WD problems
1,227 (0.18/day)
United Kingdom
Processor Intel 10 Core i9 10900K Comet Lake CPU/Processor
Motherboard Gigabyte Intel Z490 AORUS MASTER ATX Motherboard
Cooling Noctua Intel/AMD NH-D15 Silent CPU Cooler
Memory Corsair 32GB ( 4x8) DDR4 Vengeance LPX 3000MHz Memory
Video Card(s) Zotac NVIDIA GeForce RTX 3080 8GB AMP! Extreme Turing Graphics Card
Storage Samsung 970 EVO PLUS 500GB M.2, Samsung 970 EVO Plus 1 TB PCIe NVMe M.2
Display(s) ASUS ROG Swift PG279Q 27" 2K WQHD 165Hz IPS G-Sync 2K Gaming Monitor, Sony Bravia 49" 4k uhd tv
Case NZXT Phantom 410 Black Orange Special Edition
Audio Device(s) Sound BlasterX AE 5 RGB PCIe Gaming Soundcard
Power Supply Corsair RM1000
Mouse Roccat ROC-11-812 Kone EMP Max Performance Razer Basilisk x Hyperspeed Wireless Gaming Mouse
Keyboard Roccat isku/ fx
Hi I recently bought a new hard drive on 30/08/2011 to replace my faulty one anyway the new hard drive is a Western Digital 750gb WD7502AAEX Caviar Black,Sata 6gbs,7200rpm,64mb cache, it was working ok showing no problems then i started the pc and it would just sat with a black screen and would not go into windows after a while a message came on in the top left corner sayin Disk Error so i rebooted it still black screen and message A Disk Read Error Occurred. I tried to clone the back up to it but there was no E drive showing so I then tried to Format it and reinstall windows but it wouldn't let me, Message came up Windows cannot be installed to this Disk. The Computer Hardware may not support booting to this disk Ensure that the disk controller is enabled in the computer Bios, no matter what i do it just sits there and clicks should i RMA it.
Tried to clean master boot record? Cloning often messes up everything.
On windows just do Diskpart - clean, or boot up some Linux and erase everything... I've had these problems often when dissembling some RAID disks...
Check the power and data(sata) cable (both ends of the sata cable, at drive and motherboard or add-on card).
You may want to try a different sata cable.
Check you bios settings for the drive.
Make sure it shows up in the bios ok.
EDIT: you may, also, want to try booting from the Windows install disk and running the system repair option.
See option two, here: Using a Windows 7 Installation or System Repair Disc
If its clicking then its dead.
Its RMA time!
Hi when i try this it doesn't show up Create and format a hard disk partition.
Dead Man Walkin... :D
RMA it...
Thanks I am getting a bit fed up with WD didn't have this many problems with seagate.
If you have a COM Port emulator and skills in Hyper Terminal :D
I've reseted smart for my fishes twice... :D Nothing is perfect...
Just swapped my Samsung F4 after only a week of purchase :D
To be honest, the next drive in my buy list is that new Hitachi Des(th)kstar 1TB single platter... :roll:
Ha thats interesting as its the other way around for me thats why ive used WD this past few yrs as i have found Seagate drives seem to fail alot more often.
Each to there own though.
If you have a working Windows computer:
in the start menu type "computer management"
from there click on storage
If the disk isn't recognized it's RMA time if it is create a healthy drive partition and format and then reinstall.
Hi tried computer management again and all that is showing is disk 0, (C:) drive and DVD-ROM (D:), I think it is time to get in touch with Scan for an RMA number and label. thanks for all the help and advice.
cookiemonster.
Sorry to hear that...Like Melvis I use WD exclusively now because of past and current issues with Seagate and Hitachi....Guess that just goes to show it's luck of the draw...
Ive had zero issues with WD, seagate now is a different story :(
I've had issues with both, but I still lean towards WD... just a creature of habit.
Hi I recieved the RMA details from Scan I hope to get it posted tmoz, as you said maybe just unlucky this time, it is years since i had a Seagate the one i am using just now is a WD, hopefully they will find the RMA one faulty and replace it, i will probably stick with WD better the devil you know. I will let you know what happens.
Between Seagate and WD I believe it's luck of the draw.
I have seen just as many failed WDs come in as Seagates where I work.
Hi just recieved this from Scan
Current status of your RMA: Awaiting Replacement / Credit
Hi I have just been offered a
750GB Western Digital WD7500AARS Caviar Green, 3.5" HDD, SATA II - 3Gb/s, 5400rpm, 64MB Cache, 8ms, Free-Fall , NCQ
as a replacement from Scan for the caviar black above which was faulty and they are out of stock and don't know when they will get them in, is the Caviar Green as good and okay to use as a main hard drive
Hi just been on the phone to Scan and they are replacing it with the
750GB Western Digital WD7500AARX Caviar Green, 3.5" HDD, SATA III - 6Gb/s, 64MB Cache , 8ms, NCQ, OEM
thats the one i thought the were sending originally.
Hi jsfitz I have just been on the phone to Scan to cancel the above hard drive and they are replacing it with the
It will have a slower access time, which is normally why you wouldn't want a green drive as the primary OS drive.
Looks as if I have been done, just have to use it for backing up myother Hard drives to
