Using internal hard drive externally for backup
62 (0.05/day)
Hi guys, I have a question. Does an internal hard drive last longer than external drive? I have an extra internal hard drive, not sure whether I use that externally with sata to USB cable or buy an external drive for backup data.
I heard that external drive is definitely going to break as it has moving parts? Just the matter of time they said.
Toothless
Tech, Games, and TPU!
9,281 (2.52/day)
Washington, USA
System Name Veral
Processor 5950x
Motherboard MSI MEG x570 Ace
Memory 4x16GB G.Skill TridentZ
Display(s) Acer Nitro XZ342CK Pbmiiphx + 2x AOC 2425W
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
If it's on, it's wearing. Simple as that. If you keep moving it, it'll wear and/or die out.
1,328 (0.31/day)
Processor i7-13700k
Motherboard Asus Tuf Gaming z790-plus
Cooling Coolermaster Hyper 212 RGB
Memory Corsair Vengeance RGB 32GB DDR5 7000mhz
Video Card(s) Asus Dual Geforce RTX 4070 Super ( 2800mhz @ 1.0volt, ~60mhz overlock -.1volts. 180-190watt draw)
Storage 1x Samsung 980 Pro PCIe4 NVme, 2x Samsung 1tb 850evo SSD, 3x WD drives, 2 seagate
Display(s) Acer Predator XB273u 27inch IPS G-Sync 165hz
Power Supply Corsair RMx Series RM850x (OCZ Z series PSU retired after 13 years of service)
Mouse Logitech G502 hero
Keyboard Logitech G710+
Depends on the external you buy, a lot of them are just internal drives plugged in to a usb or network card with a case around it. All drives will break at some point but externals tend probably break more cause small case and more likely getting moved around to diff machines more offen.
I have had very good luck with leaving drives in my comp i leave on 24/7. IMO turning them off and on is more wear on them then just leaving them powered on.
Toothless
9,281 (2.52/day)
Washington, USA
System Name Veral
Processor 5950x
VR HMD HP Reverb G2
My main stuff just stays on. Can't fail if it's not off to fail.
62 (0.05/day)
Yeah that's what I heard.
It would be better for me to just use the internal hard drive as backup as well because I can save money by not having to buy an external drive.
I shutdown my laptop every night, is it bad?
Toothless
9,281 (2.52/day)
Washington, USA
System Name Veral
Processor 5950x
VR HMD HP Reverb G2
It's been proven that shutting down cold and starting all the time is not as good as leaving it on, but YMMV.
1,328 (0.31/day)
Processor i7-13700k
i have 3x4tb drives, one is at 61000 hours yes 61k, other 2 are 68500 hours. Respectively 7-8years of powered on time still 0 problems
Mussels
Freshwater Moderator
58,413 (8.18/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Whatever you get, you'll want it powered off as much as possible and moved as little as possible.
Modern drives have "green" features to auto power down no matter what the OS says, so that's not much of a thing any more.
Toothless
9,281 (2.52/day)
Washington, USA
System Name Veral
Processor 5950x
VR HMD HP Reverb G2
Flash backs to WD Caviar Green.
12,280 (2.36/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
Six of one, a half dozen of another. Its doesn't matter. To many variables to say ether way. Nothing is definitive
It's why we have back ups
8,944 (3.35/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
They can always fail anyway. I had 3 HDDs fail in one year and I decided to never touch mechanical drives again.
2,207 (0.87/day)
Well I have a 13 year old TV... & I bought a External hard drive around that time It's still going strong as of today.. It s always recording when TV is on for live TV pausing, but it also has TV films recoding going back the full 13 years..
