Wazzle's watercooling system
wazzledoozle
5,358 (0.70/day)
Seattle
Processor X2 3800+ @ 2.3 GHz
Motherboard DFI Lanparty SLI-DR
Cooling Zalman CNPS 9500 LED
Memory 2x1 Gb OCZ Plat. @ 3-3-2-8-1t 460 MHz
Video Card(s) HIS IceQ 4670 512Mb
Storage 640Gb & 160Gb western digital sata drives
Display(s) Hanns G 19" widescreen LCD w/ DVI 5ms
Case Thermaltake Soprano
Audio Device(s) Audigy 2 softmod@Audigy 4, Logitech X-530 5:1
Power Supply Coolermaster eXtreme Power Plus 500w
Software XP Pro
Well Urylin has provided most of what I need for a watercooling system, so far I have-
  • Volcano 4005 block/radiator
  • C-Systems CSP750 120 gph pump
  • Tygon 3/8id tubing
  • dual drivebay reservior
  • AXP Shim
Im going to go get some barbs tonight or tomorrow (or whenever I get to it)
But the Volcano 4005 wont fit in my case, so ill have to wait until after xmas to get a new case to fit it into. Im thinking a chemning full tower :toast:
Awesome... lots of pics. Going to get a gpu block as well?
-Dan
-Dan
Probably wont get a GPU block, air cooling is doing fine.
Ill get pics up tomorrow :)
Oh you know you'll want a GPU block eventually.:p Congats on the system man. Pray for no leaks!
What motivated you to go WC? Wanted to get cooler, just quieter, or both?
I need to beat the heat! I idle in the mid 40's :eek:
I'm no XP expert, but isn't that about average for an XP? My friend's old 2000 XP ran at about 50º-53º idle OC'd to 2400 speeds.
Edit: 700th post! w00t!
i dk mine runs bout 37ºC at 3200 spds from 2.0
Well then again Jason's was a Thoroughbred. Makes sense that Bartons would be cooler with the larger core size.
hehe .. it's a flippin monster :cool:
lets get wet! :rockout:
take your time in setting up/arranging your loop and do leaktest ;)
if i can be of assistance just ask
:toast:
