Upgrade from Vista Ultimate to 7 Ultimate
421 (0.07/day)
Thailand
Processor AMD Phenom II 720 3x2,8 GHz BE
Motherboard MSI 870A Fuzion A770 SAM3
Cooling Scythe Zipang SCZP-1000
Memory Crucial 4GB DDR3 1600MHz Ballistix Sport CL9
Video Card(s) PALIT GeForce GTX 560Ti 1GB
Storage TOSHIBA 1000GB 32MB 3,5'' 7200 SATA III
Display(s) Gateway FPD2275W `22
Case Shinobi SH09A
Power Supply Thermaltake Toughpower W0116 750W
Software Windows 7 Ultimate 64bit
Is there any sense to do that?
What`s drawback of this upgrade? Is there any?
Drawbacks??? Some of your program settings may not migrate correctly or at all.
Other than than that, it should be all benefits and no drawbacks.
3 Words...AmAzInG OpErAtInG SyStEm
I have done it it works great. I say go for it.
Absolutely go for it, you will be amazed! Windows 7 is so much better than Vista that there is almost no comparison
I mean, upgrade without HDD`s formating. There`s an installation`s otpion to upgrade from Vista to 7.
The god thing is that you dont have to install all the stuff again.Just run the compabilty program it will say if you have any driver problems or programs that need uppdating.The bad is you loose the vista ult extras and windows mail but there workaround for that.My rig uses noe 24% less memory and feels faster.
Upgrade doesn't work like it used to. It just moves your old installation into a folder called Windows.old, then does a clean install. You still have to reinstall all of your programs, and move your user data from the Windows.old folder to your new install.
In other words, it's actually a completely fresh install, that just so happens to keep all of your old data in a separate folder.
You can only uppgrade and keed all data if you go from ult to ult.For example if you have home version of vista the its true what Wile E says.
How about 33% off your 3dmark06 score? Mine dropped from ~15,xxx to ~10,xxx roughly. I'm using ATI's drivers on a 3870x2 card fwiw.
I -just- installed it (32bit). My first impression is... "eh" It's Vista SE! :rolleyes:
I do like the GUI and some of the annoyances of Vista are "improved" such as configuring the shutdown button to do what you want like shutdown, restart, ect. I like that. I don't care much for the other changes to the start-bar. I liked the quick-launch buttons. I put all the apps I use often in there like IE, VLC, Yahoo Messanger, and other programs I want one-click access to. I haven't dug enough to try customizing it yet. I see I can add a new toolbar to it though. I could put my own quick-launch buttons in there I assume. Now to get rid of the default buttons.
Start-up and shut-down feel about the same as my XP rig. I roughly counted 40sec load time from the time it was booting untill I could click IE and have Google on the screen. Not too bad. Just a single 750gb WD RE3 drive. No RAID yet. Seems alot faster then Vista did. I was 1:15sec to Google with Vista on the same machine.
I'll update this if I get a chance. I'm about to try the 64bit version of 7 on my main computer right after I dump the XP image to a backup drive. :D
I dont see much if any difference in performance between vista SP2 and 7 RTM.
Got It!! -woot-
FYI Windows 7 did not effect my framerates or 3dm06 benchmarks on the system with the 4870. Maybe it's an issue with the 3870x2. So far I'm loving it. =)
Any test`s comparision?
The user migration tool should let you transfer user settings and documents. Windows mail is available for download for free from here. Part of the new Windows Live.
i got an FPS boost (2-5%) going from vista to 7, on a 4870 crossfire. (games, not 3dmark programs)
