USB not recognized error
9,019 (1.38/day)
System Name Black Panther
Processor i9 9900k
Motherboard Gigabyte Z390 AORUS PRO Wifi 1.0
Cooling NZXT Kraken X72 360mm
Memory 2 x 8GB Corsair Vengeance RGB Pro DDR4 3600Mhz
Video Card(s) Palit RTX2080 Ti Dual 11GB DDR6
Storage Samsung EVO 970 500GB SSD M.2 & 2TB Seagate Barracuda 7200rpm
Display(s) 32'' Gigabyte G32QC 2560x1440 165Hz
Case NZXT H710i Black
Audio Device(s) Razer Electra V2 & Z5500 Speakers
Power Supply Seasonic Focus GX-850 Gold 80+
Mouse Some Corsair lost the box forgot the model
Keyboard Motospeed
My dad just bought an HTC Desire phone. He is not interested in synching it with his pc, but whenever he plugs the phone in through USB it gives an error saying that there was a malfunction and usb drive not recognized. We tried it in 3 different pc's and it gives the same error.
Installing the HTC Sync driver didn't work either - the software says the phone is offline, and it still pops up on the bottom right of the pc monitor that there was a malfanction and the usb is not recognized.
Am I missing something or could it be that the cable or phone is faulty?
3,471 (0.57/day)
System Name Acer Aspire V3-771G-53218G75Maii
Processor Core i5 3210M (2,5-3,1Ghz)
Memory 8GB DDR3 SODIMM
Video Card(s) Geforce GT650M
Storage Samsung 830 256GB - 750GB Toshiba drive
Software Windows 7 x64 Home Premium (non-acer-bloatware)
PC specs? What OS is this in? I have a Desire which works just fine...
9,019 (1.38/day)
Processor i9 9900k
Keyboard Motospeed
We tried it in a E7500 2GB RAM Win 7 x86, in a Q9400 2GB RAM Win 7 x86 and in laptop 1.6Ghz pentium 1GB RAM XP x86.
So you mean you plug your Desire and it is instantly recognized like a drive (my LG Arena works like that too)...
3,471 (0.57/day)
When I plug my Desire in it asks me what I wanna do (charge, USB disk, those kinds of things) and the drive shows up. Both in WinXP x86 (work) and Win7 x64 (home)
Got another micro-USB cable to test?
9,019 (1.38/day)
Processor i9 9900k
Keyboard Motospeed
This one lights up and starts charging, and this appears on the pc monitor:
If I click the message I get this:
:ohwell:
I don't have a spare cable, but guess there's no choice except getting one...
3,471 (0.57/day)
Well as my Desire does ask me the question, you might have, at some time, selected to use the phone as a modem and ticked the "Don't ask me again" box. I'm not that much into the OS but you might wanna search how you can reset that.
4,966 (0.85/day)
System Name i7-PC / HTPC / iMac
Processor i7 3820 / Phenom II 940
Motherboard GIGABYTE G1.ASSASSIN2 / M3A79-T Deluxe
Cooling Corsair Hydro H100i / Scythe II (HS only)
Memory G.SKILL Trident X Series 8GB (2 x 4GB) DDR3 1600mhz / 4GB DDR2 1066 (@800) Corsair Dominator
Video Card(s) GB Radeon HD 7950s 3GB / GB Radeon HD 7950s 3GB
Storage 2x 80GB Intel X-25, 2x600gb SATA, 1x1tb 5400RPM storage /1x600GB, 3x500GB,1x160,1x120 SATA
Display(s) 1x 27" Yamakasi / Vizio 42" HDTV
Case Lian Li Lancool PC-K58 / Antec 900
Audio Device(s) HT Omega Striker 7.1 / Onboard and HDMI from ATi Card
Power Supply PC Power & Cooling 750W / 610W
Software Ubuntu / Windows 8.1 Pro / OS X / PHPStorm / Gaming
this i think is most likely - I have an evo and it too asks me every time, as I sometimes do and sometimes do not want to use it as a drive.
I recommend getting an AC wall->USB adapter - one should have came with the phone. they are cheap, convenient, and will charge the phone faster than from a computer's usb port.
9,019 (1.38/day)
Processor i9 9900k
Keyboard Motospeed
He had ticked that box but setting it to sync, and he did it to try to solve this same problem.
I've done 'set phone to factory default' now just in case....
Edit: After setting to factory default, now the phone asks me if I want to active-sync or use as disk drive. I choose disk drive but still get the precise error in screenshots above.
4,966 (0.85/day)
yeah it should give you the option to charge only, if it doesn't do that - maybe there is something wrong with it ?
9,019 (1.38/day)
Processor i9 9900k
Keyboard Motospeed
After more googling I found advice to stick it to one of the back USB's because they supply more voltage (really?)
Anyway, this worked, but I got a popup saying that I need to format the drive before I can use it :eek:
Is it safe to do this or would my dad end up with a working usb disk instead of a working phone?
3,471 (0.57/day)
Hmm, maybe his mem card isn't formatted yet. Sounds weird tho.
9,019 (1.38/day)
Processor i9 9900k
Keyboard Motospeed
I removed the micro-sd card from the phone and re-attached the phone to the pc and still got the message that I need to format 'drive e:' :wtf:
4,966 (0.85/day)
i wouldn't, especially after the mem card is removed.
95Viper
Super Moderator
13,308 (2.20/day)
Well, on my LG you have to tell the phone, first, to use external memory device or the the internal memory.
Just saying...:)
If you don't, or don't have a card plugged in, it is on internal memory , by default.
(Most) phones will format the card and set up the directory structure when you plug it in and turn it on.
9,019 (1.38/day)
Processor i9 9900k
Keyboard Motospeed
I guess this is important - he just told me that yesterday he plugged phone onto laptop and (using his words) "the computer was loading or installing something from the phone"....
Then he was distracted and just pulled out the USB without letting it finish what it was doing :eek: :ohwell:
It even worked because he had installed music on the phone (and I was like huh how had you managed to install music.....)
It was only after this incident that every computer we plug in the phone insists on wanting to format it.
______________________
This makes sense, once I pulled out a pendrive like that and I kept getting the message that it needed to be formatted to be used again.
But well, formatting a pendrive is routine but formatting a phone especially just the phone without the micro-sd card just sounds not good..
Completely Bonkers
2,576 (0.39/day)
Processor Mysterious Engineering Prototype
Motherboard Intel 865
Cooling Custom block made in workshop
Memory Corsair XMS 2GB
Video Card(s) FireGL X3-256
Display(s) 1600x1200 SyncMaster x 2 = 3200x1200
Software Windows 2003
Format it. Fix FAT. Start over.
Oh, and don't forget to teach dad lesson about safely-remove-usb device.
PPS. Twighlightzone, is this some kind of freaky role-reversal? LOL. Anyway, hope it works out fine, if not warranty return it
de.das.dude
Pro Indian Modder
9,249 (1.70/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad | Old Monke
Case Ant Esports Tempered case | Thinkpad | NZXT Guardian 921RB
Audio Device(s) Logitech Z333 | Jabra corpo stuff | Some USB speakers
Mouse Logitech G400 | nipple | Dell
VR HMD ;_;
have you tried bluetooth?
9,019 (1.38/day)
Processor i9 9900k
Keyboard Motospeed
Won't formatting a phone remove its functions as a phone?
The pc's here don't have bluetooth.
Edit: By golly I tried to scan it several times without success, then suddenly it was Win 7 which prompted me to scan, I did and problem is solved now :)
