using the GPU fan header for temperatures
100 (0.05/day)
Milton Keynes,England
System Name AMD™ Red Tiger
Processor AMD™ Ryzen™ 7 3800XT @ 4700mhz
Motherboard MSI™ X370 Gaming Carbon Pro
Cooling XSPC™ Raystorm™ dual XSPC D5 pumps 2x 360 EX radiators 6x Noctua™ NF-F12 Industrial™ 3000rpm
Memory Avexir™ Blitz™ 3200mhz 16.18 @ 3200mhz
Video Card(s) Sapphire™ Radeon™ RX 7900XTX under Alphacool™ water block
Storage 1x Intel™ 660p 1TB 1x Seagate™ 2TB 7200RPM
Display(s) Electriq™ VM280UHD 4K 60hz
Case Cooler Master™ Cosmos™ Pure Black with 5x Coolermaster™ bladeMaster™
Audio Device(s) Creative SB X-FI with Logitech™ X540 5.1
Power Supply EVGA™ 1000w G2
Mouse EasySMX™ 4000dpi Red led on MSI™ Lava Dragon giant mouse mat
Keyboard Rii™ K66 Red switch mechanical keyboard with red led
Software Windows™ 10 Home
Benchmark Scores 13000 3dMark™ Time spy.
hello,
i was told i could use the fan header on the gpu to control the fans, which is a nice idea as i think its the hotest thing in the loop.
i use my motherboard fan headers for my PWM fans.
using a older MSI™ X370 gaming carbon pro (i brought an updated cpu for it, before support for the AMD™ R7 5800x3d came out.)
is there a way of routing the signal though the mother board please?
at present it lets me choose cpu or motherboard for temperature.
best regards,
MrPerforations
11,880 (2.15/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
hello,
best regards,
MrPerforations
Not easily but, technically with a one fan to two fan adapter cable between the fan and GPU header.
Then have just the rpm wire(usually yellow)connected on that second split you added and the other end to a motherboard fan header.
That's a double improvisation though but afaik the only way.
A lot of pumps do similar.
Not a true temperature reading but it will scale with GPU temperature.
