Q
quasar923
im wondering the difference in fat32 and NTFS HDD formating. what are the pros and cons in each if there are any if there is any difference. i have always used NTFS.
System Name | Whim |
Processor | Intel Core i5 2500k @ 4.4ghz |
Motherboard | Asus P8Z77-V LX |
Cooling | Cooler Master Hyper 212+ |
Memory | 2 x 4GB G.Skill Ripjaws @ 1600mhz |
Video Card(s) | Gigabyte GTX 670 2gb |
Storage | Samsung 840 Pro 256gb, WD 2TB Black |
Display(s) | Shimian QH270 (1440p), Asus VE228 (1080p) |
Case | Cooler Master 430 Elite |
Audio Device(s) | Onboard > PA2V2 Amp > Senn 595's |
Power Supply | Corsair 750w |
Software | Windows 8.1 (Tweaked) |
Processor | Amd Athlon X2 4600+ Windsor(90nm) EE(65W) @2.9-3.0 @1.45 |
Motherboard | Biostar Tforce [Nvidia] 550 |
Cooling | Thermaltake Blue Orb-- bunch of other fans here and there.... |
Memory | 2 gigs (2x1gb) of patriot ddr2 800 @ 4-4-4-12-2t |
Video Card(s) | Sapphire X1950pro Pci-E x16 @stock@stock on stock |
Storage | Seagate 7200.11 250gb Drive, WD raptors (30/40) in Raid 0 |
Display(s) | ANCIENT 15" sony lcd, bought it when it was like 500 bucks |
Case | Apevia X-plorer blue/black |
Audio Device(s) | Onboard- Why get an sound card when you can hum?? |
Power Supply | Antec NeoHe 550-manufactured by seasonic -replacement to the discontinued smart power series |
Software | Windows XP pro SP2 -- vista is still crap |
Processor | AMD Ryzen 7 5800X3D |
Motherboard | ASUS TUF Gaming X570-Pro Wifi II |
Cooling | Hyper 212 EVO v2 |
Memory | 2x16GB G.Skill DDR4-4000 |
Video Card(s) | AMD RX 6750 XT |
Storage | WD Black SN850 2TB, various other SSD's from ages past |
Display(s) | LG 27GL850 1440@144, AG Neovo EM2701QC 1440@75 |
Case | Zophos EVO Silent by Raijintek |
Audio Device(s) | HyperX Cloud II Wireless headphones |
Power Supply | Corsair RM850x |
Mouse | ProtoArc EM01 |
Keyboard | Razer Blackwidow X Chroma Mercury |
Software | Windows 11 Pro |
Processor | Intel Core 2 Quad Q9300 @3.0Ghz |
Motherboard | Gigabyte P35-DS3L rev2.0 |
Cooling | Xigamtek S1283, 2x Antec TriCool 120mm Case fans |
Memory | 2x2GB OCZ, DDR2-800 |
Video Card(s) | ASUS Radeon 3450 256mb |
Storage | WD 640GB AAKS; WD 500GB AAKS |
Display(s) | Dell 23" SP2309W |
Case | Sonata II |
Audio Device(s) | Audigy 2ZS |
Power Supply | OCZ GameXStream 700W modded with Scythe SFF21e |
System Name | intel-hate |
Processor | Amd phenom 2 955 @ 3800 |
Motherboard | msi 790fx-gd70 |
Cooling | coolermaster |
Memory | 4096 @1600 corsair |
Video Card(s) | sapphire 5770 @950-1350 |
Storage | 1 seagate 80gb sata2 1 160gb seagate sata |
Display(s) | 20inch wide lg |
Power Supply | chieftech 750w |
Software | windows 7 x64 |
Benchmark Scores | nah |
System Name | My Lovely PC :) |
Processor | Intel Core 2 Duo E6400 2.13GHz @3.12GHz - 1.35v/390fsb/8x multi |
Motherboard | Gigabyte P43-DS3L |
Cooling | Thermalright Ultra 120 Extreme - MX2 paste |
Memory | 2GB, Team Value Ram 667 @ 780MHz |
Video Card(s) | ECS 8800GT 512MB @ 700/1720/2100 |
Storage | 160GB Hitachi Deskstar/80GB Maxtor PY080L0 |
Display(s) | Asus VH226H 22" 1920x1080 |
Case | Eye-T |
Audio Device(s) | Realtek HD, AC888 8 channel audio |
Power Supply | 570 Watt, TRUST PSU |
Software | Windows 7 Beta |
why doesnt anyone use hpfs, would be a lot better for benchmarks
System Name | Chuck |
Processor | Core i5-2500k @ 4.5Ghz |
Motherboard | msi P67A-C43 |
Cooling | hyper 212, 2 120mm fans |
Memory | 8GB DDR3 1600MHz |
Video Card(s) | XFX 6870 |
Storage | 60GB sata3 sandforce ssd, 1TB samsung hdd |
Display(s) | Yamakazi Catleap |
Case | Possibly Antec, not sure |
Audio Device(s) | Onboard |
Power Supply | Rosewill 600W |
System Name | Moving into the mobile space |
Processor | 7940HS |
Motherboard | HP trash |
Cooling | HP trash |
Memory | 2x8GB |
Video Card(s) | 4070 mobile |
Storage | 512GB+2TB NVME |
Display(s) | some 165hz thing that isn't as nice as it sounded |
wiki said:Windows 95 and its successors Windows 98, Windows ME could only read/write HPFS when mapped via a network share, but could not read it from a local disk. They listed the NTFS partitions of networked computers as "HPFS", because NTFS and HPFS share the same filesystem identification number in the partition table.
Windows NT 3.1 and 3.51 had native read/write support for local disks and could even be installed onto an HPFS partition. This was because Microsoft at the time was creating OS/2 version 3 and implemented the filesystem.
Windows NT 4 still could read and write from local HPFS formatted drives however, using HPFS was discouraged starting with Windows NT 4 and in subsequent versions. Starting with Windows 2000 the filesystem driver pinball.sys enabling the read/write access was removed from the default installation. Pinball.sys was included on the installation media for Windows 2000 and could still be manually installed and used with some limitations.[citation needed] Later Windows versions did not ship with this driver.
Windows XP Professional allows to read and write like Windows 2000 since they are similar in code.
Case | Eye-T |
Fat only supports files up to 2GB, so that 10% is rather impossible on modern computers.FAT lows:
* Difficulty in access to big files (more than 10% of the disc space).
Don't forget filesystem security, ie access rights per user or group, compression, encryption and most importantly it's a journaling filesystem.NTFS highs:
* Fragmentation does not influence the system performance (the work might became worse as far as data access is concerned).
* Complicity of the structure of directories and the number of files do not affect the performance.
* Quick access to the required file fragment (i.e. editing of big .wav files).
* Very quick access to small files (several hundreds bytes) - the whole file is located in the same place as the system data (MFT recording).
That memory argument sounds a bit silly, I've been using NTFS ever since NT4 (ie win95 times) on machines with far lower RAM (NT4 requires only 12MB), I think this would apply more to huge drives. Though a system with huge drives most likely has more than 64MB RAM.NTFS lows:
* The memory size mustn't be less than 64 MBytes.
Really though, NTFS is the modern approach to HDD's. You should really only use FAT32 if you NEED to.
System Name | Rainbow Sparkles (Power efficient, <350W gaming load) |
Processor | Ryzen R7 5800x3D (Undervolted, 4.45GHz all core) |
Motherboard | Asus x570-F (BIOS Modded) |
Cooling | Alphacool Apex UV - Alphacool Eisblock XPX Aurora + EK Quantum ARGB 3090 w/ active backplate |
Memory | 2x32GB DDR4 3600 Corsair Vengeance RGB @3866 C18-22-22-22-42 TRFC704 (1.4V Hynix MJR - SoC 1.15V) |
Video Card(s) | Galax RTX 3090 SG 24GB: Underclocked to 1700Mhz 0.750v (375W down to 250W)) |
Storage | 2TB WD SN850 NVME + 1TB Sasmsung 970 Pro NVME + 1TB Intel 6000P NVME USB 3.2 |
Display(s) | Phillips 32 32M1N5800A (4k144), LG 32" (4K60) | Gigabyte G32QC (2k165) | Phillips 328m6fjrmb (2K144) |
Case | Fractal Design R6 |
Audio Device(s) | Logitech G560 | Corsair Void pro RGB |Blue Yeti mic |
Power Supply | Fractal Ion+ 2 860W (Platinum) (This thing is God-tier. Silent and TINY) |
Mouse | Logitech G Pro wireless + Steelseries Prisma XL |
Keyboard | Razer Huntsman TE ( Sexy white keycaps) |
VR HMD | Oculus Rift S + Quest 2 |
Software | Windows 11 pro x64 (Yes, it's genuinely a good OS) OpenRGB - ditch the branded bloatware! |
Benchmark Scores | Nyooom. |
Processor | AMD 3900X \ AMD 7700X |
Motherboard | ASRock AM4 X570 Pro 4 \ ASUS X670Xe TUF |
Cooling | D15 |
Memory | Patriot 2x16GB PVS432G320C6K \ G.Skill Flare X5 F5-6000J3238F 2x16GB |
Video Card(s) | eVga GTX1060 SSC \ XFX RX 6950XT RX-695XATBD9 |
Storage | Sammy 860, MX500, Sabrent Rocket 4 Sammy Evo 980 \ 1xSabrent Rocket 4+, Sammy 2x990 Pro |
Display(s) | Samsung 1080P \ LG 43UN700 |
Case | Fractal Design Pop Air 2x140mm fans from Torrent \ Fractal Design Torrent 2 SilverStone FHP141x2 |
Audio Device(s) | Yamaha RX-V677 \ Yamaha CX-830+Yamaha MX-630 \Paradigm 7se MKII, Paradigm 5SE MK1 , Blue Yeti |
Power Supply | Seasonic Prime TX-750 \ Corsair RM1000X Shift |
Mouse | Steelseries Sensei wireless \ Steelseries Sensei wireless |
Keyboard | Logitech K120 \ Wooting Two HE |
Benchmark Scores | Meh benchmarks. |
fat32 does 4GB files
NTFS does have better security, by far.
NTFS doesnt work on USB drives for some reason.
You're right, my mistake. 2GB is the silly limit on iso9660 or whatever the DVD standard is.
NTFS works on USB drives though, both HD's and flash. You have to uncheck optimize for quick removal though.
i've got it working on an E-sata drive (160GB) by formatting it on sata, but windows just wont let me format a USB connected drive as anything but fat32. its weird and annoying... you got any specific details on whats different when using it over USB? (E-sata works as hotplug for me 'quick removal' with NTFS)
The last 9 words of the part you quoted.
i meant, what else? does it have any actual downsides, or is it just MS being weird?
System Name | [Primary Workstation] |
Processor | Intel Core i7-920 Bloomfield @ 3.8GHz/4.55GHz [24-7/Bench] |
Motherboard | EVGA X58 E758-A1 [Tweaked right!] |
Cooling | Cooler Master V8 [stock fan + two 133CFM ULTRA KAZE fans] |
Memory | 12GB [Kingston HyperX] |
Video Card(s) | constantly upgrading/downgrading [prefer nVidia] |
Storage | constantly upgrading/downgrading [prefer Hitachi/Samsung] |
Display(s) | Triple LCD [40 inch primary + 32 & 28 inch auxiliary displays] |
Case | Cooler Master Cosmos 1000 [Mesh Mod, CFM Overload] |
Audio Device(s) | ASUS Xonar D1 + onboard Realtek ALC889A [Logitech Z-5300 Spk., Niko 650-HP 5.1 Hp., X-Bass Hp.] |
Power Supply | Corsair TX950W [aka Reactor] |
Software | This and that... [All software 100% legit and paid for, 0% pirated] |
Benchmark Scores | Ridiculously good scores!!! |
Processor | Core I5 4440 / 4430 |
Motherboard | Asus z87-k / Gigabyte ga h97- d3h |
Cooling | Arctic freezer / Generic |
Memory | 8 gb Mushkin / Various |
Video Card(s) | Radeon 7850 cf / Gtx 690 |
Storage | Samsung 850 EVO 250 gb / 2x1 terabyte hdds Wd 256 gb nvme |
Display(s) | Technika 32" / Asus 24` ips |
Case | Corsair |
Audio Device(s) | X-fi Titanium |
Power Supply | Corsair 850 w |
Software | Windows 10 |
I`m not sure , but isn`t there a 32-gig partition size limit with fat 32 ?
