- Nov 12, 2014
- 798 (0.21/day)
Processor | I5 4690K @ 4.8 Ghz |
Motherboard | Gigabyte Z97X Gaming 7 |
Cooling | Swiftech H140X |
Memory | 16GB Crucial BallistiX 1866Mhz |
Video Card(s) | GTX 1070 G1 Gaming |
Storage | 850 PRO 1TB SSD, 840 EVO 500GB SSD, 850 EVO 500GB |
Display(s) | Nixeus EDG 27-Inch IPS 1440P, 144HZ 16:9 |
Case | NZXT H440 Red/Black |
Power Supply | EVGA Supernova G2 750W |
Mouse | G600 |
Keyboard | G710+ |
Software | Win 10 64B |
Bunk meaning?I see a bunch of bunk sensor readings so who knows but its certainly possible tho if your ambient temps are low and your case has great airflow and you have a cooler running chip then most samples I have seen reviewe
also if you are getting errors under prime your oc is not stable ... you have some room with voltage but not temps I would be getting some better cooling or at least a second fan ..
the difference between the evo and non evo is 3 to 5C you are pushing toward 60 and then there is the fact that there is quiet a bit of fudge room going on with the TDP of the 8350
And yeah, thats why I have it at 4.3Ghz.... so I don't have to change voltages. I really don't need to OC more. But my point was the temps were still relatively good for the time running prime. My ambient temp is 20c.
