Weird problem: Overclocking potential decreased??
1,571 (0.30/day)
Kolkata, India
System Name Coffee | Maximus
Processor Intel Core i7 9700K @ 5.2 GHz with AVX/4.8 GHz cache | i7 9700KF @ 5.0 GHz/4.7 GHz cache
Motherboard ASUS Maximus X Formula | ASUS Maximus VIII Ranger (modded BIOS for Coffee Lake)+TPM2.0 module
Cooling Cooler Master ML240 Illusion | Cooler Master ML120L RGB
Memory 2*16 GB (32 GB) Kingston Fury Beast @3600 MHz CL17 | 4*8 GB (32 GB) HyperX Fury @3200 MHz CL14
Video Card(s) Zotac RTX 3070 8 GB Twin Edge OC | Galax RTX 2060 Super 8 GB
Storage Samsung PM981a 1TB+Crucial P5 1TB+480GB SATA SSD+2 TB HDD | Crucial P1 500GB+2.5TB HDDs
Display(s) LG OLED 55 G3, 4K 120 Hz, VRR, ALLM, GSync, FreeSync | Samsung 43AU9070 4K TV, VRR, ALLM
Case Corsair Crystal 460X RGB | Lianli Lancool 215
Audio Device(s) Creative Sound Blaster Z SE w LG SC9S Dolby/DTS | Realtek ALC1150 (Supreme FX) w 2.1 speakers
Power Supply ASUS ROG Strix 750G (80+ Gold) | Cooler Master MWE 650 V2 (80+ Bronze)
Mouse Cooler Master MM731 19000 DPI gaming mouse
Keyboard Cooler Master CK721 65% mechanical gaming keyboard (tactile)
Software Windows 11 Pro x64 |Windows 11 Pro x64
Benchmark Scores Cinebench R20 MT 4200,ST 547 CPU-Z MT 4871, ST 620 | R20 MT - 4158, ST - 534, CPU-Z MT 4798, ST 603
I have a problem again. I had an Asus M4A88TD M-EVO/USB3 motherboard. There, I kept a 24 * 7 overclock with the following settings.
CPU 3.78 GHz, RAM 1728 MHz and NB 2808 MHz.
Now when I try to give it with my present board, I get instability within 5 mins in Prime 95 in the max heat mode(large FFT)
Any ideas?
Is it failing because of RAM?
The CPU is stable at 3.8 GHz at the same voltage with 1600 MHz RAM. Is it failing because of the IMC? Or the RAM maybe? Help is appreciated.
why you expect problems to come from ram when you have changed only mb.
it is more likely your new mobo isnt as OC capable as your old one
Yeah logically, that is correct. But how can it happen? I mean my old board had 4+1 phase VRM without any heatsink and this one has 4+2 phase with a kickass heatsink. Add to that the old board had older AMD 880G chipset and this one has 970. How can it happen? Do I require more voltage?
Try changing the LLC(Load Line Calibration). Correctly setting up the LLC can increase the stability of your voltage.
all sorts of things can throw out an oc, even different bios. (what is the plural for bios btw)
tip for the future, when changing anything that has an affect on cpu always go back through the overclock procedure to find your desired OC.
BIOSii, BIOSes, BIOS', All The Things, BIOSates.
All MoBos act differently. clocking to 4.8 on a Sabertooth and CHVF was considerably different, the sabertooth was basic and faster, the CHVF was complicated and required many details.
Ok. I will try different settings. I have eliminated a few things. CPU works at 3.8 GHz perfectly with RAM at 1600 MHz and IMC at 2800 MHz. But fails when RAM is at 1728 MHz and IMC is at 2808 MHz. Considering the IMC frequency to raise by only 8 MHz, I suspect the RAM. I forgot my previous OC settings(I had them stored in the OC profiles of my previous board). What do you think?
maybe due to timings, especially if theyre tighter than before.
Have to check it. Thanks. :)
EDIT: I am searching my posts in TPU if I ever shared the BIOS settings. :p I even wrote them in my system specs. But they are no more. :(
UPDATE: She's back. :D
Ran it for 10 mins as you can see in the large FFT mode(max stress and max heat). A few hours of gaming and I will be sure. :)
I just bumped up the CPU/NB voltage to 1.3V LLC on(don't remember what I did on my old board) and memory voltage to 1.59V(I am sure I used that only in my old board) and presto she's stable.
Cheers. :toast:
44 mins of Prime95. I guess that's enough. :D
AIDA cache and memory score. :)
Some one donate me some good RAMs please. :p I am doing this with 2*2 GB Kingston value RAM(low profile, no heatsink, 1333 MHz 9-9-9-24 stock).
i got a single ripjawx 1600mhz 4gb stick not being used LOL
and an AMD 1333mhz one haha
Whoa that's too much to ask for. :o And especially considering the price of RAMs now. :p
If you are comfortable, we can have a deal. Problem is shipping charges. Too much from England to India. :(
id happily ship any of my spare stuff, but ya right shipping stuff to india would be costly.
and its more than likely to get broke.
Hmm. :( Maybe I will upgrade it in a few months. 4 GB is too mainstream these days. :p Wanna get a 2*4 GB kit at least 1600 MHz. Will sell the Kingston Value RAMs I got now. And a new GPU- A 7850 probably. ;)
