System Name | RyzenGtEvo/ Asus strix scar II |
Processor | Amd R5 5900X/ Intel 8750H |
Motherboard | Crosshair hero8 impact/Asus |
Cooling | 360EK extreme rad+ 360$EK slim all push, cpu ek suprim Gpu full cover all EK |
Memory | Gskill Trident Z 3900cas18 32Gb in four sticks./16Gb/16GB |
Video Card(s) | Asus tuf RX7900XT /Rtx 2060 |
Storage | Silicon power 2TB nvme/8Tb external/1Tb samsung Evo nvme 2Tb sata ssd/1Tb nvme |
Display(s) | Samsung UAE28"850R 4k freesync.dell shiter |
Case | Lianli 011 dynamic/strix scar2 |
Audio Device(s) | Xfi creative 7.1 on board ,Yamaha dts av setup, corsair void pro headset |
Power Supply | corsair 1200Hxi/Asus stock |
Mouse | Roccat Kova/ Logitech G wireless |
Keyboard | Roccat Aimo 120 |
VR HMD | Oculus rift |
Software | Win 10 Pro |
Benchmark Scores | laptop Timespy 6506 |
System Name | Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022) |
Processor | R7 5800X @ Stock | i7 12700H @ Stock |
Motherboard | Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231 |
Cooling | Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling |
Memory | TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16) |
Video Card(s) | Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W |
Storage | 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD |
Display(s) | Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in |
Case | Corsair 600C - Stock Fans on Low | Stock Metal/Plastic |
Audio Device(s) | Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29) |
Power Supply | EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light) |
Mouse | Logitech G502 | Logitech M330 |
Keyboard | HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW) |
Software | Windows 11 Pro x64 | Windows 11 Home x64 |
The idle test will consist of the CPU sitting idle at the desktop for 15 minutes. This will allow for a stable temperature reading that will be recorded at the end of those 15 minutes.
Wprime's and AIDA64's CPU test represent typical multi-threaded loads. Both offer consistent results, with one being a benchmarking application and the other a stability test. Both are run for 15 minutes before the peak reading during the test is recorded and taken as the result. This test lets enthusiasts know what temperatures they can expect to see with games and applications. Wprime is set to eight threads while AIDA64 is configured to stress the CPU, FPU, cache, and system memory.
AIDA64 offers maximum heat generation when set to stress just the FPU in the stability test, which will really push the CPU. This test represents extreme loads much like LinX, Prime95, and other extreme stress tests many users are familiar with.
Benchmark Scores | Faster than yours... I'd bet on it. :) |
System Name | Old reliable |
Processor | Intel 8700K @ 4.8 GHz |
Motherboard | MSI Z370 Gaming Pro Carbon AC |
Cooling | Custom Water |
Memory | 32 GB Crucial Ballistix 3666 MHz |
Video Card(s) | MSI RTX 3080 10GB Suprim X |
Storage | 3x SSDs 2x HDDs |
Display(s) | ASUS VG27AQL1A x2 2560x1440 8bit IPS |
Case | Thermaltake Core P3 TG |
Audio Device(s) | Samson Meteor Mic / Generic 2.1 / KRK KNS 6400 headset |
Power Supply | Zalman EBT-1000 |
Mouse | Mionix NAOS 7000 |
Keyboard | Mionix |
Because he's asking about what our cooler reviewer is doing to generate his test results, not what an average user does, it isn't that pointless? SMH. Makes sense that a user would ask such a question so that they might be able to draw some comparison to their needs or what they are looking to buy.IntelBurnTest for max load. Typical load is too subjective to be definable. IMO it's anything shy of max load and more than idle. IOW between 1% and 99% CPU usage.
Seems like such a pointless question to ask. As in why do you want to know? What good does it do you to have a definition of "typical load"? If your system is configured to handle max load with stability, it will be stable with any "typical" load and at idle.
System Name | HAL |
Processor | Core i9 14900ks @5.9-6.3 |
Motherboard | Z790 Dark Hero |
Cooling | Bitspower Summit SE & (2) 360 Corsair XR7 Rads push/pull |
Memory | 2x 32GB (64GB) Gskill trident 6000 CL30 |
Video Card(s) | RTX 4090 Gigagbyte gaming OC @ +200/1300 |
Storage | (M2's) 2x Samsung 980 pro 2TB, 1xWD Black 2TB, 1x SK Hynix Platinum P41 2TB |
Display(s) | 65" LG OLED 120HZ |
Case | Lian Li dyanmic Evo11 with distro plate |
Audio Device(s) | Klipsh 7.1 through Sony DH790 EARC. |
Power Supply | Thermaltake 1350 |
Software | Microsoft Windows 11 x64 |
That doesn't mean much... I can make my PC hit your definition of max load in 5 different ways with 5 different max temperatures and power use. See post #7.Max load to me is 100% or dang close...
I still don't get it. You always want the best cooler you can get for your money. Basing that on some hypothetical and/or indefinable load is to me...IMO...pointless. And I could say worse about it. But I'm playing nice today. Max load temps are the only thing you can use to determine the actual effectiveness of a given cooler with a given CPU. Without factoring in case design, case air flow, and other highly relevant factors(as EarthDog is getting at). By that I mean even max load temps are subjective to a certain extent too. But they mean the most as far as giving a good idea of cooler effectiveness. Under a given set of repeatable circumstances.Because he's asking about what our cooler reviewer is doing to generate his test results, not what an average user does, it isn't that pointless? SMH. Makes sense that a user would ask such a question so that they might be able to draw some comparison to their needs or what they are looking to buy.
Keyboard | Mionix |
I don't know what else to say. To me...Idle temps mean nothing...typical load temps mean nothing. Max load temp means everything. Why bother with anything else. I don't care about it.
That is why reviewers that know what they are doing (they do at TPU), test with the same tests and same loads so its comparable. Of course its a "YMMV" with case design/airflow and other relevant factors (which I was not getting at) as far as temps go. In other words, yeah, no system will hit the same exact temp his will for a WIDE variety of reasons.I still don't get it. You always want the best cooler you can get for your money. Basing that on some hypothetical and/or indefinable load is to me...IMO...pointless. And I could say worse about it. But I'm playing nice today. Max load temps are the only thing you can use to determine the actual effectiveness of a given cooler with a given CPU. Without factoring in case design, case air flow, and other highly relevant factors(as EarthDog is getting at). By that I mean even max load temps are subjective to a certain extent too. But they mean the most as far as giving a good idea of cooler effectiveness. Under a given set of repeatable circumstances.
good for you. Everyone has different opinions, yours isn't any better than anyone else's, so trying to force your opinion only makes you look like an ass.And I'm not saying you're doing your job incorrectly. I just don't look at most of it for meaningful information.
System Name | H7 Flow 2024 |
Processor | AMD 5800X3D |
Motherboard | Asus X570 Tough Gaming |
Cooling | Custom liquid |
Memory | 32 GB DDR4 |
Video Card(s) | Intel ARC A750 |
Storage | Crucial P5 Plus 2TB. |
Display(s) | AOC 24" Freesync 1m.s. 75Hz |
Mouse | Lenovo |
Keyboard | Eweadn Mechanical |
Software | W11 Pro 64 bit |
Max load to me is utilising the cpu at around 100%When they are testing CPU coolers they have idle, typical load, and max load (running aida64). What would playing a game maxed out at 1440p, a few tabs in chrome, and a word document constitute? Typical load?
Keyboard | Mionix |
