immab33tch
- Jun 22, 2015
- 19 (0.01/day)
Hi guys i am new here.. Im a web designer and i really need help on building a computer. I use teamviewer, photoshop, fireworks and dreamweaver, sometimes we use after effects and premiere for presentation, we also use CAD tools like sketchup to do some 3d layout. I can not find anywhere the perfect desktop build for web developers. My max budget would be $1200
I already have this: mx100 128gb SSD for OS and applications and 2 dell u2412hm monitor.
Designers prefer mac for the reason that they can use windows on the same machine but i cant afford it cause its really expensive.
My motherboard should not be fancy as long as it can run the processor well and ram is compatible.
I wont be overclocking but if non k is just few dollars savings over K version well i would jsut pick the K
GPU, this one really confused me but i am pretty certain that gtx 750 TI would be just fine im not sure. I use dual monitors.
RAM i plan on using 16gb as long as its compatible with the motherboard
Power supply, modular and non modular i wouldnt be needing the fancy feature right? cause my clients wont look at whats inside my cpu lol
I need to save on things that i dont actually need, so pls help me.
Thanks in advance
Thanks in advance
