Using an Android Tablet as a PC Display?
31 (0.01/day)
System Name My HTPC Games Build
Processor Ryzen 5 2600 Hex Core 12 Thread CPU
Motherboard ASUS AB350 Gaming Socket AM4
Cooling Cooler Master Hyper 212 LED Turbo
Memory 32GB Crucial Ballistix Sport DDR4 2400MHZ (4x8GB)
Video Card(s) Gigabyte G1 Gaming 980TI 6GB
Storage Mushkin Scorpion Deluxe 1.92TB PCIE SSD, ADATA SU800 256GB SSD M.2 (SATA MODE)
Display(s) Digihome 55" UHD TV via Yamaha RV-V377 Receiver
Case Cooler Master Full Tower
Audio Device(s) Motherboard/GPU (No Sound Card)
Power Supply Corsair CX850M 850 Watt
Mouse Logitech K400
Keyboard Logitech K400
Software Windows 10 Professional
I have an android tablet with a large 14-inch display (Virgin Media Telly Tablet) that I would like to re-purpose as a computer display. The thing is I need it to work as seamlessly as possible, ideally just like a TV, as I am intending to use it for a relative who has little computer knowledge. I am fine to do the initial set up for them, but after that I really need it to work with just a couple of easy steps to be any good.
I know programs for this exist, but have no knowledge of them or their set up. However, I notice most assume the Android device is a secondary display. However, I am looking to make the Android device the primary (and ideally only) display once set up, is this possible? The reason is I want to stream a game from Steam to the tablet and games generally will only output to the main display by default. The game is slow paced, so minor lag or delay is acceptable. The computer is in the same room, so will be using the game pad and keyboard from that, so I only need the tablet to be a ‘dumb’ display (with sound), I don’t need any touch functionality at all.
Ideally wireless would be best, but it may be possible to run a long USB lead as I have read that wired can be a lot smoother and higher resolution (the tablet is full HD so would be nice to use its full resolution).
Has anyone had any experience with using an Android phone or tablet as a computer display and how did you find it? Is there one program that works particularly well for this task?
So to sum up is it a practical and simple solution to use an Android device as a primary display like this for (casual) gaming, or would I be better off selling the desktop PC and saving for a low-end laptop instead and playing the games directly on the there?
Thank you in advance for any replies.
FreedomEclipse
~Technological Technocrat~
24,780 (3.76/day)
(currently) Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Eeeeeerrrrrrrr from my experience this has been done before. you would need to install some software on your pc to set it up as a server but once the app on android and PC are paired, you can use the tablet to control the PC.
I cant remember the name of the app but it does exist.
Deleted member 67555
Unified remote.
You have to have a tablet that can reproduce the display resolution of the monitor though.
Not sure if it's still feature rich or available but also Remotr.
14,545 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Just buy a cheap monitor and hook that up, forget the tablet, it's too small to be practical as a monitor anyway.
31 (0.01/day)
Mouse Logitech K400
"Just buy a cheap monitor and hook that up, forget the tablet, it's too small to be practical as a monitor anyway. "
I have a spare monitor I could use but the reason I am suggesting the tablet instead is because I don't want wires trailing across the room between the PC and the display as it is in a living room setting rather than a conventional PC at a desk. I could maybe hide a thin USB cable for the tablet but no chance of hiding the mains power cable and DVI cable for a monitor sadly....
2,695 (0.42/day)
System Name panda
Processor 6700k
Motherboard sabertooth s
Cooling raystorm block<black ice stealth 240 rad<ek dcc 18w 140 xres
Memory 32gb ripjaw v
Video Card(s) 290x gamer<ntzx g10<antec 920
Storage 950 pro 250gb boot 850 evo pr0n
Display(s) QX2710LED@110hz lg 27ud68p
Case 540 Air
Audio Device(s) nope
Power Supply 750w superflower
Mouse g502
Keyboard shine 3 with grey, black and red caps
Software win 10
Benchmark Scores http://hwbot.org/user/marsey99/
Vysor is an app that does it across usb.
But you can get wireless hdmi and only have 1 cable to a real monitor and get about the same input lag and a better screen.
de.das.dude
Pro Indian Modder
9,249 (1.70/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad | Old Monke
Case Ant Esports Tempered case | Thinkpad | NZXT Guardian 921RB
Audio Device(s) Logitech Z333 | Jabra corpo stuff | Some USB speakers
Mouse Logitech G400 | nipple | Dell
VR HMD ;_;
Google chrome remote desktop. Thats the most reliable one i found. Its has decent latency as well.
I use this as a PC remote as well.
11,880 (2.15/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
I have'nt got games to work on it, though I have not tried too hard either.
207 (0.09/day)
Processor 3700x @ 4.3
Motherboard Crosshair 7 hero
Cooling Kraken X62
Memory 16GB Trident-Z 3200
Video Card(s) EVGA RTX2080 XC Ultra
Storage Samsung 960 evo 500gb NVME
Display(s) ASUS ROG Swift PG348Q
Case NZXT H500
Audio Device(s) Phillips SHP 9500s.....Audio Technica AT 2035 microphone.....Scarlett 2i2 audio interface.
Power Supply EVGA 850W Supernova G2
Mouse Model O
Keyboard Corsair K65
Get a cheap laptop and a Steam Link.
6,143 (1.12/day)
System Name RemixedBeast-NX
Cooling Dell Standard
Memory 24GB ECC
Mouse Logitech G700s/G502
Keyboard Logitech K740
VR HMD Linktr.ee/remixedcat // for my music ♡♡
Software Linux Mint 20
Benchmark Scores Network: APs: Ubiquiti Unifi AP-AC-LR and Lite Router/Sw:Meraki MX64 MS220-8P
get a VNC server/ client and use that. I use tight vnc server/clent on windows. lots of choices for android clients.
6,143 (1.12/day)
Memory 24GB ECC
4,914 (1.48/day)
Processor Intel Core i7-13700 PL2 150W
Cooling Cooler Master RGB Tower cooler
Memory Crucial Pro DDR5-5600 32GB Kit OC 6600
Video Card(s) Gigabyte Radeon RX 9070 GAMING OC 16G
Storage 970 EVO NVMe 500GB, WD850N 2TB
Case Corsair iCUE 4000D RGB AIRFLOW
Audio Device(s) EVGA NU Audio, Edifier Bookshelf Speakers R1280
Power Supply TT TOUGHPOWER GF A3 Gold 1050W
Software Windows 11 Professional v24H2
6,143 (1.12/day)
Memory 24GB ECC
4,914 (1.48/day)
basically what I posted.. lol.. but yeah the portable monitor seems like the more elegant solution for this. less kludgy
But it's only $160 for no touch or $230 for touch.
