the temp probe connector and it's damn bad positioning
Ok, have figured out a way to do this, due to the 43mm depth restriction.
What I do have in that case is Height at the top of the case - 50mm in height and over 150 width
What I have thought of is this - cut out the main section of the radiator shelf to allow the 360 (or even 280, but I am going for the 360 unless someone can persuade me, as it has more surface area) to drop in complete.
I have ordered some mild steel black angle (20mm x 20mm) to span the gap, screw or bolt that into place with a 20mm spacer in place and then attach the radiator and fans to that.
That will then mean that less than 35mm of the unit will enter down into the case, giving me 8mm clearance still, which will allow the ATX 12Vconnector cables to remain routed as they are now.
This will mean that the top of the radiator will be exactly level with the side venting on the top panel, so ventilation would not be compromised
Sorry for the crap picture, never been any good with paint, heh. Yellow is the section to cut out, to allow the rad unit to be dropped in, red would be the steel angle spanning that the radiator attaches to
This shows just How much space there is Above the radiator shelf
Thoughts
@Zach_01 @tabascosauz @Fry178 ?
Mine works between 24-25C idle and 27-28C max water temp, with CPU around 58-60C max temp. Tho it’s 280mm AIO and fans 700-1400rpm.
Remember though yours does have liquid metal not thermal paste, so that helps somewhat
Ooh, just saw this -
The
Eisbaer Aurora AIO is next on the list. This is a higher-end AIO cooler with full copper radiators in 240mm or 360mm sizes. Currently, Alphacool also has 280mm and 420mm versions planned for Q2 or Q3 2020. Pricing starts at €124.99 for the 240mm version and goes up to €144.99 for the 360mm version.
Aurora LUX RGB fans are also coming, with the key selling point being addressable RGB, but other specs include 800 to 2000 RPM, 35.6dB max noise level and 2mm H2O static pressure.
Our CES coverage continues, this time with Leo checking out the Alphacool suite, which was packed wi
www.kitguru.net
