- Nov 19, 2014
- 13 (0.00/day)
Processor | Amd ryzen 7 3700x |
Motherboard | Asus rog strix x470F |
Cooling | Corsair h150i pro |
Memory | 16gb @3400mhz corsair vegeance pro |
Video Card(s) | Amd sapphire rx 5700xt nitro+ |
Storage | nvme ssds + sata ssds (mix match 5x) |
Display(s) | Acer ed323quara x2 |
Case | Thermaltake tg32 view |
Audio Device(s) | Sound blaster z + logitech z906 |
Power Supply | corsair rm750i |
Mouse | Corsair m65 elite |
Keyboard | Corsair k95 platinum |
Hi ppl,
I know this isn't exactly hard drive related but it is belong near to this topic
.Last march i moved to Mexico,and in here are power problems on daily basis,1 or 2 seconds without power,voltage is jumping up and down etc.So at first i bought older UPC with nominal power 480w (around 4 years old) and changed the battery.It haven't been enough my PC always went off because battery would switch itself of when playing games.I thought it is because voltage converter itself degraded over the years.So i bought new one vica b flow 500w (cost me around 130 dollars) but this one wont even run the machine under the full load.It says overloaded and disconnect.I got desperate so start to play with it and found out that my old 480w UPC it s able to hold machine itself even under the load,without monitors and speakers when ac voltage isn't available.But the new more power full 500w will just show me overload and switch itself off.I have i5 2500k @ 4.6 ghz,water cooled,8gb ram @ 1996 mhz ,gtx 680 and 2 hdd and 2 ssd,corsair 850w psu.I did the math and it doesnt make sense max output of my pc should be no more than 450w.Is my math wrong,or just my new UPC isnt working properly?
